Good Morning:
I'm giving a little robotics workshop to a group of teenagers in my city in Texas and I'm guiding them through the process of building the meArm. I've assembled it and programmed it 'manually' before to perform certain movements, but now we're going to use Joysticks to control it. We bought the joysticks that come in separately and hook them up to our proto-board. We're using the code below but I'm having problems interpreting certain lines of code, particularly the move_joy() function, perhaps of my lack of experience with Joystick programming. Anyways, I've tried for the last week to try to interpret the code the best I can, doing online research and reading an arduino book that I have, but this function keeps giving me trouble. I would like your help to verify that what I'm putting on the comments lines is accurate and also to try and figure out the lines in which I don't have comments. Your help will be greatly appreciated and promote the proper dissemination or Arduino Knowledge, thanks
Here's the full code...
#include <Servo.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX
const int SERVOS = 4;
int PIN[SERVOS], value[SERVOS], currentAngle[SERVOS], MIN[SERVOS], MAX[SERVOS], INITANGLE[SERVOS];
Servo myservo[SERVOS];
int afrom[] = {90, 35, 135}, ato[] = {20, 140, 110}, amiddle[] = {20, 35, 135}, afinal[] = {179,75,95}, aafterfinal[] = {179,35,135};
int DELAYTIME = 200;
int servo_moving[SERVOS] = {0,0,0,0};
boolean stringComplete = false;
int bt_servo = 0;
int bt_move = 0;
int idle = 0;
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
mySerial.begin(9600);
init_Pins();
//auto_mode();
move_bt();
move_joy();
void init_Pins(){
PIN[0] = 11;
MIN[0] = 0;
MAX[0] = 179;
INITANGLE[0] = 90;
PIN[1] = 10;
MIN[1] = 35;
MAX[1] = 179;
INITANGLE[1] = 90;
PIN[2] = 9;
MIN[2] = 90;
MAX[2] = 179;
INITANGLE[2] = 155;
PIN[3] = 5;
MIN[3] = 0;
MAX[3] = 179;
INITANGLE[3] = 25;
for (int i = 0; i < SERVOS; i++){
myservo[i].attach(PIN[i]);
myservo[i].write(INITANGLE[i]);
value[i] = 0;
idle = 0;
void move_bt(){
checkSoftSerial();
currentAngle[i] = myservo[i].read();
if (servo_moving[i] != 0){
currentAngle[i] += servo_moving[i];
currentAngle[i] = currentAngle[i] > MAX[i] ? --currentAngle[i] : currentAngle[i];
currentAngle[i] = currentAngle[i] < MIN[i] ? ++currentAngle[i] : currentAngle[i];
myservo[i].write(currentAngle[i]);
delay(20);
void checkSoftSerial() {
String str = "";
if (mySerial.available()){
for (int i = 0 ; i < 2; i++){
str += (char)mySerial.read();
// the servo to move
int value = str.toInt();
bt_servo = value / 10;
// the direction to move
int angle = value % 10;
if (angle == 2) bt_move = 1;
else if (angle == 1) bt_move = -1;
else bt_move = 0;
servo_moving[bt_servo] = bt_move;
void move_joy(){
value[i] = analogRead(i);
if (value[i] > 612) {
idle = 0;
if (currentAngle[i] > MIN[i]) --currentAngle[i];
} else if (value[i] < 412) {
idle = 0;
if (currentAngle[i] < MAX[i]) ++currentAngle[i];
++idle;
if (idle == 100){
myservo[i].detach();
for (int i = 0 ; i < SERVOS; i++){
if (!myservo[i].attached()) myservo[i].attach(PIN[i]);
delay(20);
void auto_mode(){
for (int i = 0; i < 2; i++){
closeclaw(false);
armfromto(afrom, ato);
closeclaw(true);
delay(DELAYTIME);
armfromto(ato, amiddle);
delay(DELAYTIME);
armfromto(amiddle, afinal);
closeclaw(false);
delay(DELAYTIME);
armfromto(afinal, aafterfinal);
delay(DELAYTIME);
armfromto(aafterfinal, afrom);
delay(DELAYTIME);
void armfromto(int *arrf, int *arrt){
int lp[3], seg = 3, sign;
for (int i = 0; i < 3; i++){
lp[i] = abs((arrt[i] - arrf[i])/seg);
//delay(DALAYTIME);
sign = arrt[i] - arrf[i] > 0 ? 1 : -1;
for (int j = 0; j < lp[i]; j++){
myservo[i].write(arrf[i]+j*seg*sign);
delay(20);
delay(DELAYTIME);
void closeclaw(boolean op){
if (op){
myservo[3].write(5);
myservo[3].write(30);
But where I'm stuck is on the move_joy() function
void move_joy(){ //Declares the ‘move-joy()’ function
for (int i = 0; i < SERVOS; i++){ //Creates the ‘for’ loop, counting 1 servo at the time to perform the following instructions
value[i] = analogRead(i); //Reads analog feed from the Joystick and stores it into the Variable ‘Value’ for each servo
currentAngle[i] = myservo[i].read(); //Reads the angle of each servo and stores it in the Variable ‘CurrentAngle’
if (value[i] > 612) { //If the Joystick is over 612…
idle = 0;
if (currentAngle[i] > MIN[i]) --currentAngle[i]; //If the angle of a given Servo is larger than its MIN limit, it will decrease it by 1 in each loop
} else if (value[i] < 412) { //If the Joystick is under 412…
idle = 0;
if (currentAngle[i] < MAX[i]) ++currentAngle[i]; //If the angle of a given Servo is smaller than its MAX limit, it will increase it by 1 in each loop
++idle;
if (idle == 100){
I would like to know why the code moves only between 412 and 612, and also if idle means really stand still and why does it detaches the servos at 100. Again, any help will be greatly appreciated, have a great day! ![]()
