I posted another note in the forum but received no answer!! I am hoping to get some help with my project, your help is very much appreciated.
I have three stepper motors connected to an Arduino Mega 2560 using three SN754410 H-Bridges. I have attached pictures (sorry for the busy looking background and too many wires, in advance).
I have also got an external power supply with 12VDC and 3A output; since I realized each stepper draws 0.4A current per phase (not sure what this means though). I have connected the outputs of the H-Bridges (from 4 wire steppers) to pins:
0 (RX), 1 (TX), 2, 3, ..., 9, 10, 11.
First of all is this setup correct?
Second, is there like a sample code for multiple steppers so I can test them to sweep back and forth?
Hi, okay on the pics, but I think a circuit diagram, either CAD or pic of hand drawn effort would help.
I think you also need to keep away from your rx/tx pins as they are part of the programming/ serial i/o.
I would appreciate your help. Am I connecting to wrong pins to Arduino? Am I drawing too much current?? As you can see both the "ON" green and "L" yellow LEDs are lighting!! why is that?
Hi, sorry but to get this far with your project you must have drawn or followed a circuit diagram.
If not, then draw a diagram from what you have, these pictures show the myriad of wires needed to connect to the bridges, but not how you have done it.
Please a diagram, CAD or picture of hand drawn circuit.
Thanks for your efforts so far, however its your project and you know all about it, we don't which makes you miles ahead in understanding the system.
Have you tried the sketch, if you want the circuit checked before you try it, then a circuit diagram is essential.
