help with an aquarium project but not to sure of what im doing
hi everyone im new to arduino (but im ok with small electrical projects) and after alil bit of looking around and reading i think that an arduino would be the best route for my next project. im starting to set up a saltwater aquarium and would really like to use a arduino to monitor the high/low water level in my sump aswell as the temp
i was looking to start off with
or
http://www.amazon.ca/dp/B00CRF1AA0/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=23YP34XTM89GW&coliid=IO9HNUQHXYSW5
not sure what the diffrence is or witch would be better for this
2 of these to watch the water level
http://www.amazon.ca/dp/B00CI0TZ0G/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23YP34XTM89GW&coliid=I3DMULM0R4QX3E
to power the unit
http://www.amazon.ca/dp/B00IWDXYJQ/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23YP34XTM89GW&coliid=I1P5T83TPIQ5O9
id also like to use 2 of these
http://www.amazon.ca/dp/B00INX20ZY/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23YP34XTM89GW&coliid=I2UT2BOMOIWLDE
one in the tank and one in the sump
and for a warning
http://www.amazon.ca/dp/B00EK6NAYI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23YP34XTM89GW&coliid=I4LWKG6EB89QI
to diffrent colored leds
http://www.amazon.ca/dp/B00E34MNYU/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23YP34XTM89GW&coliid=IYVUSCUQ8U9B9
to let me know witsh water level swtich is going off.
am i way off track here is can this be done, would like the lcd screen to just give the temps of both tanks
Yes, this can be done.
I suggest you leave the LCD screen until you have eveything else working. The code for the LCD just clutters up a program and makes it harder to understand. In the initial stages just display everything on the Serial Monitor.
...R
thanks so im guessing this isnt really a novice projet?
anyone on here bilud custom projects for money?
badboythecat: thanks so im guessing this isnt really a novice projet?
Check out the Reef Angel.
No, this is not very complicated, but if you really want to pay somebody to do this for you there's Gigs and Collaborations section of the forums.
That temperature sensor might be a problem if you submerse it in salt water. You'll need a waterproof one, such as this one.
