Help with Arduino WebServer
I am trying to create a webserver with my arduino uno to allow remote control of devices, right now I am working with a 4 led prototype. The issue am having is that whenever I turn first led on, the others don’t respond. The second one when turned on just flashes and does not actually stay on. Any help will be appreciated. I have posted my code below:
#include <SPI.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
//Ethernet Shield MAC address
byte mac={0x90,0xA2,0xDA,0x0D,0x9D,0xBB};
//Board IP Address
byte ip={192,168,1,5};
byte gateway={192,168,1,1};
byte subnet={255,255,255,0};
//Initialize ethernet server library
//Port 80 is default port for HTTP
EthernetServer server(80);
int Room1=2;
int Room2=3;
int Room3=5;
int Room4=6;
//int TempPin
String readString = String(30);
//led status flags
boolean LED1_ON=false;
boolean LED2_ON=false;
boolean LED3_ON=false;
boolean LED4_ON=false;
void setup(){
//start ethernet connection and server
Ethernet.begin(mac,ip,gateway,subnet);
server.begin();
pinMode(Room1,OUTPUT);
pinMode(Room2,OUTPUT);
pinMode(Room3,OUTPUT);
pinMode(Room4,OUTPUT);
//Start Serial communication and initiailize baud rate
void loop(){
//digitalWrite(Room4,HIGH);
//listen for incoming clients
if(client){
while(client.connected()){
if(client.available()){
char c = client.read();
//read each char of HTTP request
if(readString.length()<30){
//store characters to string
readString +=c;//replaces readString.append(c);
//print char to serial port
Serial.print(c);
//if HTTP request has ended
if(c==’\n’){
Serial.println("");
Serial.println(readString);
Serial.println("");
int L1=readString.indexOf(“L1=”);
int L2=readString.indexOf(“L2=”);
int L3=readString.indexOf(“L3=”);
int L4=readString.indexOf(“L4=”);
Serial.print(“L1=position:”);
Serial.println(L1);
Serial.print(“L2=position:”);
Serial.println(L2);
Serial.print(“L3=position:”);
Serial.println(L3);
Serial.print(“L4=position:”);
Serial.println(L4);
if(readString.indexOf("?")<0)
//skip everything
//lets check if LED is lit
if(readString.indexOf(“L1=1”)>0)
//if(L1 > 1){
//if(readString.substring(L1,(L1+3))==“L1=1”)
digitalWrite(Room1,HIGH);
LED1_ON=true;
else{ //if(readString.substring(L1,(L1+3))==“L1=0”){
digitalWrite(Room1,LOW);
LED1_ON=false;
if(readString.indexOf(“L2=1”)>0)
// if(L2 > 0){
//if(readString.substring(L2,(L2+3))==“L2=1”)
digitalWrite(Room2,HIGH);
LED2_ON=true;
else{ //if(readString.substring(L2,(L2+3))==“L2=0”){
digitalWrite(Room2,LOW);
LED2_ON=false;
//if(L3 > 0){
//if(readString.substring(L3,(L3+3))==“L3=1”)
if(readString.indexOf(“L3=1”)>0)
digitalWrite(Room3,HIGH);
LED3_ON=true;
else {//if(readString.substring(L3,(L3+3))==“L3=0”){
digitalWrite(Room3,LOW);
LED3_ON=false;
if(readString.indexOf(“L4=1)”)>0)
// if(L4 > 0){
// if(readString.substring(L4,(L4+3))==“L4=1”)
LED4_ON=true;
else {//if(readString.substring(L4,(L4+3))==“L4=0”){
digitalWrite(Room4,LOW);
LED4_ON=false;
//now output HTML data starting with standard header
//standard http request header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
//client.println(“Connection: close”);
client.println();
// add a meta refresh tag, so the browser pulls again every 5 seconds:
//client.println("<meta http-equiv=“refresh” content=“5”>");
//set background to white
client.print("");
//Send first heading
client.println("<font color='blue’
Home Control System.
client.println("
client.println("
//controlling LED’s
client.println(“
LED CONTROL
client.println("");
client.println("LED1 ON
LED1 OFF
client.println("LED2 ON
LED2 OFF
client.println("LED3 ON
LED3 OFF
client.println(“LED4 ON
LED4 OFF
client.println(””);
client.println("
//client.print(”<font size='5[ch8242]>LED status: ")
//printing LED status
client.print("<font size='5[ch8242]>LED1 status: “);
if (LED1_ON)
client.println(”<font color=‘green’ size='5[ch8242]>ON");
client.println("<font color=‘grey’ size='5[ch8242]>OFF");
client.println("
client.println(”
//client.println("
//client.println("");
//clearing string for next read
client.print("<font size='5[ch8242]>LED2 status: “);
if (LED2_ON)
client.println("
client.println("
//client.println("
client.print("<font size='5[ch8242]>LED3 status: “);
if (LED3_ON)
client.println("
client.println(”
//client.println("
client.print("<font size='5[ch8242>LED4 status: “);
if (LED4_ON)
client.println("
client.println(”
//client.println("
client.println("");
readString="";
//stopping client
client.stop();
You have this code for LED 1:
  if(readString.indexOf("?")<0) {
    //skip everything
    if(readString.indexOf("L1=1")>0) {
      LED1_ON=true;
    else {
      LED1_ON=false;
And this code for LED 2:
  if(readString.indexOf("L2=1")>0)
    LED2_ON=true;
  else{
    LED2_ON=false;
It looks like you might have intended the LED 2 code to ALSO be part of the ELSE clause in that initial IF statement. If you want more than one statement in an ELSE clause you need to put brackets around the block of statements to make them act as one statement.
Thank You. That was my issue. I really appreciate the help!!!
