I want to store some analog pin numbers in an array. is there anyway to do this?
of course. how about giving it a try?
There may be a hidden question here ... why would you want to store analog PIN numbers .....
hammy:
For the same reason that you want to store digital pin numbers in arrays?
The analog pins A0 - A5 (on Arduino Uno) can also be called using IDE pin nunbers 14 - 19 respectively. Reference image is attached. Then you can do the same as digital pins:
const uint8_t analogPins[6] = {14, 15, 16, 17, 18, 19};
const uint8_t pinToRead = 0;//analog pin to read 0=A0, 1=A1,...
void setup(){
//open serial
delay(250);
//print analog read w/50ms delay
while(1){
Serial.println(analogRead(analogPins[pinToRead]));
delay(50);
void loop(){}
Luckyfish13:
That will break compatibility. If you want to move from an Uno to a Mega, it will no longer work with the given numbers while the below will.
const uint8_t analogPins[6] = {A0, A1, A2, A3, A4, A5};
