Predoblikovano besedilo
I'm working on this project :
Joystick Controller for MeArm Robot - Recording Coordinates - Arduino Project Hub
I will us this code for 6Dof Robotic Arm . I have instead of 2 ,3 joysticks and instead 4, 6 servos. Manual everything works fine ,except of recording and playing.
When i record and play some of the servos working and some don´t. What do i need to change in code to work ? With orginal code for 2 joystick and 4 servos record and play works with no problem.
My code [code]
#include <Servo.h>
bool repeatePlaying = false; /* Repeatedly is running recorded cycle */
int delayBetweenCycles = 2000; /* Delay between cycles */
int basePin = 11; /* Base servo */
int shoulderPin = 10; /* Shoulder servo */
int elbowPin = 9; /* Elbow servo */
int gripperPin = 6; /* Gripper servo */
int foreArmPin = 7;
int wristPin = 8;
int xdirPin = 0; /* Base - joystick1*/
int ydirPin = 1; /* Shoulder - joystick1 */
int zdirPin = 3; /* Elbow - joystick2 */
int gdirPin = 2; /* Gripper - joystick2 */
int sdirPin = 5;
int rdirPin = 4;
//int pinRecord = A4; /* Button record - backward compatibility */
//int pinPlay = A5; /* Button play - backward compatibility */
int pinRecord = PD2; /* Button record - recommended (A4 is deprecated, will by used for additional joystick) */
int pinPlay = PD3; /* Button play - recommended (A5 is deprecated, will by used for additional joystick) */
int pinLedRecord = PD4; /* LED - indicates recording (light) or auto play mode (blink one) */
bool useInternalPullUpResistors = false;
const int buffSize = 512; /* Size of recording buffer */
int startBase = 90;
int startShoulder = 90;
int startElbow = 90;
int startGripper = 0;
int startForeArm = 90;
int startWrist = 90;
int posBase = 90;
int posShoulder = 90;
int posElbow = 90;
int posGripper = 0;
int posForeArm = 90;
int posWrist = 90;
int lastBase = 90;
int lastShoulder = 90;
int lastElbow = 90;
int lastGripper = 90;
int lastForeArm = 90;
int lastWrist = 90;
int minBase = 0;
int maxBase = 150;
int minShoulder = 0;
int maxShoulder = 150;
int minElbow = 0;
int maxElbow = 150;
int minGripper = 0;
int maxGripper = 150;
int minForeArm = 0;
int maxForeArm = 150;
int minWrist = 0;
int maxWrist = 150;
const int countServo = 6;
int buff[buffSize];
int buffAdd[countServo];
int recPos = 0;
int playPos = 0;
int buttonRecord = HIGH;
int buttonPlay = HIGH;
int buttonRecordLast = LOW;
int buttonPlayLast = LOW;
bool record = false;
bool play = false;
bool debug = false;
String command = "Manual";
int printPos = 0;
int buttonPlayDelay = 20;
int buttonPlayCount = 0;
bool ledLight = false;
Servo servoBase;
Servo servoShoulder;
Servo servoElbow;
Servo servoGripper;
Servo servoForeArm;
Servo servoWrist;
if (useInternalPullUpResistors) {
pinMode(pinRecord, INPUT_PULLUP);
pinMode(pinPlay, INPUT_PULLUP);
pinMode(pinRecord, INPUT);
pinMode(pinPlay, INPUT);
pinMode(xdirPin, INPUT);
pinMode(ydirPin, INPUT);
pinMode(zdirPin, INPUT);
pinMode(gdirPin, INPUT);
pinMode(sdirPin, INPUT);
pinMode(rdirPin, INPUT);
pinMode(pinLedRecord, OUTPUT);
servoBase.attach(basePin);
servoShoulder.attach(shoulderPin);
servoElbow.attach(elbowPin);
servoGripper.attach(gripperPin);
servoForeArm.attach(foreArmPin);
servoWrist.attach(wristPin);
StartPosition();
digitalWrite(pinLedRecord, HIGH);
digitalWrite(pinLedRecord, LOW);
buttonRecord = digitalRead(pinRecord);
buttonPlay = digitalRead(pinPlay);
// Serial.print(buttonRecord);
// Serial.print("\t");
// Serial.println(buttonPlay);
// for testing purposes
if (buttonPlay == LOW)
buttonPlayCount++;
if (buttonPlayCount >= buttonPlayDelay)
repeatePlaying = true;
else buttonPlayCount = 0;
if (buttonPlay != buttonPlayLast)
if (record)
record = false;
play = !play;
if (play)
StartPosition();
if (buttonRecord != buttonRecordLast)
if (buttonRecord == LOW)
record = !record;
if (record)
play = false;
recPos = 0;
if (debug) PrintBuffer();
buttonPlayLast = buttonPlay;
buttonRecordLast = buttonRecord;
float dx = map(analogRead(xdirPin), 0, 1023, -5.0, 5.0);
float dy = map(analogRead(ydirPin), 0, 1023, 5.0, -5.0);
float dz = map(analogRead(zdirPin), 0, 1023, 5.0, -5.0);
float dg = map(analogRead(gdirPin), 0, 1023, 5.0, -5.0);
float ds = map(analogRead(sdirPin), 0, 1023, 5.0, -5.0);
float dr = map(analogRead(rdirPin), 0, 1023, 5.0, -5.0);
if (abs(dx) < 1.5) dx = 0;
if (abs(dy) < 1.5) dy = 0;
if (abs(dz) < 1.5) dz = 0;
