Help with bitwise
Hi All,
I need some help converting a long 2711790500 (0xA1A2A3A4) to 2762187425 (0xA4A3A3A1)
Here is the code I am trying...
  unsigned long n = 2711790500;
  byte buf[4];
  buf[0] = byte(n);
  buf[1] = byte(n >> 8);
  buf[2] = byte(n >> 16);
  buf[3] = byte(n  >> 24);
  unsigned long value = (unsigned long) (buf[0] << 24) | (unsigned long) (buf[1] << 16) | (unsigned long) (buf[2] << 8) | (unsigned long) buf[3];
  Serial.println(value, HEX);
This seems to give me an output of 0xFFFFA2A1.
I'm struggling to see what I'm doing wrong can anybody help?
Thanks
Try ((unsigned long)buf[0] << 24) etc.
Did you consider to use the union?
Why make it so complicated?
uint32_t x = 2711790500UL;
x = 2762187425UL;
Regards,
Ray L.
Ah yes "UL", sry. :-[
Look at this or even this.
Hi All,
Thanks for all of your help.
In the end I went with this...
uint32_t byteReverse(uint32_t value)
    uint32_t result = 0;
    result |= (value & 0x000000FF) << 24;
    result |= (value & 0x0000FF00) << 8;
    result |= (value & 0x00FF0000) >> 8;
    result |= (value & 0xFF000000) >> 24;
    return result;
Thanks again
Richard
