Hey everyone,
I'm running into some issues with my Arduino Pro Micro. I'm trying to get it to constantly read inputs from six capacitive touch buttons I've made using iron rings (1.2mm thick) and 1M ohm resistors for each button. However, it seems to only register the touches once every second, instead of continuously.
The project is meant to be a macropad with an OLED SSD1306 display, 6 capacitive touch buttons, and a 10k potentiometer.
Does anyone have any ideas on how to fix this or improve the reading speed?
Thanks in advance!
#include <CapacitiveSensor.h>
// Define the capacitive sensors with the specified wiring
CapacitiveSensor touchSensor1 = CapacitiveSensor(4, 5); // Sensor 1: Pin 4 and 5
CapacitiveSensor touchSensor2 = CapacitiveSensor(6, 7); // Sensor 2: Pin 6 and 7
CapacitiveSensor touchSensor3 = CapacitiveSensor(8, 9); // Sensor 3: Pin 8 and 9
CapacitiveSensor touchSensor4 = CapacitiveSensor(A2, 10); // Sensor 4: Pin A2 and 10
CapacitiveSensor touchSensor5 = CapacitiveSensor(A1, 15); // Sensor 5: Pin A1 and 15
CapacitiveSensor touchSensor6 = CapacitiveSensor(A0, 14); // Sensor 6: Pin A0 and 14
// Threshold values for each sensor
const int threshold1 = 4;
const int threshold2 = 15; // Example threshold for Sensor 2
const int threshold3 = 30; // Example threshold for Sensor 3
const int threshold4 = 25; // Example threshold for Sensor 4
const int threshold5 = 10; // Example threshold for Sensor 5
const int threshold6 = 35; // Example threshold for Sensor 6
Serial.begin(2000000); // Baud rate for faster communication
// Optional: Re-enable auto-calibration with an interval
touchSensor1.set_CS_AutocaL_Millis(5000); // Recalibrate every 5 seconds
touchSensor2.set_CS_AutocaL_Millis(5000);
touchSensor3.set_CS_AutocaL_Millis(5000);
touchSensor4.set_CS_AutocaL_Millis(5000);
touchSensor5.set_CS_AutocaL_Millis(5000);
touchSensor6.set_CS_AutocaL_Millis(5000);
// Read the values from each sensor
long sensorValue1 = touchSensor1.capacitiveSensor(50); // More sensitive
long sensorValue2 = touchSensor2.capacitiveSensor(50);
long sensorValue3 = touchSensor3.capacitiveSensor(50);
long sensorValue4 = touchSensor4.capacitiveSensor(50);
long sensorValue5 = touchSensor5.capacitiveSensor(50);
long sensorValue6 = touchSensor6.capacitiveSensor(50);
// Check if each sensor's value exceeds its respective threshold and print a message
if (sensorValue1 > threshold1) {
Serial.println("Sensor 1 activated!");
if (sensorValue2 > threshold2) {
Serial.println("Sensor 2 activated!");
if (sensorValue3 > threshold3) {
Serial.println("Sensor 3 activated!");
if (sensorValue4 > threshold4) {
Serial.println("Sensor 4 activated!");
if (sensorValue5 > threshold5) {
Serial.println("Sensor 5 activated!");
if (sensorValue6 > threshold6) {
Serial.println("Sensor 6 activated!");
// Continuously loop without delay
