Help with a compiling error
My latest version of code will not compile for an UNO.
When I comment out the line below it works, but that’s so weird since that part of the code is exactly the same as the code I had in my previous version.
myFile.println(dataString);
What was added:
  • Output LED on pin 13
  • Input Switch (recordDATA) on pin 12 (which hopefully only lets the arduino save the string to the SD card if the switch is on
Newest code:
#include <SPI.h>
#include <SD.h>
File myFile;
int ledPin = 13;
int recordDATA = 12;
  while (!Serial) {
    // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  Serial.println("A0, A1, A2, A3, A4, A5, ms time");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  pinMode(recordDATA, INPUT);
  // make a string for assembling the data to log:
  String dataString = "";
  // read 6 sensors and append to the string:
  for (int analogPin = 0; analogPin < 6; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    dataString += ",";
  // append time stamp
  dataString += String(millis());
  Serial.println(dataString);
  myFile = SD.open("test.csv", FILE_WRITE);
  if (digitalRead(recordDATA) == HIGH) {
    digitalWrite(ledPin, HIGH);
    // if the file opened okay, write to it:
    if (myFile) {
      myFile.close();
    else {
      // if the file didn't open, print an error:
      Serial.println("error opening test.txt");
  else {
  delay(3000);
Error message:
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp: In member function 'availableForWrite':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp:203:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.19.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.19.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
previous code version that worked perfectly:
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  if (!SD.begin(4)) {
    while (1);
    dataString += ",";
  if (myFile) {
    myFile.close();
  delay(3000);
Do a search of this site for "arduino ide segmentation fault" for information.
Which version of IDE? it compiles ok in 1.8.5
Sketch uses 12650 bytes (39%) of program storage space. Maximum is 32256 bytes.
Global variables use 1020 bytes (49%) of dynamic memory, leaving 1028 bytes for local variables. Maximum is 2048 bytes.
I am using IDE 1.8.8
Turns out I had to follow Pert's response here to roll back to an older version of the AVR Boards: https://forum.arduino.cc/index.php?topic=572746.0
It's compiling properly.
Thank you both for taking your time to help!
