Help with a Smartshield and relay project
I am trying to make the following code work but I am having issues.
/// @file
/// @brief
///   Arduino SmartThings Shield LED Example with Network Status
/// @note
///              ______________
///             |         SW[] |
///             |[]RST         |
///             |         AREF |--
///             |          GND |--
///             |           13 |--X LED
///             |           12 |--
///             |           11 |--
///           --| 3.3V      10 |--
///           --| 5V         9 |--
///           --| GND        8 |--
///           --| GND          |
///           --| Vin        7 |--
///             |            6 |--
///           --| A0         5 |--
///           --| A1    ( )  4 |--
///           --| A2         3 |--X THING_RX
///           --| A3  ____   2 |--X THING_TX
///           --| A4 |    |  1 |--
///           --| A5 |    |  0 |--
///             |____|    |____|
///                  |____|
#include <SoftwareSerial.h>   //TODO need to set due to some weird wire language linker, should we absorb this whole library into smartthings
#include <SmartThings.h>
// Pin Definitions    | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
//                    V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
#define PIN_LED         13
#define PIN_THING_RX    3
#define PIN_THING_TX    2
// Global Variables   | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
SmartThingsCallout_t messageCallout;    // call out function forward decalaration
SmartThings smartthing(PIN_THING_RX, PIN_THING_TX, messageCallout);  // constructor
bool isDebugEnabled;    // enable or disable debug in this example
int stateLED;           // state to track last set value of LED
int stateNetwork;       // state of the network
int relay1 = 7;         // energize relay1 shield pin 7
int relay2 = 6;         // energize relay2 shield pin 6
// Local Functions  | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
//                  V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
void on()
  stateLED = 1;                 // save state as 1 (on)
  digitalWrite(PIN_LED, HIGH);  // turn LED on
  digitalWrite(relay1, HIGH);   // energize relay1
  delay (1000);                 // hold relay1 on for 1 second
  digitalWrite(relay1, LOW);    // deenergize relay1
  smartthing.shieldSetLED(0, 0, 2);
  smartthing.send("on");        // send message to cloud
void off()
  stateLED = 0;                 // set state to 0 (off)
  digitalWrite(PIN_LED, LOW);   // turn LED off
  digitalWrite(relay2, HIGH);   // energize relay2
  digitalWrite(relay2, LOW);    // deenergize relay2
  smartthing.shieldSetLED(0, 0, 0);
  smartthing.send("off");       // send message to cloud
void setNetworkStateLED()
  SmartThingsNetworkState_t tempState = smartthing.shieldGetLastNetworkState();
  if (tempState != stateNetwork)
    switch (tempState)
      case STATE_NO_NETWORK:
        if (isDebugEnabled) Serial.println("NO_NETWORK");
        smartthing.shieldSetLED(2, 0, 0); // red
      case STATE_JOINING:
        if (isDebugEnabled) Serial.println("JOINING");
      case STATE_JOINED:
        if (isDebugEnabled) Serial.println("JOINED");
        smartthing.shieldSetLED(0, 0, 0); // off
      case STATE_JOINED_NOPARENT:
        if (isDebugEnabled) Serial.println("JOINED_NOPARENT");
        smartthing.shieldSetLED(2, 0, 2); // purple
      case STATE_LEAVING:
        if (isDebugEnabled) Serial.println("LEAVING");
      default:
      case STATE_UNKNOWN:
        if (isDebugEnabled) Serial.println("UNKNOWN");
        smartthing.shieldSetLED(0, 2, 0); // green
    stateNetwork = tempState;
// API Functions    | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
  // setup default state of global variables
  isDebugEnabled = true;
  stateLED = 0;                 // matches state of hardware pin set below
  stateNetwork = STATE_JOINED;  // set to joined to keep state off if off
  // setup hardware pins
  pinMode(PIN_LED, OUTPUT);     // define PIN_LED as an output
  digitalWrite(PIN_LED, LOW);   // set value to LOW (off) to match stateLED=0
  if (isDebugEnabled)
  { // setup debug serial port
    Serial.begin(9600);         // setup serial with a baud rate of 9600
    Serial.println("setup..");  // print out 'setup..' on start
  // run smartthing logic
  smartthing.run();
  setNetworkStateLED();
void messageCallout(String message)
  // if debug is enabled print out the received message
  if (isDebugEnabled)
    Serial.print("Received message: '");
    Serial.print(message);
    Serial.println("' ");
  // if message contents equals to 'on' then call on() function
  // else if message contents equals to 'off' then call off() function
  if (message.equals("on"))
    on();
  else if (message.equals("off"))
    off();
I am using the following Shields:
Arduino Uno Rev3
Seeed Relay Shield Relay Shield v3.0 - Seeed Studio
SmartThings Shield https://support.smartthings.com/hc/en-us/articles/213652126-SmartThings-Shield-for-Arduino
The object of my application is to activate two relays when a command is issued.
If the On command is sent then relay1 would be energized for one second, then when the off command is sent relay2 is energized for one second. If someone can look at my code and tell me where I am going wrong I would appreciate it
We know what the code should do, but not what it actually does. Care to clue us in?
it does not trigger the relays as I had hoped! I added lines of code to designate which relays to trigger on pins 7 and 6. the boards are stacked and there is no interference between pins being assigned different modes.
I was hoping someone with more coding experience than I would see what is needed and asset with the correction!
My car won't start. Can you fix it, over the phone? Of course not, if I won't even tell you what happens when I try. It could be something as simple as a dead battery. Or, it could be something as stupid as I lost the key.
You have NOT told us what DOES happen. All you have managed, so far, is to tell us what it doesn't do.
Until you provide the needed details, no one can help you "asset with the correction". Whatever that means.
