Help with battery powered ESP 8266 and Stepper Motor½
Hi Everyone!
I am currently working on a project where i'm attempting to make motorized roller blinds.
I,ve gotten the code to work and set everything up but now i have a issue with how i will power it.
I would like to power it through some sort of battery and i would want it to last for atleast 2-3 months.
I am using a wemos D1 mini as my ESP and 28byj-48 stepper motor with ULN2003 driver.
Ive read about the ESP's Deepsleep mode but it seems as you have to either set a sertain time or reset it for it to wake up.
I've would like to have it in some sort of power saving mode while it doesn not get any input from the app (btw im using blynk as my way of controlling it) and whenever a button is pressed it does the action and then go back to power saving mode.
How would this be accomplished or is there any other way i can get decent battery life with this?
Thanks ahead
Heres the code i use:
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Stepper.h>
const int stepsPerRevolution = 512;  // change this to fit the number of steps per revolution
// for your motor
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "********************************";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "*********";
char pass[] = "********";
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, D1, D3, D2, D4);
  // set the speed at 60 rpm:
  myStepper.setSpeed(60);
  Blynk.begin(auth, ssid, pass); {
  // Wait until connected
void clockwisefull()
  // step one revolution  in one direction:
  Serial.println("clockwise");
  myStepper.step(512);
  delay(30);
void counterclockwisefull()
  Serial.println("counterclockwise");
    myStepper.step(-512);
  delay(30);
   BLYNK_WRITE(V1)
       int b1 = param.asInt();
      // Execute clockwise routine if V1 is pressed in dashboard
      if (b1 == 0)
        clockwisefull();
      else if (b1 == 1)
        counterclockwisefull();
Unfortunately you are out of luck. The sleep modes shut down the Wifi so your system will not be able to listen for commands while sleeping. You may also find it takes a lot of power to wake up and re-establish the connection to your router. All of the "run your esp8266 for a year on a single battery" tutorials involve a device that wakes up every few minutes, sends in a data point then goes back to sleep again without having to stay awake and listen.
However I would have thought that the main power draw is the motor so your batteries will rapidly run out anyway.
The complete guide to all the power-saving modes can be found at https://www.espressif.com/sites/default/files/9b-esp8266-low_power_solutions_en_0.pdf
