help with an error in my sketch
Bonjour,
J'ai encore des soucis avec un sketch qui me renvoit un code d'erreur que je ne comprends pas.
Le message d'erreur est le suivant:
Project_22_Keypad_Entry_System.ino:9:38: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Password password = Password( "2468" ); // Set password as 2468
Le sketch est le suivant:
// Keypad Library for Arduino
// Authors: Mark Stanley, Alexander Brevig
// Arduino Playground - KeypadTutorial
#include <Password.h>
#include <Keypad.h>
#include <Servo.h>
Servo myservo;
const byte ROWS = 4; // set four rows
const byte COLS = 4; // set four columns
char keys[ROWS][COLS] = { // Define the keymap
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'', '0', '#', 'D'}
byte rowPins[ROWS] = { 9, 8, 7, 6 }; // Pins connected to keypad
// ROW0, ROW1, ROW2 and ROW3
byte colPins[COLS] = { 5, 4, 3, 2, }; // Pins connected to keypad
// COL0, COL1 and COL2
// Create the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins,
ROWS, COLS );
delay(200);
pinMode(11, OUTPUT); // Set green LED as output
pinMode(12, OUTPUT); // Set red LED as output
myservo.attach(13); // Pin connected to servo
keypad.addEventListener(keypadEvent); // Add an event listener to
// detect keypresses
keypad.getKey();
myservo.write(0);
void keypadEvent(KeypadEvent eKey) {
switch (keypad.getState()) {
case PRESSED:
Serial.print("Pressed: ");
Serial.println(eKey);
switch (eKey) {
case '
': checkPassword(); break;
case '#': password.reset(); break;
default: password.append(eKey);
void checkPassword() {
if (password.evaluate() ) {
Serial.println("Success"); // If the password is correct...
myservo.write(90); // Move servo arm 90 degrees
digitalWrite(11, HIGH); // Turn on green LED
delay(500); // Wait 5 seconds
digitalWrite(11, LOW); // Turn off green LED
Serial.println("Wrong"); // If the password is incorrect...
myservo.write(0);
digitalWrite(12, HIGH); // Turn on red LED
digitalWrite(12, LOW); // Turn off red LED
Merci de votre aide bienveillante
Franck
warning != error
To make the warning go away:
Password password = Password( (char *)"2468" ); // Set password as 2468
Thank you very much
Franck
