Here's the sketch.
* @file Samco_2.0_4IR.ino
* @brief 10 Button Light Gun sketch for 4 LED setup
* @n INO file for Samco Light Gun 4 LED setup
* @copyright Samco, https://github.com/samuelballantyne, June 2020
* @copyright GNU Lesser General Public License
* @author [Sam Ballantyne](samuelballantyne@hotmail.com)
* @version V1.0
* @date 2020
#include <HID.h> // Load libraries
#include <Wire.h>
#include <Keyboard.h>
#include <AbsMouse.h>
#include <DFRobotIRPosition.h>
#include <Samco.h>
// Tigger is set to LEFT_MOUSE, A Button is set to RIGHT_MOUSE & B Button is set to MIDDLE_MOUSE
char _upKey = KEY_UP_ARROW;
char _downKey = KEY_DOWN_ARROW;
char _leftKey = KEY_LEFT_ARROW;
char _rightKey = KEY_RIGHT_ARROW;
char _startKey = KEY_RETURN;
char _selectKey = KEY_BACKSPACE;
int xCenter = 512; // If second calibration seems more accurate you can replace these values with the altered camera center values from serial monitor
int yCenter = 368;
int finalX; // Values after tilt correction
int finalY;
int xLeft; // Stored calibration points
int yTop;
int xRight;
int yBottom;
int MoveXAxis; // Unconstrained mouse postion
int MoveYAxis;
int conMoveXAxis; // Constrained mouse postion
int conMoveYAxis;
int count = 4; // Set intial count
int _tiggerPin = 7; // Label Pin to buttons
int _upPin = 11;
int _downPin = 9;
int _leftPin = 10;
int _rightPin = 12;
int _APin = A1;
int _BPin = A0;
int _startPin = A2;
int _selectPin = A3;
int _reloadPin = 13;
int _pedalPin = 5;
int buttonState1 = 0;
int lastButtonState1 = 0;
int buttonState2 = 0;
int lastButtonState2 = 0;
int buttonState3 = 0;
int lastButtonState3 = 0;
int buttonState4 = 0;
int lastButtonState4 = 0;
int buttonState5 = 0;
int lastButtonState5 = 0;
int buttonState6 = 0;
int lastButtonState6 = 0;
int buttonState7 = 0;
int lastButtonState7 = 0;
int buttonState8 = 0;
int lastButtonState8 = 0;
int buttonState9 = 0;
int lastButtonState9 = 0;
int buttonState10 = 0;
int lastButtonState10 = 0;
int buttonState11 = 0;
int lastButtonState11 = 0;
DFRobotIRPosition myDFRobotIRPosition;
Samco mySamco;
int res_x = 1023; // UPDATE: These values do not need to change
int res_y = 768; // UPDATE: These values do not need to change
myDFRobotIRPosition.begin();
Serial.begin(9600); // For debugging (make sure your serial monitor has the same baud rate)
AbsMouse.init(res_x, res_y);
pinMode(_tiggerPin, INPUT_PULLUP); // Set pin modes
pinMode(_upPin, INPUT_PULLUP);
pinMode(_downPin, INPUT_PULLUP);
pinMode(_leftPin, INPUT_PULLUP);
pinMode(_rightPin, INPUT_PULLUP); // Set pin modes
pinMode(_APin, INPUT_PULLUP);
pinMode(_BPin, INPUT_PULLUP);
pinMode(_startPin, INPUT_PULLUP);
pinMode(_selectPin, INPUT_PULLUP);
pinMode(_reloadPin, INPUT_PULLUP);
pinMode(_pedalPin, INPUT_PULLUP);
AbsMouse.move((res_x / 2), (res_y / 2)); // Set mouse position to centre of the screen
if (count > 3) {
getPosition();
mouseButtons();
PrintResults();
go();
/* ------------------ START/PAUSE MOUSE ---------------------- */
else if (count > 2 ) {
skip();
getPosition();
mouseCount();
mouseButtons();
PrintResults();
/* ---------------------- TOP LEFT --------------------------- */
else if (count > 1 ) {
AbsMouse.move(300, 200);
mouseCount();
getPosition();
xLeft = finalX;
yTop = finalY;
PrintResults();
/* -------------------- BOTTOM RIGHT ------------------------- */
else if (count > 0 ) {
AbsMouse.move((res_x - 300), (res_y - 200));
mouseCount();
getPosition();
xRight = finalX;
yBottom = finalY;
xCenter = ((xRight - xLeft) / 2) + min(xRight, xLeft);
yCenter = ((yBottom - yTop) / 2) + min(yBottom, yTop);
PrintResults();
/* ---------------------- LET'S GO --------------------------- */
else {
AbsMouse.move(conMoveXAxis, conMoveYAxis);
mouseButtons();
getPosition();
MoveXAxis = map (finalX, xLeft, xRight, 300, (res_x - 300));
MoveYAxis = map (finalY, yTop, yBottom, 200, (res_y - 200));
conMoveXAxis = constrain (MoveXAxis, 0, res_x);
conMoveYAxis = constrain (MoveYAxis, 0, res_y);
PrintResults();
reset();
/* --------------------------- METHODS ------------------------- */
void getPosition() { // Get tilt adjusted position from IR postioning camera
myDFRobotIRPosition.requestPosition();
if (myDFRobotIRPosition.available()) {
mySamco.begin(myDFRobotIRPosition.readX(0), myDFRobotIRPosition.readY(0), myDFRobotIRPosition.readX(1), myDFRobotIRPosition.readY(1),myDFRobotIRPosition.readX(2), myDFRobotIRPosition.readY(2),myDFRobotIRPosition.readX(3), myDFRobotIRPosition.readY(3), xCenter, yCenter);
