You need to decouple receiving input from displaying your patterns. Read this tutorial: several things at the same time
And then structure your code like a state machine. Updating/running your patterns should be moved outside your if(client) {} condition since you want to update your patterns every time though loop.
#include <WiFi.h>
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 13
#define NUM_LEDS 300
Adafruit_NeoPixel strip(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 500
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// neopixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// fastlED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for (int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
uint16_t rainbow_j;
void rainbowCycle(int SpeedDelay) {
byte *c;
uint16_t j = rainbow_j;
for (int i = 0; i < NUM_LEDS; i++) {
c = Wheel(((i * 256 / NUM_LEDS) + j) & 255);
setPixel(i, *c, *(c + 1), *(c + 2));
strip.setBrightness(255);
showStrip();
delay(SpeedDelay);
rainbow_j++;
if ( rainbow_j >= 256 * 5 ) rainbow_j = 0;
byte * Wheel(byte WheelPos) {
static byte c[3];
if (WheelPos < 85) {
c[0] = WheelPos * 3;
c[1] = 255 - WheelPos * 3;
c[2] = 0;
} else if (WheelPos < 170) {
WheelPos -= 85;
c[0] = 255 - WheelPos * 3;
c[1] = 0;
c[2] = WheelPos * 3;
WheelPos -= 170;
c[0] = 0;
c[1] = WheelPos * 3;
c[2] = 255 - WheelPos * 3;
return c;
const char* ssid = "BT-TGAHZR";
const char* password = "beqxyVRt6cGng7";
WiFiServer server(80);
pinMode(5, OUTPUT);
delay(10);
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
strip.begin();
enum { NONE, RAINBOW };
int pattern = NONE;
switch ( pattern ) {
case NONE:
// nothing to do
break;
case RAINBOW:
rainbowCycle(5);
break;
WiFiClient client = server.available();
if (client) {
Serial.println("New Client.");
String currentLine = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (c == '\n') {
if (currentLine.length() == 0) {
client.println("Content-type:text/html");
client.println();
client.print("Click <a href=\"/N\">here</a> to Neophase.<br>");
client.print("Click <a href=\"/R\">here</a> to Running Lights.<br>");
client.print("Click <a href=\"/RC\">here</a> to Rainbow Cycle.<br>");
client.print("Click <a href=\"/L\">here</a> to turn off.<br>");
client.println();
break;
currentLine = "";
} else if (c != '\r') {
currentLine += c;
if ( currentLine.endsWith("GET /RC")) {
pattern = RAINBOW;
rainbow_j = 0;
if (currentLine.endsWith("GET /L")) {
pattern = NONE;
setAll(0, 0, 0);
client.stop();
Serial.println("Client Disconnected.");
