Help with button box code and pressing multiple buttons at once
I have made a button box for PC gaming. All buttons work fine 1-25 (I used a 5x5 matrix for wiring) but the problem is when two toggles are activated simultaneously when another button is pressed it activates multiple buttons. I need to be able to have multiple buttons pressed at the same time with no conflict. I assume it is in the code I am using? Any help to point me in the right direction would be appreciated.
//BUTTON BOX
//USE w ProMicro
//BIGGINS 09-08-22
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 3
#define NUMBUTTONS 25
#define NUMPOTS 1
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[] =
  // We are using .kcode (the index, 0-24) instead of
  // .kchar (the character from this table) so
  // these letters are unused and arbitrary as long as
  // they are each unique and none of them are '\0'.
  "ABCDE"
  "FGHIJ"
  "KLMNO"
  "PQRST"
  "UVWXY"
struct rotariesdef
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES]
  {0, 1, 25, 26, 0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] =
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] =
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {A1, A0, 15, 14, 16};
byte colPins[NUMCOLS] = {10, 9, 8, 7, 6};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
                   JOYSTICK_TYPE_JOYSTICK, 32, 0,
                   false, false, false, false, false, false,
                   false, false, false, false, false);
  Joystick.begin();
  rotary_init();
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void)
  if (buttbx.getKeys())
    for (int i = 0; i < LIST_MAX; i++)
      if ( buttbx.key[i].stateChanged )
        switch (buttbx.key[i].kstate)
          case PRESSED:
            Joystick.setButton(buttbx.key[i].kcode, 1);
          case RELEASED:
            Joystick.setButton(buttbx.key[i].kcode, 0);
          case IDLE:
          case HOLD:
          default:
void rotary_init()
  for (int i = 0; i < NUMROTARIES; i++)
#ifdef ENABLE_PULLUPS
    pinMode(rotaries[i].pin1, INPUT_PULLUP);
    pinMode(rotaries[i].pin2, INPUT_PULLUP);
#else
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
#endif
unsigned char rotary_process(int _i)
  unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void)
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW)
      Joystick.setButton(rotaries[i].ccwchar, 1);
      delay(50);
      Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW)
      Joystick.setButton(rotaries[i].cwchar, 1);
      delay(50);
      Joystick.setButton(rotaries[i].cwchar, 0);
Well as we haven't seen your circuit who knows.
But I suspect you haven't got diodes in series with the switches in the matrix.
I apologize I am very new to this. I will try and post an image of the circuits as best I can. I did not use diodes no. I just wired them according to a tutorial I followed. Is there a reference to using diodes for my situation you could refer me to?
Then you are seeing exactly what you should. Without diodes you can't detect more than one push at a time.
Yes here
https://www.baldengineer.com/arduino-keyboard-matrix-tutorial.html
Thank you very much I will definitely take a look. Again I apologize for not having the wiring diagram in the post.
