Help with Bluetooth exception?
I’m using a Processing user interface to control a robot via bluetooth. I get “Exception in thread “Animation Thread” java.lang.NullPointerException
at GUI$Bluetooth.checkTestButtonClick(GUI.java:231)
at GUI.mousePressed(GUI.java:101)
at processing.core.PApplet.handleMouseEvent(PApplet.java:1607)
at processing.core.PApplet.dequeueMouseEvents(PApplet.java:1544)
at processing.core.PApplet.handleDraw(PApplet.java:1436)
at processing.core.PApplet.run(PApplet.java:1327)
at java.lang.Thread.run(Thread.java:613)”
Note that I only get this error when I click the forward button, not when it is launched.
Line 231 is “void drawBt()”, which is the method that draws everything to be used by thr Bluetooth:
void drawBt() //Draws all things related to bluetooth
    if (testButtonMouseOver)
     fill(0, 102, 153);
     PFont font;
     font = loadFont("BankGothic-Light-20.vlw");
     textFont(font);
     text("Test LED", BLUETOOTH_TEST_BUTTON_Label_X, BLUETOOTH_TEST_BUTTON_Label_Y);
     rect(BLUETOOTH_TEST_BUTTON_X, BLUETOOTH_TEST_BUTTON_Y, STANDARD_BUTTON_WIDTH, STANDARD_BUTTON_HEIGHT); //Draw Bluetooth Test button
     //fill(STANDARD_BUTTON_COLOR); //Fill button
     text("Left", BLUETOOTH_LEFT_BUTTON_LABEL_X, BLUETOOTH_LEFT_BUTTON_LABEL_Y);
     rect(BLUETOOTH_LEFT_BUTTON_X, BLUETOOTH_LEFT_BUTTON_Y, STANDARD_BUTTON_WIDTH, STANDARD_BUTTON_HEIGHT);
     text("Right", BLUETOOTH_RIGHT_BUTTON_LABEL_X, BLUETOOTH_RIGHT_BUTTON_LABEL_Y);
     rect(BLUETOOTH_RIGHT_BUTTON_X, BLUETOOTH_RIGHT_BUTTON_Y, STANDARD_BUTTON_WIDTH, STANDARD_BUTTON_HEIGHT);
     text("Forward", BLUETOOTH_FORWARD_BUTTON_LABEL_X, BLUETOOTH_FORWARD_BUTTON_LABEL_Y);
     rect(BLUETOOTH_FORWARD_BUTTON_X, BLUETOOTH_FORWARD_BUTTON_Y, STANDARD_BUTTON_WIDTH, STANDARD_BUTTON_HEIGHT);
     // DRAW RADAR STUFF
     //ellipse(RADAR_X, RADAR_Y, RADAR_WIDTH, RADAR_HEIGHT);
     //fill(0);
     //ellipse(RADAR_X, RADAR_Y, RADAR_CENTER_HEIGHT, RADAR_CENTER_WIDTH);
     //fill(255);
     //r.draw();
Here’s a sample from the checkMouseClick() method:
void checkTestButtonClick()
    //println("Button Click Tested!");
    if (mouseX > BLUETOOTH_TEST_BUTTON_X && mouseX < BLUETOOTH_TEST_BUTTON_X + STANDARD_BUTTON_WIDTH &&
    mouseY > BLUETOOTH_TEST_BUTTON_Y && mouseY <  BLUETOOTH_TEST_BUTTON_Y + STANDARD_BUTTON_HEIGHT)
      println("Test Button CLicked!");
      myPort.write('A'); // Sends 'A' char to on board computer to be processed and interpreted
      delay(TIME_BEFORE_RESET);
      myPort.write('Z');
This is the robot’s code:
char val; // Data received from the serial port
int ledPin = 13; // Set the pin to digital I/O 4
int leftMotorPin = 8;
int rightMotorPin = 9;
pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
Serial.begin(115200); // Start serial communication at 9600 bps
//Declare the purpose and use of pin 8 and 9 for motors (output)
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
if (Serial.available()) { // If data is available to read,
val = Serial.read(); // read it and store it in val
if (val == 'A') { // If A was received
digitalWrite(ledPin, HIGH); // turn the LED on
delay(400);
digitalWrite(ledPin, LOW); // turn the LED on
else {
digitalWrite(ledPin, LOW); // Otherwise turn it OFF
if (val == 'B') //If Left Motor activated
  digitalWrite(leftMotorPin, HIGH);
  digitalWrite(leftMotorPin, LOW);
if (val == 'C') //If right Motor activated
  digitalWrite(rightMotorPin, HIGH);
  digitalWrite(rightMotorPin, LOW);
if (val == 'D') //If right and left Motor activated
if (val == 'Z') //If right and left Motor activated
delay(10); // Wait 100 milliseconds for next reading
The bluetooth blinks red, showing that it is on, however it does not turn green when GUI is launched. This means that a Bluetooth connection was never established. Can someone help me figure out why?
The only thing I see in the drawBt function that might throw an exception is this:
Does this file actually exist? Is it in the right place?
How does the drawBt function get called? I didn’t see anything in the checkTestButtonClick that would call it.
Yes, that font is accessed correctly and is in the correct file. Draw bt is called in the beginning:
  //Part 1 - create window
  createWindow();
  //Part 2 - create serial port for hardware connection
  initializeSerial();
  //Part 3 - draw all buttons, etc. related to bluetooth
  drawBluetooth();
  //Part 4 - check if mouse is clicked
  //Part 5 draw radar
  drawRadar();
void createWindow()
  // Creates window
  size(1200, 700);
void initializeSerial()
  //Print serial data and create myPort, the port used for hardware connection
  println(Serial.list());
  String portName = Serial.list()[0];
void drawBluetooth()
  bt.checkTestButtonMouseOver();
  bt.drawBt();
void drawRadar()
 // r.draw();
void mousePressed()
  //println("Mouse Pressed!");
  bt.checkTestButtonClick();
void draw()
  background(BG_COLOR); //Draws background
  bt.drawBt(); // Draws all GUI data related to bluetooth
