Help with Arduino project
Hi, I recently posted a project to the project hub. It then told me that it was being reviewed. Then a few weeks later it said that my project needs revision. The email said "Topic already presented multiple times" So I changed the title thinking that that is the problem. Then I pressed save changes. How do I make it go back into the review process. Was saving the changes all I had to do? I'm a 10th grader that is just doing this as a summer project for fun.
Thanks
Grant
Here is the link to my project if it helps. Edit Project | Arduino Project Hub
I dont know if you will be able to view it though. Thanks in advance
I think it's not referring to the title, but the contents. It sounds like, it's rejected because it's nothing new, has already been done multiple times. If it's just for fun, it shouldn't matter much anyway, right?
Would you agree that multiple identical projects don't serve much useful purpose? If they are almost the same, if you see one, you've basically seen them all.
If you're really eager to stick something there, perhaps you need to show something that hasn't been done before.
The link you posted is broken.
@krishna_agarwal has some projects in Project Hub... and maybe some advice for you.
I will be very happy to advice and help someone
That is quite likely to be correct. Did you look carefully through the Project Hub offerings, to see whether you agree?
Thank you all for responding. Now that I look through the project hub, I can see that there is multiple other offerings. When it said topic, I thought that It meant the title. Now I will make some changes and try to make it more unique.
Thank you all so much!!!
