Hi
I have a project that uses 2 Buttons and a relay shield module
Im only using two relays
now i dont know how to code it
the game has two players, each player has 1 button to pass the turn to the other one
if they dont press the button in 8 seconds, the turn is passed to the other player
Each player has 1 series off leds trigger by the relay
only in the first 3 second of the program, both leds blink, otherwise only 1 relay can be turned on at the time.
All of that makes sense. When it is your turn, you press the button. If you don't press the button in 8 seconds, it is pressed for you.
This part I don't understand. How many LEDs? What do they do?
Is any score kept? Does the game ever end? Is there a way to win?
the led part is simply sending digital pin power to the numer 6 for one player and numer 7 for the other that ativates the relay that ativates 24 leds (for each player)
can you help me code or send me a demo one?
const byte Player1ButtonPin = 2;
const byte Player1RelayPin = 6;
const byte Player2ButtonPin = 3;
const byte Player2RelayPin = 7;
bool TurnPlayer1; // 'true' for Player 1, 'false' for Player 2
unsigned long PlayerTurnStartTime = 0;
pinMode(Player1ButtonPin, INPUT_PULLUP);
pinMode(Player1RelayPin, OUTPUT);
pinMode(Player2ButtonPin, INPUT_PULLUP);
pinMode(Player2RelayPin, OUTPUT);
// Turns start with Player 1
TurnPlayer1 = true; // Player 1's turn
digitalWrite(Player1RelayPin, HIGH); // Turn on Player 1 lights
digitalWrite(Player2RelayPin, LOW); // Turn off Player 1 lights
PlayerTurnStartTime = millis();
if (TurnPlayer1)
// Player 1's turn until they press their button or 8 seconds is up
if (digitalRead(Player1ButtonPin) == LOW || millis() - PlayerTurnStartTime >= 8000)
// Change player
digitalWrite(Player1RelayPin, LOW); // Turn off Player 1 lights
TurnPlayer1 = false; // Player 2's turn
digitalWrite(Player2RelayPin, HIGH); // Turn on Player 2 lights
// Player 2's turn until they press their button or 8 seconds is up
// Change player
digitalWrite(Player2RelayPin, LOW); // Turn off Player 2 lights
hi again i tried the code you send me but the two relays are always on
How have you got your buttons wired?
@johnwasser code needs your buttons between gnd and the input pin, not 5V and the input pin.
Can you please post a circuit diagram?
Thanks.. Tom..
oh ok now works ahaahha
thanks
is easy to implement in startup like a sequence of cliks to make like a sinal to the player that the game is about to start??
You could flash the lights:
// Signal for attention. Blink both lights three times and then pause one second:
for (int i = 0; i < 3; i++)
delay(300);
delay(300);
delay(700); // Add this delay to the 300 milliseconds above to get 1 second
you are a genius thank you so much
