Help with Bluetooth
Hello, Max30100 sensor works perfectly, but when i try to change Bluetooth state “b” sensor crashes and sends same measurement. And if state “a” is chosen, then program crashes and nothing works
So i want to do two measurement mods, one gives bpm fast another gives average measurement after 10s
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS     10000
#define REPORTING_PERIOD_MS1     1000
PulseOximeter pox;
int readIndex=0;
int average_beat=0;
int average_SpO2=0;
const int numReadings=10;
float filterweight=0.5;
uint32_t tsLastReport = 0;
uint32_t last_beat=0;
bool calculation_complete=false;
bool calculating=false;
bool initialized=false;
byte beat=0;
String state = "";
// Callback (registered below) fired when a pulse is detected
void onBeatDetected()
    Serial.println("Beat!");
 void display_calculating(int j){
 onBeatDetected();
  Serial.println("Measuring");
  for (int i=0;i<=j;i++) {
    Serial.print(". ");
    Serial.print("Initializing pulse oximeter..");
    // Initialize the PulseOximeter instance
    // Failures are generally due to an improper I2C wiring, missing power supply
    // or wrong target chip
    if (!pox.begin()) {
        Serial.println("FAILED");
        for(;;);
        Serial.println("SUCCESS");
    // The default current for the IR LED is 50mA and it could be changed
    //   by uncommenting the following line. Check MAX30100_Registers.h for all the
    //   available options.
    //pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
    // Register a callback for the beat detection
    pox.setOnBeatDetectedCallback(onBeatDetected);
void calculate_average(int beat, int SpO2)
  if (readIndex==numReadings) {
    calculation_complete=true;
    calculating=false;
    initialized=false;
    readIndex=0;
    loop();
  if (not calculation_complete and beat>30 and beat<220 and SpO2>50) {
    average_beat = filterweight * (beat) + (1 - filterweight ) * average_beat;
    average_SpO2 = filterweight * (SpO2) + (1 - filterweight ) * average_SpO2;
    readIndex++;
    display_calculating(readIndex);
    // Make sure to call update as fast as possible
    pox.update();
 if(Serial.available() > 0){ // Checks whether data is comming from the serial port
 state = Serial.readString(); // Reads the data from the serial port
     pox.update();
 //Serial.print(state);
    // Asynchronously dump heart rate and oxidation levels to the serial
    // For both, a value of 0 means "invalid"
    if (state == "a"){
    if (millis() - tsLastReport > REPORTING_PERIOD_MS)  {
      pox.update();
        Serial.print("Heart rate:");
        Serial.print(pox.getHeartRate());
        Serial.print("bpm / SpO2:");
        Serial.print(pox.getSpO2());
        Serial.println("%");
        tsLastReport = millis();
       pox.update();
  while (state == "b"){
pox.update();
    if (millis() - tsLastReport > REPORTING_PERIOD_MS1)  {
      pox.update();
          pox.update();
        //state = "";
       pox.update();
Audrimon:
Your post is unreadable, but it appears that you simply want to send/receive data via Bluetooth rather than to the serial monitor. In that event, Bluetooth has no bearing on the code and cannot crash anything. Your problem could be due to inadequate power.
