Help with BQ_24195 Library
I need help with the Arduino_BQ24195 library. I installed this library using the Library Manager on the Arduino IDE 2.3.2, but when I try to #include this library from the Manager, it #included Arduino_PMIC, nor Arduino_BQ24195. I left the PMIC library included, and typed in #include Arduino_BQ24195, so I have both. But when I check/compile the sketch,, I keep getting a "No such file or directory" message. This code is intended to be uploaded on an Arduino MKR WiFi 1010, howerver, I have yet to receive them (they will be here next week), so I haven't connected the board to the computer yer. Will that make a difference? Am I doing something wrong. Help!
(also, while y'all are here, can you read through the rest of the code and give any suggestions to format/layout/anything)
#include <WiFiNINA.h>
#include <Arduino_BQ24195.h>        //battery utilities************************ will not compile with this library included
#include <Arduino_PMIC.h>           //part of BQ24195?
#include <ArduinoIoTCloud.h>
#include "simulationDiag.h"
#include "arduino_secrets.h"
//will also need to #include thingsProperties.h and arduino_secrets.h, but these should be added automatically by the online IDE.
//provide network credentials using the arduino_secrets.h header tab. Header should be included automatically
char cloudSSID[] = cloudNetwork_SSID;
char cloudPASS[] = cloudNetwork_PASS;
char localSSID[] = localNetwork_SSID;
char localPASS[] = localNetwork_PASS;
//the WiFI radio stauts (I just copied this from a tutorial):
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//defining constants:
const int toggleAllButton = 2;
const int toggleDoorButton = 3;
const int numberOfMotorUnits = 11;
bool shutterCommandBool;                    //this is what changes when the toggleAll button is pressed.
int shutterCommandBin = 0b00000000000;      //this is what the other boards will read, then use bitRead to determine its specific command.
int shutterStatus = 0b00000000000;          //currently, this is just to figure out what its doing on the simulator. eventually it will read the status of the other boards and update here
bool statusCorrectBool;                     //this will be used as a check to make sure all motorUnits completed their task properly.
unsigned long cloudUpdatePreviousMillis = 0; //will store the last time ArduinoCloud updates.
const long cloudUpdateInterval = 900000; //interval at which to update ArduinoCloud. 900000millis == 15 min
  while (!Serial) {}                        //delay while monitor starts  ***Is there a better option, since delay is not reccomended on cloud?
//  initProperties();                         //Initialize the variables/properties. Header created/maintained by IoT Cloud. Commented out temporarily to test if code will compile before boards arrive.*************************************************
  cloudSetup();
  localAPSetup();
  firmwareVersion();
  createLocalAPNetwork();
  pinMode(toggleAllButton, INPUT);
  pinMode(toggleDoorButton, INPUT);
  attachInterrupt(digitalPinToInterrupt(toggleAllButton), toggleAllShutters, RISING);
  attachInterrupt(digitalPinToInterrupt(toggleDoorButton), toggleBackDoor, RISING);
   setLedOutput();                          //simulator diag. Defined in simulatorDiag header. not important for code functionality
  scheduledCloudUpdate();
  diagOutput(shutterCommandBool, shutterCommandBin, numberOfMotorUnits);   //simulator diag. Defined in simulatorDiag header. not important for code functionality.
void cloudSetup(){
  //Cloud debug information (again, just copied from a tutorial):
//  ArduinoCloud.begin(ArduinoIoTPreferredConnection);   Requires initProperties(). Commented out temporarily to test if code will compile before boards arrive.
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
void localAPSetup(){
  //local AP information. Copied from tutorial.
  Serial.println("Access Point Web Server");
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    //don't continue
    while (true);                          //need to find a way to retry vs staying in a while loop
void firmwareVersion() {
  String firmwareVersion = WiFi.firmwareVersion();
  Serial.print("Firmware Version: ");
  Serial.println(firmwareVersion);
  if (firmwareVersion < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  else {
    Serial.println("Firmware Version is up to date!");
void createLocalAPNetwork(){
  //Create AP with open network
  Serial.print("Creating Access Point named: ");
  Serial.println(localSSID);
  status = WiFi.beginAP(localSSID, localPASS);
  if (status != WL_AP_LISTENING) {
    Serial.println("Creating Access Point Failed");
    while (true);     // don't continue. Need to find a way to keep retrying instead of staying in loop.
  delay(5000);        //***code I copied said 10 seconds, but I want to try 5 first, since the cloud documentation says delays aren't the best idea.***
  server.begin();      //start the server on port 80 (set in the variable info above).
  printWiFiStatus();
void scheduledCloudUpdate() {
  if (currentMillis-cloudUpdatePreviousMillis >= cloudUpdateInterval) {
    cloudUpdatePreviousMillis = currentMillis;
    shutterStatusCheck();
    ArduinoCloud.update();
void toggleAllShutters(){
  shutterCommandBool = !shutterCommandBool;
    for(int i=0; i<numberOfMotorUnits; i++){
      bitWrite(shutterCommandBin, i, shutterCommandBool);
void toggleBackDoor(){
  bitWrite(shutterCommandBin, 0, !bitRead(shutterCommandBin,0));
void shutterStatusCheck(){
  //this function will request the sensor status from each of the MotorUnits, and update shutterStatusBin variable, then check to see if shutterStatusBin==shutterCommandBin.
void printWiFiStatus() {                                  //I literally just copied this from a tutorial. Not sure if it is needed.
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
you better should not try to outsmart the library. examine library example to learn how to use it.
That is maddeningly unhelpful.
