Help with buttons not working please
Hi there can anyone please help me, and explain to me why button 5 is not working i am a newbie so be gentle thanks
#include <Ethernet.h>
#include <SPI.h>
#include <avr/pgmspace.h>
prog_char string_0[] PROGMEM = "<html><body><h2>HOME AUTOMATION</h2><font size= 4><form method=GET>";
prog_char string_1[] PROGMEM = "
<input type=submit name=b1 value= SHED_LIGHT>";
prog_char string_2[] PROGMEM = "
<input type=submit name=b2 value=Led2>";
prog_char string_3[] PROGMEM = "
<input type=submit name=b3 value=Led3>";
prog_char string_4[] PROGMEM = "
<input type=submit name=b4 value=Led4>";
prog_char string_5[] PROGMEM = "
<input type=submit name=b5 value=Led5>";
prog_char string_6[] PROGMEM = "";  //"<input name=msg value=no_name MAXLENGTH=20>";
prog_char string_7[] PROGMEM = "</form></body></html>";
prog_char string_8[] PROGMEM = "ON (ON)";
prog_char string_9[] PROGMEM = "OFF (OFF)";
prog_char string_10[] PROGMEM = "<meta http-equiv=refresh content=30 > "; //for auto refresh
PROGMEM const char *string_table[] =     // change "string_table" name to suit
  string_0,
  string_1,
  string_2,
  string_3,
  string_4,
  string_5,
  string_6,
  string_7,
  string_8,
  string_9,
  string_10
char buffer[85];    // make sure this is large enough for the largest string it must hold
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x21, 0xE3 };
byte ip[] = { 192, 168, 1, 68 };
byte gateway[] = { 192, 168, 1, 254 };
byte subnet[] = { 255, 255, 255, 0 };
String inString = String(35);
EthernetServer server(80);
boolean led1 = false;
boolean led2 = false;
boolean led3 = false;
boolean led4 = false;
boolean led5 = false;
String msg="";
int tam=0;
int st1=9,st2=9,st3=9,st4=9,st5=9;
  Ethernet.begin(mac, ip,gateway,subnet);
  server.begin();
  Serial.println("Serial READY");
  Serial.println("Ethernet READY");
  Serial.println("Server READY");
  pinMode(4,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(9,OUTPUT);
  int led=0;
  if (client) {
    // an http request ends with a blank line
    boolean current_line_is_blank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if we've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so we can send a reply
        if (inString.length() < 35) {
            inString.concat(c);
        if (c == '\n' && current_line_is_blank) {
          if(inString.indexOf("b1")>0){
             if(led1==false){
               st1=8;
               led1=true;
               digitalWrite(8,LOW);
             else{
               st1=9;
               led1=false;
               digitalWrite(8,HIGH);
             led=1;
           if(inString.indexOf("b2")>0){
             if(led2==false){
               st2=8;
               led2=true;
               digitalWrite(5,HIGH);
             else{
               st2=9;
               led2=false;
               digitalWrite(5,LOW);
             led=2;
           if(inString.indexOf("b3")>0){
             if(led3==false){
               st3=8;
               led3=true;
               digitalWrite(6,HIGH);
             else{
               st3=9;
               led3=false;
               digitalWrite(6,LOW);
             led=3;
           if(inString.indexOf("b4")>0){
             if(led4==false){
               st4=8;
               led4=true;
               digitalWrite(7,HIGH);
             else{
               st4=9;
               led4=false;
               digitalWrite(7,LOW);
             led=4;
           if(inString.indexOf("b5")>0){
             if(led5==false){
               st5=8;
               led5=true;
               digitalWrite(9,HIGH);
             else{
               st5=9;
               led5=false;
               digitalWrite(9,LOW);
             led=5;
           if(inString.indexOf("msg")>0){
              char charBuf1[50];
              char charBuf2[50];
              strcpy(msg,(char*)inString.substring(inString.indexOf("g")+2,inString.indexOf(" H")));
              //Serial.print("msg: ");
              Serial.println(msg);
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println();
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table[0]))); // Necessary casts and dereferencing, just copy.
          client.println( buffer );
          for (int i = 1; i < 8; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
            switch(i){
              case 1: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st1]))); client.println( buffer ); break;
              case 2: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st2]))); client.println( buffer ); break;
              case 3: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st3]))); client.println( buffer ); break;
              case 4: strcpy_P(buffer, (char*)pgm_read_word(&(string_table[st4]))); client.println( buffer ); break;
            delay(30);
          if(digitalRead(8)==HIGH){
            client.println("");
          }else{
            client.println("");
          if(digitalRead(9)==HIGH){
            client.println("");
          }else{
            client.println("");
         //strcpy_P(buffer, (char*)pgm_read_word(&(string_table[10]))); client.println( buffer );
        if (c == '\n') {
          // we're starting a new line
        } else if (c != '\r') {
          // we've gotten a character on the current line
          current_line_is_blank = false;
    // give the web browser time to receive the data
    delay(1);
    inString = "";
    client.stop();
Can't see it immediately,
best to strip the code line by line to a minimum version that shows the failure.
Far easier to debug.
thanks shannon
sorry thanks rob ha
All that dynamic memory allocation is not a good thing. Ditch the String class completely.
Debugging code without using Serial.print() wastes everyone's time. How do you KNOW that the client ever asks for anything to be done with button 5?
Meaningful names and initial values would help. There is nothing here to suggest what the heck stN is or why 9 is a useful initial value.
              char charBuf1[50];
              char charBuf2[50];
Is your delete key broken? Clearly this code is crap. Delete it or fix it.
