Help With AccelStepper
Im trying to make a stepper move X number of steps when a button is activated and then wait for the button to be pressed to move another 16 steps, I already have the homing secuence in void setup ().
Show us your complete sketch between code tags (the </> button). Tell us what it does and what it should do.
Sorry, I forgot to put the code…
Here it is, after the homing process, the steppers starts moving and stops when the button is pressed. I need to move the stepper X number of steps when the button is pressed and then stop to wait the next button press.
#include <AccelStepper.h>
AccelStepper stepper (1, 9 ,8);
#define home_switch 4
#define buttonState 7
long initial_homing=-1;
long stepstogo=16;
pinMode(home_switch, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
delay(5);
stepper.setMaxSpeed(100);
stepper.setAcceleration(100);
while (digitalRead(home_switch)) {
stepper.moveTo(initial_homing);
initial_homing–;
stepper.run();
delay(5);
stepper.setCurrentPosition(0);
stepper.setMaxSpeed(500000);
stepper.setAcceleration(5000);
stepper.setSpeed(2800);
if (digitalRead(buttonState)){
stepper.move(16);
stepper.run();
Are those reasonable values for max speed, acceleration and speed?
Have you tried to use lower values?
marioacosta556:
What happens when you try the code you posted?
You seem to have the motor working with
so why are you changing to ridiculous numbers with these lines
...R
The speed of movement is not a problem, those are just random numbers that I put there.
Yes, I have tried with lower values.
I need to move the stepper an specific number of steps with a button press and then wait until the next button press to move again.
Have you tried this:
    stepper.move(16);
    stepper.run();
Jacques
Yes, I already tried that, the problem is that as soon as the homing process is completed, the stepper begins to move without pressing the start button.
This
    stepper.move(16);
  stepper.run();
Will certainly do that
jbellavance:
Well spotted.
@marioacosta556, because you are using INPUT_PULLUP you should have
if (digitalRead(buttonState) == LOW){
...R
Well spotted also :wink:
Jacques
You both, thank you very much! That solved the problem.