finalX = mySamco.X();
finalY = mySamco.Y();
else {
Serial.println("Device not available!");
void go() { // Setup Start Calibration Button
buttonState1 = digitalRead(_reloadPin);
if (buttonState1 != lastButtonState1) {
if (buttonState1 == LOW) {
count--;
else { // do nothing
delay(50);
lastButtonState1 = buttonState1;
void mouseButtons() { // Setup Left, Right & Middle Mouse buttons
buttonState2 = digitalRead(_tiggerPin);
buttonState3 = digitalRead(_upPin);
buttonState4 = digitalRead(_downPin);
buttonState5 = digitalRead(_leftPin);
buttonState6 = digitalRead(_rightPin);
buttonState7 = digitalRead(_APin);
buttonState8 = digitalRead(_BPin);
buttonState9 = digitalRead(_startPin);
buttonState10 = digitalRead(_selectPin);
buttonState11 = digitalRead(_pedalPin);
if (buttonState2 != lastButtonState2) {
if (buttonState2 == LOW) {
AbsMouse.press(MOUSE_LEFT);
else {
AbsMouse.release(MOUSE_LEFT);
delay(10);
if (buttonState3 != lastButtonState3) {
if (buttonState3 == LOW) {
Keyboard.press(_upKey);
else {
Keyboard.release(_upKey);
delay(10);
if (buttonState4 != lastButtonState4) {
if (buttonState4 == LOW) {
Keyboard.press(_downKey);
else {
Keyboard.release(_downKey);
delay(10);
if (buttonState5 != lastButtonState5) {
if (buttonState5 == LOW) {
Keyboard.press(_leftKey);
else {
Keyboard.release(_leftKey);
delay(10);
if (buttonState6 != lastButtonState6) {
if (buttonState6 == LOW) {
Keyboard.press(_rightKey);
else {
Keyboard.release(_rightKey);
delay(10);
if (buttonState7 != lastButtonState7) {
if (buttonState7 == LOW) {
AbsMouse.press(MOUSE_RIGHT);
else {
AbsMouse.release(MOUSE_RIGHT);
delay(10);
if (buttonState8 != lastButtonState8) {
if (buttonState8 == LOW) {
AbsMouse.press(MOUSE_MIDDLE);
else {
AbsMouse.release(MOUSE_MIDDLE);
delay(10);
if (buttonState9 != lastButtonState9) {
if (buttonState9 == LOW) {
Keyboard.press(_selectKey);
else {
Keyboard.release(_selectKey);
delay(10);
if (buttonState10 != lastButtonState10) {
if (buttonState10 == LOW) {
Keyboard.press(_startKey);
else {
Keyboard.release(_startKey);
delay(10);
if (buttonState11 != lastButtonState11) {
if (buttonState11 == LOW) {
else {
delay(10);
lastButtonState2 = buttonState2;
lastButtonState3 = buttonState3;
lastButtonState4 = buttonState4;
lastButtonState5 = buttonState5;
lastButtonState6 = buttonState6;
lastButtonState7 = buttonState7;
lastButtonState8 = buttonState8;
lastButtonState9 = buttonState9;
lastButtonState10 = buttonState10;
lastButtonState11 = buttonState11;
void mouseCount() { // Set count down on trigger
count--;
delay(10);
void reset() { // Pause/Re-calibrate button
count = 3;
delay(50);
delay(50);
void skip() { // Unpause button
count = 0;
delay(50);
delay(50);
void PrintResults() { // Print results for debugging
Serial.print("RAW: ");
Serial.print(finalX);
Serial.print(", ");
Serial.print(finalY);
Serial.print(" Count: ");
Serial.print(count);
Serial.print(" Calibration: ");
Serial.print(xLeft);
Serial.print(", ");
Serial.print(yTop);
Serial.print(", ");
Serial.print(xRight);
Serial.print(", ");
Serial.print(yBottom);
Serial.print(" Cam Center: x ");
Serial.print(xCenter);
Serial.print(", y ");
Serial.println(yCenter);
Through trial and error and commenting out stuff, I learned that commenting out the mysamco.begin line (215) will allow the sketch to upload. Line 215 references this include samco.h
* @file Samco.h
* @brief Samco Light Gun library for 4 LED setup
* @n Header file for Samco Light Gun 4 LED setup
* @copyright [Samco](http://www.samco.co.nz), 2020
* @version V1.0
* @date 2020
#include "Arduino.h"
#ifndef Samco_h
#define Samco_h
class Samco {
private:
int positionXX[4]; ///< position x.
int positionYY[4]; ///< position y.
int positionX[4];
int positionY[4];
int see[4];
int buff = 50;
int medianY = 768 / 2;
int medianX = 1024 / 2;
int FinalX[4] = {400,623,400,623};
int FinalY[4] = {200,200,568,568};
int xDistTop;
int xDistBottom;
int yDistLeft;
int yDistRight;
float angle;
float angleOffset;
int xx;
int yy;
int i;
int start = 0;
public:
void mapper();
void begin(int x0, int y0, int x1, int y1, int x2, int y2, int x3, int y3, int cx, int cy);
int testX(int index);
int testY(int index);
int testMedianX();
int testMedianY();
int X();
int Y();
#endif
So it would seem that there's some issue passing the variables to the mysamco.begin function, maybe? But I don't know why others wouldn't be having the same problem I am if that's the case.
