help with boolean
hi
im really stuck im trying to make a mute button to so when alarm sounds i can mute it with a button, i just cant make it work, any help greatly appreciated thanks
           //    input and alatm circuit, if any inputs are on for more > 30 seconds alarm sounds, mute button to turn off alarm.
int inputA = 2;                    // input a
int inputB = 3;                    // input b
int mute = 4;                      // mute low input
int led = 5;                       // LED on pin 3
int alarm = 6;                     // alarm sounds
int abgood = 7;                    // healthy a and b inputs made.
int abfail = 8;                    // FAIL a or b failed.
int inputaval;                     // val for reading input a
int inputbval;                     // val for reading input b
boolean running = false;
  pinMode(inputA, INPUT);         //input
  digitalWrite(inputB, HIGH);     //turn on pullup r
  pinMode(inputB, INPUT);         //input
  pinMode(mute, INPUT);           //mute push switch input
  digitalWrite(mute, HIGH);       //turn on pull up r
  pinMode(led, OUTPUT);           //led to show
  pinMode(alarm, OUTPUT);         //alarm circuit.
  pinMode(abgood, OUTPUT);        //lights up green led for healthy status.
  pinMode(abfail, OUTPUT);        //lights up red led for a fail.
void loop(){
  inputaval = digitalRead(inputA);            // read input value and store it in val1
  inputbval = digitalRead(inputB);            // read input value and store it in val2
  if ((inputaval == LOW) && (inputbval == LOW))
    digitalWrite(abgood, HIGH);               // a and B inputs are healthy.
    digitalWrite(alarm, LOW);                 // no alarm
    digitalWrite(abfail, LOW);                // no fail led lit
  } else{
    delay (1000);
    digitalWrite(alarm, HIGH);                // Alarm sounds   ****want to MUTE/toggle this output****
    digitalWrite(abfail, HIGH);               // fail led lit.
  if (digitalRead(mute) == LOW)              // switch is pressed - pullup keeps pin high normally
    delay(100);                              // delay to debounce switch
    running = !running;                      // toggle running variable
    digitalWrite(alarm, running);              // indicate via LED
  inputaval = digitalRead(inputa);            // read input value and store it in fan1
  inputbval = digitalRead(inputb);            // read input value and store it in fan2
The code does not do what the comments say. If you are not going to maintain the comments, get rid of them. Incorrect comments are worse than no comments.
You'll notice that there are functions like digitalRead, analogWrite(), etc., rather than digitalread and analogwrite. Ever wonder why? It's simple, really. The mixed case makes it much easier to see the words, and to see that you are using the correct function. You should really consider adopting a similar scheme for naming your variables. inputA and inputB are much easier to distinguish than inputa and inputb.
But, really, you don't have something connected to the Arduino called an input, do you. Use names that reflect what it attached. Use names for the state of what it attached that reflect what is attached. inputaval is way too vague.
When I see code with multiple } on one line, I give up trying to read it.
if(thisOrThat)
   if(someOtherCondition)
is much easier to see the logic of than
if(thisOrThat){
  if(someOtherCondition){
  }else{
If you had some names that allowed me to see which pin the mute button was connected to, and some visible logic in the structure of the code, it would be much easier to see where you are going wrong, and to explain what you need to change.
What is the mute button supposed to do? Mute the alarm while pressed or mute it forever or mute it until the error condition goes away & allow a subsequent alarm to be sounded?
ok points taken paul
will re post using your advice thanks
hi bill,
sorry i wasnt very clear im trying to make it mute until the error goes away, and to allow subsequent alarms to be sounded if the conditions occur
thank you
int InputA = 2;                    // input a
int InputB = 3;                    // input b
int Mute = 4;                      // mute button, low input
int Led = 5;                       // LED on pin 3
int Alarm = 6;                     // alarm sounds
int ABgood = 7;                    // healthy a and b inputs made.
int ABfail = 8;                    // FAIL a or b failed.
int InputAval;                     // val for reading input a
int InputBval;                     // val for reading input b
void setup(){
  pinMode(InputA, INPUT);         //input a input
  digitalWrite(InputA, HIGH);     //turn on pullup r
  pinMode(InputB, INPUT);         //input b input
  digitalWrite(InputB, HIGH);     //turn on pullup r
  pinMode(Mute, INPUT);           //mute push switch input
  digitalWrite(Mute, HIGH);       //turn on pull up r
  pinMode(Led, OUTPUT);           //led to show
  pinMode(Alarm, OUTPUT);         //alarm circuit.
  pinMode(ABgood, OUTPUT);        //lights up green led for healthy status.
  pinMode(ABfail, OUTPUT); }      //lights up red led for a fail.
void loop(){
  InputAval = digitalRead(InputA);            // read input value and store it in fan1
  InputBval = digitalRead(InputB);            // read input value and store it in fan2
  if ((InputAval == LOW) && (InputBval == LOW))
   {delay(1000);
    digitalWrite(ABgood, HIGH);               // a and b inputs are healthy.
    digitalWrite(Alarm, LOW);                 // no alarm
    digitalWrite(ABfail, LOW);                // no fail led lit
  }else{
    delay (1000);
    digitalWrite(Alarm, HIGH);                 // Alarm sounds   ****want to MUTE/toggle this output****
    digitalWrite(ABfail, HIGH);}               // fail led lit.
  if (digitalRead(Mute) == LOW)                 // switch is pressed - pullup keeps pin high normally
    digitalWrite(Alarm, running); }             // indicate via LED
yes paul i see what you mean, looks more logical will take on board your advice thank you
looks more logical
Really? What does this } match?
Why are you delay()ing only if the switch is pressed?
