im pretty new to arduino, so far iv'e experimented with the basics, LEDs, servos, analog inputs even the odd LCD display! proud of myself . Now i want to move on to my first propper project, and i thought a simple robot would be fun.
for a drive system i thought continuous rotation servos would be easier to use than DC motors as i wouldent have to use a motor controller. and in terms of sensors im gona start with the sharp IR range sensors.
Q's:
are continuous rotation servos compatable with the standard servo library?
i looked at the spec sheets for the IR range finders, they say the output voltage is -0.3 to 0.3, this seemed kinda low to me, will i just be able to use the analogRed() function with this sensor? here is the spec sheet (i will post the link below)
all other sugestions will be apriciated!
thanks!
