Hello everyone,
I'm trying to test receiving a signal using the Sparkfun CANbus and the arduino Mega 2560, the send signal is working fine currently. But I have a problem with the receive data:
I realized the following code that we will call *1 and I observe in the arduino console that I block at "CAN init OK" so my void loop is not carried out...
(this code is made in the Seeed library)
By chance I launched the following code *0 from coryjfowler's MCP2515 library which is called Loopback , everything works and moreover if I launch this code *0 then my code *1 then everything works ...
Questions :
Is there a way to check/solve this or do I need to add something in the code.
Maybe change library and code all my code in coryjfowler's MCP2515 library?
I hope my attached code and pictures will lead you to find the problem.
Thanks
Remay
*1 My code
#include <SPI.h>
#include <SD.h>
#include <TimeLib.h>
#include "mcp2515_can.h"
//*********************CAN Sheild declarations*********************
const int SPI_CS_PIN = 10;
const int CAN_INT_PIN = 2;
mcp2515_can CAN(SPI_CS_PIN);
//*********************SD Sheild declarations**********************
File myFile;
const int SD_CS_PIN = 9;
//*********************Record Excel declarations*******************
char filename[16];
unsigned long reads_recorded = 0;
uint16_t i = 0;
//*********************Switch and Led declarations*****************
const int buttonPin = 40; // the number of the pushbutton pin
const int ledPin = 41; // the number of the LED pin
//********************* Program SETUP *****************************
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(CAN_INT_PIN, INPUT);
SERIAL_PORT_MONITOR.begin(115200);
while (CAN_OK != CAN.begin(CAN_500KBPS, MCP_16MHz)) { // init can bus : baudrate = 500k
SERIAL_PORT_MONITOR.println("CAN init fail, retry...");
while (1); //wait here forever
SERIAL_PORT_MONITOR.println("CAN init ok!");
if (SD.begin(SD_CS_PIN))
SERIAL_PORT_MONITOR.println("SD card is present & ready");
//initialise filename
sprintf(filename, "can_%.03d.csv", i);
myFile = SD.open(filename, FILE_WRITE);
if (myFile) // it opened OK
//add header to file
myFile.println("Time,Pression,Temperature,co2_hydrogen,humidity");
myFile.close();
SERIAL_PORT_MONITOR.println("File created!");
SERIAL_PORT_MONITOR.println("Error opening file");
SERIAL_PORT_MONITOR.println("SD card missing or failure");
//********************* Fonction ecrire dans Excel ***********************
void writeToFile(float press_pascal, float temp_degC, float co2_true, float humi_pourcent)
myFile.print(String(minute()));
myFile.print(":");
myFile.print(String(second()));
myFile.print(";");
myFile.print(String(press_pascal, 2));
myFile.print(";");
myFile.print(String(temp_degC, 2));
myFile.print(";");
myFile.print(String(co2_true, 2));
myFile.print(";");
myFile.println(String(humi_pourcent, 2));
myFile.close();
//********************* Program LOOP ************************
unsigned char len = 0;
unsigned char buf[8];
unsigned long canId = CAN.getCanId();
if (digitalRead(buttonPin)== HIGH)
digitalWrite(ledPin, HIGH); // turn LED on
CAN_MSGAVAIL != CAN.checkReceive();
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
SERIAL_PORT_MONITOR.println("_____Pression_____");
uint16_t press_raw;
memcpy(&press_raw, &buf[0], 2); //buf[0] is the first byte in buf, 2 because you want 2 bytes
float press_pascal = ((press_raw * 0.0078125) - 250);
SERIAL_PORT_MONITOR.println(press_pascal, 2); // value to copy on excel
SERIAL_PORT_MONITOR.println("_____Temperature_____");
uint16_t temp_raw;
memcpy(&temp_raw, &buf[2], 2); //buf[2] is the third byte in buf, 2 because you want 2 bytes
float temp_degC = ((temp_raw * 0.3125) - 273) / 100;
SERIAL_PORT_MONITOR.println(temp_degC, 2);
SERIAL_PORT_MONITOR.println("_____CO2_Hydrogen_____");
uint16_t co2_raw;
memcpy(&co2_raw, &buf[4], 2); //buf[4] is the fifth byte in buf, 2 because you want 2 bytes
float co2_true = ((co2_raw * 1) - 0) / 100;
SERIAL_PORT_MONITOR.println(co2_true, 2);
SERIAL_PORT_MONITOR.println("_____Humidity_%_____");
uint16_t humi_raw;
memcpy(&humi_raw, &buf[6], 2); //buf[6] is the six byte in buf, 1 because you want 1 bytes
float humi_pourcent = ((humi_raw * 0.4) - 0);
SERIAL_PORT_MONITOR.println(humi_pourcent, 2);
writeToFile(press_pascal, temp_degC, co2_true, humi_pourcent);
++reads_recorded;
digitalWrite(ledPin, LOW); // turn LED off
Serial.println("off");
//********************* Creation new files excel ***********************
//create new filenames for every 1800 lines written to file
if(reads_recorded == 1800) { //reset counter
reads_recorded = 0;
//increment file counter
++i;
//update finename
//add header to new file
myFile.close();
SERIAL_PORT_MONITOR.println("New File created!");
*0 The code in coryjfowler's MCP2515 library
#include <mcp_can.h>
#include <SPI.h>
// CAN TX Variables
unsigned long prevTX = 0; // Variable to store last execution time
const unsigned int invlTX = 1000; // One second interval constant
byte data[] = {0xAA, 0x55, 0x01, 0x10, 0xFF, 0x12, 0x34, 0x56}; // Generic CAN data to send
// CAN RX Variables
long unsigned int rxId;
unsigned char len;
unsigned char rxBuf[8];
// Serial Output String Buffer
char msgString[128];
// CAN0 INT and CS
#define CAN0_INT 2 // Set INT to pin 2
MCP_CAN CAN0(10); // Set CS to pin 10
Serial.begin(115200); // CAN is running at 500,000BPS; 115,200BPS is SLOW, not FAST, thus 9600 is crippling.
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
Serial.println("MCP2515 Initialized Successfully!");
Serial.println("Error Initializing MCP2515...");
// Since we do not set NORMAL mode, we are in loopback mode by default.
//CAN0.setMode(MCP_NORMAL);
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
Serial.println("MCP2515 Library Loopback Example...");
if(!digitalRead(CAN0_INT)) // If CAN0_INT pin is low, read receive buffer
CAN0.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if((rxId & 0x40000000) == 0x40000000){ // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for(byte i = 0; i<len; i++){
sprintf(msgString, " 0x%.2X", rxBuf[i]);
if(millis() - prevTX >= invlTX){ // Send this at a one second interval.
prevTX = millis();
byte sndStat = CAN0.sendMsgBuf(0x100, 8, data);
if(sndStat == CAN_OK)
Serial.println("Message Sent Successfully!");
Serial.println("Error Sending Message...");