 *  2 switches monitoring two fans, healthly if both fan1 and fan2 switches are low output switches a relay, if any input high an alarm sounds no output to relay.
                              //int muteoutput = 2;          // mute buzzer (removes the low in the buz circuit to mute) XXXXX
int Buz = 10;                // buzzer sounds if fault
int Mute = A2;               // mut switch input
int Service = 9;             // service switch
int Supfanled = 4;           // supply fan led
int Extfanled = 5;           // ext fan led.
int Esled = 8;               // emergency stop switch led
int Relay = 3;               // green led lights if fan1 and fan2 are low connected to pin 9. healthey fan1 and fan2
int Gasled = 12;             // led to indicate gas is on.
int Fanfault = 6;            // red led lights if fan 1 or fan2 are high connected to pin 8.  (sounds an alarm)
int Es = A3;                 // emergency stop switch input.
int Fan2 = A5;               // fan switch is connected to pin 3
int Fan1 = A4;               // fan switch is connected to pin 2
int Fan1val;                 // var for reading the pin status
int Fan2val;                 // var for reading the pin status
int Esval;                   // val for reading emergency stop status
int Srviceval;               // val for service status.
boolean running = false;     // *****
void setup(){
  pinMode(Service, INPUT);              // service switch on just gas operates nothing else
  digitalWrite(Service, HIGH);          //turn on pulup r
  pinMode(Supfanled, OUTPUT);           // supply fan led o/p
  pinMode(Extfanled, OUTPUT);           // extfan led o/p
  pinMode(Gasled, OUTPUT);               // Greenlled as op.
  pinMode(Fanfault, OUTPUT);            // redled as op.
  pinMode(Fan1, INPUT);                // Set the switch pin as ip.
  digitalWrite(Fan1, HIGH);             // turn on internal r
  pinMode(Fan2, INPUT);                 // Set the switch pin as ip.
  digitalWrite(Fan2, HIGH);             // turn on internal r
  pinMode(Relay, OUTPUT);               // Set the switch pin as op.
  pinMode(Buz, OUTPUT);                 // Set the switch pin as op.
  pinMode(Mute, OUTPUT);                // Set the switch pin as 1p.
  pinMode(Es, INPUT);                   // Set the switch pin as 1p. *****
  digitalWrite(Es, HIGH);               // turn on pullup r
  pinMode(Esled, OUTPUT);               // Set the switch pin as 1p
  pinMode(Mute, INPUT);                 // set the switch pin as ip
  digitalWrite(Mute, HIGH);             // turn on pullup resistor
 void loop(){
  Fan1val = digitalRead(Fan1);            // read input value and store it in fan1
  Fan2val = digitalRead(Fan2);            // read input value and store it in fan2
  Esval = digitalRead(Es);                // read estop value and store value
  if ((Fan1val == LOW) && (Fan2val == LOW) && (Esval == LOW))
    delay (1000);                             // check if both inputs show fan OK (Switch is pressed)
    digitalWrite(Gasled, HIGH);               // turn green led on.
    digitalWrite(Relay, HIGH);                // turn on gas relay.
    digitalWrite(Buz,LOW);                    // buzzer off, no error
    digitalWrite(Fanfault,LOW);               // red led off no fault
  } else{
    delay (1000);
    digitalWrite(Gasled, LOW);                // turn green OFF
    digitalWrite(Relay, LOW);                 // turn off relay     **** Turn off Relay if fault has been greater than 30 seconds*****
    digitalWrite(Fanfault, HIGH);             // red led on
    digitalWrite(Buz, HIGH);                  // Alarm on            ****want to toggle this on/off only when fault, with the mute button *******
    digitalWrite(Supfanled, Fan1val);          //fan1 status led
    digitalWrite(Extfanled, Fan2val);          //fan2 status led
    digitalWrite(Esled, Esval);                //estop status
hi,
im really struggling with my program and im stuck, all i need to finish my project is to add a mute to my alarm, and a 30 sec delay to my relay.
finding it really difficuly to understand mills() to add a delay and boolean to make a mute button, hope someone could help me maby if i see the code it will help understand how these work and help me go faward
thank you
Why was it necessary to start a new thread on the same topic?
Intelligent use of white space is good.
 void loop(){
isn't it.
Where are you triggering an alarm? Where are you reading the mute switch? Where are you acting on that switch?
I thought I was (am?) having a deja vu.
They looked to be on the same topic, so I merged them.
What is a "1p"? (apart from 1/100th of a pound sterling)
hi
my alarm is here, is a high output that switches on a buzzer circuit.
my mute switch is here, a low in to mute the alarm.
int Mute = A2; // mute switch input
to be honest i really dont know how to act upon the input (mute)
(pinMode(Mute, OUTPUT); // Set the switch pin as 1p.) sorry corrected should be INPUT
That defines a pin name. There is a lot more to reading the state of the switch than that. You have not defined what the mute switch is to do, when it is to be read, or when the mute effect starts and ends.
For instance, on the rare occasions when I watch TV, I mute it when the commercials come on. I unmute it when the commercials end.
What do you want to mute? When do you want to mute it? When do you want to stop muting it?
hi paul
the mute needs to mute (Buz, HIGH); alarm, and finish when, if ((Fan1val == LOW) && (Fan2val == LOW) && (Esval == LOW))
You need a flag (boolean muted = false;). You need to set the value of the flag in appropriate places. Set it to false when the need for muting ends. Set it to true when the mute switch reads LOW.
Then, use the muted flag to decide whether to make the annoying noise, or not.
hi paul, how do you set the value of the flag in appropriate places?
muted = true;
muted = false;
The trick, of course, is determining the appropriate places.
Now, it's your turn to try something.
