Help with a Temperature and Pressure measurment system
Hi
I am completely new to arduino I was just wondering what is the best board for me to get being a starter? and also my project is to create a temperature and pressure measurement system what sensors will I need to use?
0-50 deg c max (temperature)
and 0-12 bar max (Pressure)
I would like these sensors to be portable to be mounted within a manufacture vessel so a temperature probe and a pressure sensor which can be threaded into a vessel.
thanks
DS18B20 for temperature is a good sensor for most projects.
pressure ? air / water?
Please tell more about your project.
i am trying to create a temperature and pressure measuring system so that the temperature of a tank can be displaced on a little LCD likewise for the pressure. this means the two sensors need to be housed in something so they can be threaded into a try clamp for a tank/vessel. like the image on the link below.
https://www.google.co.uk/imgres?imgurl=http://www.bubbasbarrels.com/sites/all/files/imagecache/product_full/DSC_4782.jpg&imgrefurl=http://www.bubbasbarrels.com/catalog/hardware-fittings/tri-clamp-fittings/fittings-size/2-tri-clamp&h=581&w=871&tbnid=jz52qkFycmrLjM:&docid=NNr45BfWkT9L1M&ei=gn2iVsmDHsae-wGfy5TIBA&tbm=isch&ved=0ahUKEwjJzIG9jr7KAhVGzz4KHZ8lBUkQMwhiKDswOw
i am just wanting simple unit displaying for the pressure and temperature, i may progress this to data logging i.e temperature average over 12 hours
is this possible with a arduino or is it more of a plc and HMI job?
The image you posted looks like it is a boss to be welded onto a tank??
Like has been asked before, does it need to measure air pressure (in a tank), or a liquid?
Jon
Hi the ferrule clamps onto the tank and i am wanting to measure air pressure so the sensor must be capable or screwing into the ferrule
Thanks
