help with beginner arduino project
Objective: Develop a program to perform the following tasks:
  • Measure a variable DC voltage ranging from 0 to 9 volts.
  • The input voltage to the microprocessor cannot go above 3 VDC.
  • The DC voltage will be displayed in 1 volt increments on the 9 LEDs.
im assuming im gonna need a lot off if statements but its asking for leds to be displayed every 1 volte but 3 volt is the limit..
Id appreciate some advice on where to start or go about doing this
Divide the measured voltage by 3 using a voltage divider.
A ladder of 9 “if’s” sounds like possible to run well.
inVolt = 3 * analogRead(inVoltPin);//compensate for divider
if(inVolt <1023/9) digitalWrite(ledPin1, HIGH);
else if(inVolt <2*1023/9) digitalWrite(ledPin2, HIGH);
else if(inVolt <3*1023/9) digitalWrite(ledPin3, HIGH);
else if(inVolt <8*1023/9) digitalWrite(ledPin8, HIGH);
else digitalWrite(ledPin9, HIGH);
the code you gave me wouldthat be a good code to replicate 9 times and change according to pin/action?
I think so but You need to make declarations, define the input pin and output pins in Setup(). That snippet of code belongs to loop().
A more elegant solution might be to put the pin numbers of the LEDs in an array and light the first n of them in a for loop, where n is the measured voltage.
wildbill:
So how do i set up pins 2-10 as an array to give "power" to certain LEDs when voltage is read from either 9v battery or a Dc voltage regulator (variable one)
Actually, if you plan to use sequential pins, you won't even need the array, just a for loop than runs from 2 to 10 and a little math.
so what use 3 Leds per pin? and base the power of LED on the amount of voltage given ?
or just all pins ?
int LED1 2;
int LED2 3;
int LED3 4;
int LED4 5;
int LED5 6;
int LED6 7;
int LED7 8;
int LED8 9;
and set in motion each one to power at a certain voltage?
You can use a switch-case to operate the LEDs as shown here
Beginners: using the switch - case statement
What model controller are you using?
