help with Bi directional PID motor control
HI,
I'm trying to make a motor that i can control and regulate position based on feedback from a potentiometer. The program gets it's PID target value from another potentiometer. essentially it's a servo but with a 12V motor.
any help would be greatly appreciated, I posted the code below:
Thanks,
Rhetkun
ps. for PID control i used the new PID library 1.0.1 =)
#include <PID_v1.h>
#define forward 3
#define reverse 5
#define potpin 0
#define servopot 1
double Setpoint, Input, Output;
PID myPID(&Input, &Output, &Setpoint,2,5,1, DIRECT);
pinMode(forward,OUTPUT);
pinMode(reverse,OUTPUT);
pinMode(potpin,INPUT);
pinMode(servopot,INPUT);
Setpoint = map(analogRead(potpin),0,1023,0,220);
Input = map(analogRead(servopot),0,1023,0,180);
myPID.SetMode(AUTOMATIC);
myPID.SetSampleTime(10);
myPID.Compute();
if(Input<Setpoint)
digitalWrite(reverse,LOW);
analogWrite(forward,Output);
if(Input>Setpoint)
digitalWrite(forward,LOW);
analogWrite(reverse,Output);
Any particular reason you're using PID, instead of a window comparator logic design (do you need the absolute accuracy - note that this really only applies if you are using accurate/tight mechanical linkage between the motor and potentiometer, and your potentiometer is a high-tolerance/accuracy device)? Have you seen this thread?
http://arduino.cc/forum/index.php/topic,60163.0.html
Depending on your application, PID might just be overkill (certainly standard r/c servos don't use PID)...
hey thanks man, I tweaked my code to accomodate window comparator logic and it works great!
I owe you......
Cheers
