Help with arduino ethernet shield and websocket
hi, im trying to get this sketch to work. i have a ethernet wiz5100 with a 4gb sdcard. so far it seems to notice the sdcard is plugged in but i cant get an ip address. ive set static ip addresses properly on the computer im connected to. i used a example ethernet shield sketch and was able to ping my shield just fine but when i load this sketch i cant get anything to work. can anyone help me out thankyou.
// Wave format file transfer demo for Arduino Mega over Ethernet
// Author: Bruno Senzio-Savino Barzellato
// V 1.0
// Notes: Transfer function can be optimized for filename and buffer size input
// December 1, 2016
// So far no data for this, decided to upload it for people that might consider this
// useful :)
//Using SdFat library
#include <SdFat.h>
SdFat sd;
#include <SPI.h>
#include <Ethernet2.h>
// SD chip select pin
const uint8_t chipSelect = 53; //Connect SD Card to pins 50, 51, 52 and 53
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10,0xCA,0x90 };
IPAddress server(10, 10, 6, 93); //SERVER IP ADDRESS
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(10,10,4,15); //ARDUINO IP ADDRESS
// Initialize the Ethernet client library
// with the IP address and port of the server
EthernetClient client;
int localport =19126;
// print stream
ArduinoOutStream cout(Serial);
// store error strings in flash memory
#define error(s) sd.errorHalt_P(PSTR(s))
void ftransfer() {
  char rbuffer[1024]; //Chunk can be increased to bigger sizes, be careful about memory!!
  char c;
  int n;
  // open test file
  SdFile rdfile("test.wav", O_READ); // <--- Name of file to be transfered
  //Obtain file size
  uint32_t fsize;
  fsize = rdfile.fileSize() - rdfile.curPosition();
  Serial.println(fsize);
  // check for open error
  if (!rdfile.isOpen()) error("File could not be opened, check configuration...");
    // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  Serial.println("Connecting to server for transfer...");
 Serial.println(Ethernet.localIP());
  // if you get a connection, report back via serial:
  if (client.connect(server, localport)) {
    Serial.println("Connected");
  while ((n = rdfile.fgets(rbuffer, sizeof(rbuffer))) > 0) {
       client.write(rbuffer, sizeof(rbuffer)-1);
    client.stop();
  else {
    // No response from server reply
    Serial.println("No server available");
void setup(void) {
  //Allow communications for SD Card ant Ethernet Shield
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  while (!Serial) {}  // Wait for Leonardo
  cout << PSTR("Type any character to start\n");
  while (Serial.read() <= 0) {}
  delay(400);  // catch Due reset problem
  // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
  // breadboards.  use SPI_FULL_SPEED for better performance.
  if (!sd.begin(chipSelect, SPI_FULL_SPEED)) sd.initErrorHalt();
  ftransfer();
  cout << PSTR("\nDone\n");
void loop(void) {}
also heres a link to the github im using the sketch from
what im trying to do is take a reading from a dht sensor and save the value to a txt file on the ethernet shield sdcard. then use the python tool in the link to get the file from the arduino. but im not having any luck making it work at all. the serial screen prints as if the baud rate was off but its not. please help me thankyou
Have you checked your serial port configuration. The Ethernet shield and Arduino Mega might be using the same port in common.
I remember I had to check the serial pinout configuration to avoid problems.
Hope this works.
P.S. Also check the Ethernet shield version.
I think this code was for version 2.
