I have a Intel 4 pin fan ( FHP 6074; Black - GND; Yellow - 12V; Green - Tach; Blue - PWM) and I want to make the following project:
In Serial Monitor I want to give the fan the command to spin with X RPM (Ex: 1500 RPM). Next, on an LCD
I want to read the fan speed to see if it's the same with the one desired.
I tried a lot of codes but none worked as I wanted.
//project done by www.theorycircuit.com
//code by Crenn from http://thebestcasescenario.com thank you!
//Varibles used for calculations
int NbTopsFan; int Calc;
//The pin location of the sensor
int hallsensor = 2; typedef struct{
//Defines the structure for multiple fans and
//their dividers
char fantype;
unsigned int fandiv; }fanspec;
//Definitions of the fans
//This is the varible used to select the fan and it's divider,
//set 1 for unipole hall effect sensor
//and 2 for bipole hall effect sensor
fanspec fanspace[3]={{0,1},{1,2},{2,8}}; char fan = 1;
void rpm ()
//This is the function that the interupt calls
{ NbTopsFan++; }
//This is the setup function where the serial port is initialised,
//and the interrupt is attached
{ pinMode(hallsensor, INPUT);
attachInterrupt(0, rpm, RISING); }
void loop ()
//Set NbTops to 0 ready for calculations
{ NbTopsFan = 0;
//Enables interrupts
sei();
//Wait 1 second
delay (1000);
//Disable interrupts
cli();
//Times NbTopsFan (which is apprioxiamately the fequency the fan
//is spinning at) by 60 seconds before dividing by the fan's divider
Calc = ((NbTopsFan * 60)/fanspace[fan].fandiv);
//Prints the number calculated above
Serial.print (Calc, DEC);
//Prints " rpm" and a new line
Serial.print (" rpm\r\n");
I think a better approach would be to power up your motor and get variable speed working , write your own code to do that . Then get the lcd working , then try and measure the rpm using that third wire .
Finding a couple of bits of code , then sticking them together is not the way in my opinion .
