Help with Arduino/Processing
Hello, I’m trying to use Processing with Arduino. The code in Arduino is “StandarFirmdata”. And this is the code in processing (is one of the examples):
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
color off = color(4, 79, 111);
color on = color(84, 145, 158);
int values = { Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW,
Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW,
Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW, Arduino.LOW };
size(470, 200);
println(Arduino.list());
arduino = new Arduino(this, Arduino.list()[0], 57600); //I have problems in this line.
for (int i = 0; i <= 13; i++)
arduino.pinMode(i, Arduino.OUTPUT);
void draw() {
background(off);
stroke(on);
for (int i = 0; i <= 13; i++) {
if (values == Arduino.HIGH)
  • fill(on);*
  • else*
  • fill(off);*
_ rect(420 - i * 30, 30, 20, 20);_
    void mousePressed()
  • int pin = (450 - mouseX) / 30;*
  • if (values[pin] == Arduino.LOW) {*
  • arduino.digitalWrite(pin, Arduino.HIGH);*
  • values[pin] = Arduino.HIGH;*
  • } else {*
  • arduino.digitalWrite(pin, Arduino.LOW);*
  • values[pin] = Arduino.LOW;*
    }[/quote]
    When I click run in Processing I get this:
    > Stable Library
    > Native lib Version = RXTX-2.1-7
    > Java lib Version = RXTX-2.1-7
    > [0] “/dev/ttyACM0”
    > [1] “/dev/ttyS0”
    > Exception in thread “Animation Thread” java.lang.IllegalAccessError: tried to access class processing.core.PApplet$RegisteredMethods from class cc.arduino.Arduino$SerialProxy
    > at cc.arduino.Arduino$SerialProxy.(Arduino.java:119)
    > at cc.arduino.Arduino.(Arduino.java:168)
    > at arduino_output.setup(arduino_output.java:41)
    > at processing.core.PApplet.handleDraw(PApplet.java:2095)
    > at processing.core.PGraphicsJava2D.requestDraw(PGraphicsJava2D.java:197)
    > at processing.core.PApplet.run(PApplet.java:1998)
    > at java.lang.Thread.run(Thread.java:662)
    My O.S is Linux Ubuntu 12.04 but I have the same problem on Windows7, please help me!
Hi, we faced the same problem a couple of days ago. I just uploaded a fixed version of the library to https://github.com/pardo-bsso/processing-arduino . Let me know how it works for you.
Thanks pardo_bsso - I had that problem and you had the solution. :)
Hello
I have follow the intructions from http://playground.arduino.cc/interfacing/processing to install "Processing" and now I have exactly the same problem as Euromas tells trying to communicate with Arduino
I have tried the Pardo,s solution , but it does not work for me , the message of error is practically the same as Euromas
Any advice?
Thanks pardo_bsso, I had the same problem with Processing 2 on Win XP and your library fixed it. Now I can use Processing 2 with the Arduino.
Thanks.
Thanks pardo_bsso!
