I am using the arduino FX with an arduino nano to produce sound fx for a prop. I am using a string to store names for the sound files in the code below. Everything works fine as long as I have 17 or less names in the string. If I have 18 or more, the Arduino FX ceases to work at all. Here's a look at some of the code:
// audio track names on soundboard
const String startupTrack = "T00 WAV";
const String blastTrack = "T01 WAV";
const String endTrack = "T02 WAV";
const String idleTrack = "T03 WAV";
const String shutdownTrack = "T04 WAV";
const String clickTrack = "T05 WAV";
const String chargeTrack = "T06 WAV";
const String warnTrack = "T07 WAV";
const String ventTrack = "T08 WAV";
const String texTrack = "T09 WAV";
const String choreTrack = "T10 WAV";
const String toolsTrack = "T11 WAV";
const String listenTrack = "T12 WAV";
const String thatTrack = "T13 WAV";
const String neutronizedTrack="T14 WAV";
const String boxTrack = "T15 WAV";
const String themeTrack = "T16 OGG";
const String slimeTrack = "T17 OGG";
// softwareserial at 9600 baud for the audio board
ss.begin(9600);
// see if we have the soundboard
// If we fail to communicate, loop forever for now but it would be nice to warn the user somehow
if (!sfx.reset()) {
while (1);
// set act modes for the fx board
pinMode(ACT, INPUT);
/* ************* Audio Board Helper Functions ************* */
// helper function to play a track by name on the audio board
void playAudio( String trackname, int playing ) {
// stop track if one is going
if (playing == 0) {
sfx.stop();
char charName[20];
trackname.toCharArray(charName, 20);
// now go play
if (sfx.playTrack(charName)) {
sfx.unpause();
// get the current time
// find out of the audio board is playing audio
int playing = digitalRead(ACT);
// get the current switch states
int theme_switch = digitalRead(THEME_SWITCH);
// if the theme switch has recently changed from off to on we
// should play the full ghostbusters theme song
if (theme_switch == 1) {
if (theme == false) {
playAudio(themeTrack, playing);
theme = true;
theme = false;
How can I fix this, or is there another way to do this?
