Help with choosing random string from array
I am trying to write code for my Arduino Uno with Adafruit MP3 Music Maker Shield that plays a randomly selected song from an array whenever it is turned on, but every time I reset the board the
Here is a sample of the code I have:
const char* song[]={"track001.mp3","track002.mp3","track003.mp3"};
const char* str = song[random(4)];
Serial.println(str);
musicPlayer.playFullFile(str);
Serial Monitor:
Randomized Music Speakers
VS1053 found
Done playing music
I can't figure out why no song is playing at all, I've used every resource I could find and still it will not work. Any and all help would be appreciated, more code and other information can be given upon request, thanks!
Here is a sample of an answer.
Arrays are addressed from zero...
A fragment is usually useless. You give us the code you understand when the problem is usually in the code that you don't understand.
Can you play a song without the random() nonsense?
Your array of songs has 3 elements in it.
You are calling random(4), which returns a number from 0 to 3,
BUT:
If it returns 3 and you access array index3, you create a "buffer overflow" and access memory locations, where no valid data is stored!
In an array with 3 elements, the valid array index is 0,1, or 2 only!
If you want to have a random index number for accessing an array with 3 elements, better use random(3) instead!
BTW:What are your provisions to get a "true random number" from the "pseudo random number generator" function in Arduino?
When you take no provisions, you get the same sequence of numbers after each resetii.,e. the first access to random(4) or random(3) will always return the same number after each reset of the Arduino (power-on reset or pressing the reset button or auto-reset when opening the serial monitor!
