my filament dryer broke so instead of purchasing one decided to make it work with a esp32 laying aroundwith 2 ch relay for the heater and fan, 100k thermister for the heat plate temp and a SHT31 for chamber humidity and temp with a rotary encoder to set temp and timer. but when compiling i keep getting an error
error: 'class RotaryEncoder' has no member named 'begin'
28 | encoder.begin();
error: 'class RotaryEncoder' has no member named 'setMinMax'
29 | encoder.setMinMax(0, 24);
Compilation error: 'class RotaryEncoder' has no member named 'begin'
and i cannot seem to pinpoint why below is the code, any help is appriciated
TIA
#include <Wire.h>
#include <Adafruit_SHT31.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <RotaryEncoder.h>
#define NTC_PIN A0
#define HEATER_RELAY 13
#define FAN_RELAY 12
#define ROTARY_PIN1 26
#define ROTARY_PIN2 25
#define MAX_TEMP 33
Adafruit_SHT31 sht31 = Adafruit_SHT31();
Adafruit_SSD1306 display(128, 64, &Wire, -1);
RotaryEncoder encoder(ROTARY_PIN1, ROTARY_PIN2);
float heaterTemp = 0;
float ambientTemp = 0;
float humidity = 0;
pinMode(HEATER_RELAY, OUTPUT);
pinMode(FAN_RELAY, OUTPUT);
Wire.begin();
sht31.begin(0x44);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
encoder.begin();
ambientTemp = sht31.readTemperature();
humidity = sht31.readHumidity();
heaterTemp = analogRead(NTC_PIN) * (3.3 / 4095.0) * 100; // Convert to Celsius
if (heaterTemp < MAX_TEMP) {
digitalWrite(HEATER_RELAY, HIGH);
digitalWrite(FAN_RELAY, HIGH);
digitalWrite(HEATER_RELAY, LOW);
digitalWrite(FAN_RELAY, LOW);
encoder.tick();
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0);
display.println("Heater Temp: " + String(heaterTemp));
display.println("Ambient Temp: " + String(ambientTemp));
display.println("Humidity: " + String(humidity));
display.println("Timer: " + String(encoder.getPosition()));
display.display();
