Hello everyone,
I made a basic interaction in which one audio file is triggered on a wave shield using a Sharp IR distance sensor. It uses Wave_HC.h, WaveUtil.h & SharpDistSensor.h.
Strangely, I had it working fine.. but when I revisited the project a week later, there is now a slight issue: when triggered, the audio plays three times in a loop before returning to reading the distance data. It seems to repeat the initial reading (<800mm) and use it to re-trigger the audio two more times. The IR has no obstruction at this point.
Any ideas? I've tried tweaking and adjusting code and hardware connections for hours and so confused.. perhaps someone with more coding knowledge might know of an additional line or two that could skip over this glitch?
Thanks.
This example plays every .WAV file it finds on the SD card in a loop
#include <WaveHC.h>
#include <WaveUtil.h>
#include <SharpDistSensor.h>
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
uint8_t dirLevel; // indent level for file/dir names (for prettyprinting)
dir_t dirBuf; // buffer for directory reads
// Analog pin to which the sensor is connected
const byte sensorPin = A0;
// Window size of the median filter (odd number, 1 = no filtering)
const byte medianFilterWindowSize = 5;
// Create an object instance of the SharpDistSensor class
SharpDistSensor sensor(sensorPin, medianFilterWindowSize);
Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
// Function definitions (we define them here, but the code is below)
void play(FatReader &dir);
//////////////////////////////////// SETUP
Serial.begin(9600); // set up Serial library at 9600 bps for debugging
putstring_nl("\nWave test!"); // say we woke up!
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(FreeRam());
// if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
if (!card.init()) { //play with 8 MHz spi (default faster!)
error("Card init. failed!"); // Something went wrong, lets print out why
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
error("No valid FAT partition!"); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(), DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
error("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Files found (* = fragmented):");
// Print out all of the files in all the directories.
root.ls(LS_R | LS_FLAG_FRAGMENTED);
//////////////////////////////////// LOOP
// 5v
// Get distance from sensor
int distance = sensor.getDist();
// Print distance to Serial
Serial.println(distance);
if (distance <= 800) {
//Serial.println(distance); // print the distance
root.rewind();
play(root); //play the track on the SD Card
/////////////////////////////////// HELPERS
print error message and halt
void error_P(const char *str) {
PgmPrint("Error: ");
SerialPrint_P(str);
sdErrorCheck();
while (1);
print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void) {
if (!card.errorCode()) return;
PgmPrint("\r\nSD I/O error: ");
Serial.print(card.errorCode(), HEX);
PgmPrint(", ");
Serial.println(card.errorData(), HEX);
while (1);
play recursively - possible stack overflow if subdirectories too nested
void play(FatReader &dir) {
FatReader file;
while (dir.readDir(dirBuf) > 0) { // Read every file in the directory one at a time
// Skip it if not a subdirectory and not a .WAV file
if (!DIR_IS_SUBDIR(dirBuf)
&& strncmp_P((char *)&dirBuf.name[8], PSTR("WAV"), 3)) {
continue;
Serial.println(); // clear out a new line
for (uint8_t i = 0; i < dirLevel; i++) {
Serial.write(' '); // this is for prettyprinting, put spaces in front
if (!file.open(vol, dirBuf)) { // open the file in the directory
error("file.open failed"); // something went wrong
if (file.isDir()) { // check if we opened a new directory
putstring("Subdir: ");
printEntryName(dirBuf);
dirLevel += 2; // add more spaces
// play files in subdirectory
play(file); // recursive!
dirLevel -= 2;
else {
// Aha! we found a file that isnt a directory
putstring("Playing ");
printEntryName(dirBuf); // print it out
if (!wave.create(file)) { // Figure out, is it a WAV proper?
putstring(" Not a valid WAV"); // ok skip it
Serial.println(); // Hooray it IS a WAV proper!
wave.play(); // make some noise!
uint8_t n = 0;
while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
putstring(".");
if (!(++n % 32))Serial.println();
delay(100);
sdErrorCheck(); // everything OK?
// if (wave.errors)Serial.println(wave.errors); // wave decoding errors
