Help with chat server Telnet
I am new to this site but I would like to download my program byt dont know how.
I modifyed the chat server and was able to conect and chat with Telnet but i was playing with the program and now I conect and imedeitly disconect? im not sure why. I am new to programing so getting the program to work first time was just luck. Can anyone help?
Thx
This code may work for what you want. You will need to modify it to your requirements, but it does allow 4 simultaneous connections. It may be a bit difficult to understand. It is not for the beginner.
http://playground.arduino.cc/Code/Telnet
Thanks again Surfer Tim. I am a beginner but i am willing to work for my goals. the code you gave me was for a W5100 Ethernet shield and mine is a W5200. I should have mentioned that. what would help me the most rite now would be if someone could tell or show me how to get my program on this site.
the code I have is a whole lot simpler lol.
Thx
#7 below:
http://forum.arduino.cc/index.php/topic,148850.0.html
Thank you zoomkat im going to give it a try.
my problem is when i try to conect through telnet it conects and imedietly disconects. could some one help?
 Chat  Server
 A simple server that distributes any incoming messages to all
 connected clients.  To use telnet to  your device's IP address and type.
 You can see the client's input in the serial monitor as well.
 Using an Arduino Wiznet Ethernet shield.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 * Analog inputs attached to pins A0 through A5 (optional)
 created 18 Dec 2009
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
#include <SPI.h>
#include <EthernetV2_0.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,x, x);
IPAddress gateway(192,168,x, x);
IPAddress subnet(255, 255, 255, 0);
IPAddress dnServer(192, 168, x, x);
EthernetServer server(xxxx);
  Ethernet.begin(mac, ip, gateway, subnet);
  Serial.println(Ethernet.localIP());
I know i am new and this is not a verry exciting code but i think i am learning thank you guys.
That won't do it. Reload the example chat server code.