if (abs(dg) < 1.5) dg = 0;
if (abs(ds) < 1.5) ds = 0;
if (abs(dr) < 1.5) dr = 0;
posBase += dx;
posShoulder += dy;
posElbow += dz;
posGripper += dg;
posForeArm += ds;
posWrist += dr;
if (play)
if (playPos >= recPos) {
playPos = 0;
if (repeatePlaying)
delay(delayBetweenCycles);
StartPosition();
play = false;
bool endOfData = false;
while (!endOfData)
if (playPos >= buffSize - 1) break;
if (playPos >= recPos) break;
int data = buff[playPos];
int angle = data & 0xFFF;
int servoNumber = data & 0x3000;
endOfData = data & 0x4000;
switch (servoNumber)
case 0x0000:
posBase = angle;
case 0x1000:
posShoulder = angle;
case 0x2000:
posElbow = angle;
case 0x3000:
posForeArm = angle;
case 0x4000:
posWrist = angle;
case 0x5000:
posGripper = angle;
dg = posGripper - lastGripper;
playPos++;
if (posBase > maxBase) posBase = maxBase;
if (posShoulder > maxShoulder) posShoulder = maxShoulder;
if (posElbow > maxElbow) posElbow = maxElbow;
if (posGripper > maxGripper) posGripper = maxGripper;
if (posForeArm > maxForeArm) posForeArm = maxForeArm;
if (posWrist > maxWrist) posWrist = maxWrist;
if (posBase < minBase) posBase = minBase;
if (posShoulder < minShoulder) posShoulder = minShoulder;
if (posElbow < minElbow) posElbow = minElbow;
if (posGripper < minGripper) posGripper = minGripper;
if (posForeArm < minForeArm) posForeArm = minForeArm;
if (posWrist < minWrist) posWrist = minWrist;
servoBase.write(posBase);
servoShoulder.write(posShoulder);
servoElbow.write(posElbow);
servoForeArm.write(posForeArm);
servoWrist.write(posWrist);
bool waitGripper = false;
if (dg < 0) {
waitGripper = true;
else if (dg > 0) {
waitGripper = true;
servoGripper.write(posGripper);
if (play && waitGripper)
if ((lastBase != posBase) | (lastShoulder != posShoulder) | (lastElbow != posElbow) | (lastForeArm != posForeArm) | (lastWrist != posWrist) | (lastGripper != posGripper))
if (record)
if (recPos < buffSize - countServo)
int buffPos = 0;
if (lastBase != posBase)
buffAdd[buffPos] = posBase;
buffPos++;
if (lastShoulder != posShoulder)
buffAdd[buffPos] = posShoulder | 0x1000;
buffPos++;
if (lastElbow != posElbow)
buffAdd[buffPos] = posElbow | 0x2000;
buffPos++;
if(lastForeArm != posForeArm)
buffAdd[buffPos] = posForeArm | 0x3000;
buffPos++;
if(lastWrist != posWrist)
buffAdd[buffPos] = posWrist | 0x4000;
buffPos++;
if (lastGripper != posGripper)
buffAdd[buffPos] = posGripper | 0x5000;
buffPos++;
buffAdd[buffPos - 1] = buffAdd[buffPos - 1] | 0x6000;
for (int i = 0; i < buffPos; i++)
buff[recPos + i] = buffAdd[i];
recPos += buffPos;
command = "Manual";
printPos = 0;
if (play)
command = "Play";
printPos = playPos;
else if (record)
command = "Record";
printPos = recPos;
Serial.print(command);
Serial.print("\t");
Serial.print(printPos);
Serial.print("\t");
Serial.print(posBase);
Serial.print("\t");
Serial.print(posShoulder);
Serial.print("\t");
Serial.print(posElbow);
Serial.print("\t");
Serial.print(posForeArm);
Serial.print("\t");
Serial.print(posWrist);
Serial.print("\t");
Serial.print(posGripper);
Serial.print("\t");
Serial.print(record);
Serial.print("\t");
Serial.print(play);
lastBase = posBase;
lastShoulder = posShoulder;
lastElbow = posElbow;
lastForeArm = posForeArm;
lastWrist = posWrist;
lastGripper = posGripper;
if ( repeatePlaying)
ledLight = !ledLight;
if (ledLight)
ledLight = false;
if (record)
ledLight = true;
digitalWrite(pinLedRecord, ledLight);
delay(50);
void PrintBuffer()
for (int i = 0; i < recPos; i++)
int data = buff[i];
bool endOfData = data & 0x4000;
Serial.print("Servo=");
Serial.print(servoNumber);
Serial.print("\tAngle=");
Serial.print(angle);
Serial.print("\tEnd=");
Serial.print(endOfData);
Serial.print("\tData=");
Serial.print(data, BIN);
void StartPosition()
int angleBase = servoBase.read();
int angleShoulder = servoShoulder.read();
int angleElbow = servoElbow.read();
int angleForeArm = servoForeArm.read();
int angleWrist = servoWrist.read();
int angleGripper = servoGripper.read();
Serial.print(angleBase);
Serial.print("\t");
Serial.print(angleShoulder);
Serial.print("\t");
Serial.print(angleElbow);
Serial.print("\t");
Serial.print(angleForeArm);
Serial.print("\t");
Serial.print(angleWrist);
Serial.print("\t");
Serial.print(angleGripper);
Serial.println("\t");
posBase = startBase;
posShoulder = startShoulder;
posElbow = startElbow;
posForeArm = startForeArm;
posWrist = startWrist;
posGripper = startGripper;
[/code]
Thanks.
