Help with a timer
I am new to arduino and would like some help to build as timer to turn on and off a relay.
I want to be able to set the time in 5 minute intervals to 30 minutes in total and have a led light up for each interval. I want to use a reed switch or hall effect switch to set the interval with a magnet and a latching reed or hall effect switch to start a motor via a relay.
I am only just starting with arduino so this is over my head at the moment. Would anyone like to help me with code and schematic.
I wish I could do this myself however I would like to use the timer soon and I don't think I will be able to figure it out that quickly.
This is also sounding like a school project. What is it that you are trying to do with this ?
I am not sure how the timer is connected to the motor though. This sounds like two tasks.
Cheers Pete.
Some particular reason to get so fancy? Sounds like you want to make a "magic" wand with a magnet in it, and wave it at the Arduino to make stuff happen.
PaulS:
Ha Ha Paul .. sounds like you may have built one of these already then :slight_smile:
Sounds like a plot from "Home Alone"
I have visions of a motor with paddles attached lurking behind the Street Door. Anyone that enters gets the thousand fist punch. :slight_smile:
