Hi I'm looking for some pretty basic advice on whether or not my project is feasible using Arduino.
I will have three units configured with Arduino boards, one will be the controller and the other two the slaves.
The controller will have constant power, no need for a battery.
The controllers job will be to monitor inputs (not really important at this stage where they come from) and once triggered, it will send Bluetooth signals to the slaves telling them to either turn on or off 30 LEDs.
The slaves will be approximately 20 feet from the controller and will need to be battery powered.
The slave(s) units will have a light sensor and return an acknowledgment to the controller that the LEDs did in fact come on.
Questions I have are as follows:
What kind of batteries would I need to power the slave units?
How would I be able to estimate how long the slave unit batteries would last for continual use under varying conditions?
Condition 1 - lets say no LEDs are ever turned on, only the Bluetooth communication between the controller and the slave.
Condition 2 - Going to the opposite extreme, the LEDs are turned on immediately and are left on continuously, how many hours could I expect the batteries to last?
I hope this is enough information to determine if this is a doable project, if not I will be happy to answer any follow up questions you have. Thanks for any input.
