Help with ADC read on UNO R4
Hi All,
This is my first time posting and I would like to learn about using the UNO R4 to read millivolts. I am trying to read a voltage source from 0V to 8V. I know the maximum ADC input is 5V so I am using a voltage divider to drop the source. The code and circuit seemed to work fine when the source is above 100 mV, but I found that the ADC values started to behave unexpectedly when the source was below that. I am using a 10mV source as an example here. During troubleshooting, the Arduino can read a correct ADC (config 2) before the voltage divider, but it gives unexpected values after the voltage divider (config 1). I have a suspension that my voltage divider is the issue here, but I am not sure why that is and how to move forward. Any advice here would be appreciated.
Thank you and happy holidays everyone!
int sensorValue;
float Vcc;
float convert = 16383.0;
  // initialize serial communication at 9600 bits per second:
  analogReadResolution(14); //change to 14-bit resolution
// the loop routine runs over and over again forever:
sensorValue = analogRead(A0);
Vcc = analogReference();
Serial.print("ADC = ");
Serial.println(sensorValue);
Serial.print("Voltage = ");
Serial.println(sensorValue*(Vcc/convert)*1000);
delay(100);
config 1
config 2
Check the processor data sheet for restrictions on voltage source impedance with the Uno R4 ADC.
Hi, Thanks for the direction. I found that the input resistance is 2.5 kOhm for the high-precision channel. Does this mean that R1 and R2 in series should be much smaller than 2.5 kohm? Shouldn't the resistance in the ADC be extremely high so that it does not draw any current from the input?
Thank you for your help!
