help with arduino rfid
hi
i am trying to make an rfid lock using the code below. the code reads the tag fine, but it won’t run the servo when it detects the correct card.
int  val = 0;
char code[10]; //stores the code from card
int bytesread = 0;
char correctCode[] = {"0F03028CF8"}; // correct code that should turn servo
#include <Servo.h>
Servo myservo;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW);                  // Activate the RFID reader
myservo.attach (9);
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);         // print the TAG code
        if (code == correctCode) {
        myservo.write (180);
       delay (1000);
      myservo.write (90);
      bytesread = 0;
      digitalWrite(2, HIGH);                  // deactivate the RFID reader for a moment so it will not flood
           delay(1500);                       // wait for a bit
and when i add the word HEX, it turns the servo after reading any card:
if (code == correctCode, HEX)
please help.
thanks
code is the address of a block of memory. correctCode is the address of another block of memory. Do you really expect them to match?
correctCode is a string. To compare strings, you use the strcmp() function. Unfortunately, you can't do that, because code is NOT a string. code is an array of chars. You could make it a string, if you properly NULL terminated it.
thank yo so much Paul. It worked!! sorry about the multiple threads. i am new to forums. sorry for any annoyance.
