Hello! This is my first post. Im in a situation where I have a school assingment that Ive been frying my brain over and hoped that someone could really really help me with this as I am not proficient in coding at all but can do basic coding. I Have the Arduino Smart Home kit that uses the Arduino Uno board. Im currently on the 15th project of assembling the entire home and have it working, but the teacher wants me to modify the code under these pre-reqs
These is the connections based on the smarthome kit so far
Link (Project 15) KS0085 Keyestudio Smart Home Kit for Arduino - Keyestudio Wiki
Modifications needed below
1:When at night someone passes by Photosensor (Pin A1) , Both LED Lights blink alternately (Pin 5 & Pin 13)
2: Change the password to ā..---.-" (Note: The old password is ā. - - . - .ā which means short press button1, long press button1, long press button1, short press button1, long press button1, short press button1.)
3: When Gas Sensor detects gas (Pin A0), Buzzer (Pin 3) emits a tick-tick sound as normal and the window will open and close (Pin 10).
4: When Steam Sensor detects no rain (Pin A3), window opens
As light intensity increases on photosensor (Pin A1), increase speed of fan and as light decreases speed of fan decreases (Pin 6 GVS and Pin 7S)
5: When soil sensor is wet (Pin A2) and steam sensor detects rain (Pin A3) the house will do whatever it does normally and Yellow and white LEDS Blink alternately
The code itself that i need help with
//call the relevant library file
#include <Servo.h>
#include <Wire.h>
//Set the communication address of I2C to 0x27, display 16 characters every line, two lines in total
LiquidCrystal_I2C mylcd(0x27, 16, 2);
//set ports of two servos to digital 9 and 10
Servo servo_10;
Servo servo_9;
volatile int btn1_num;//set variable btn1_num
volatile int btn2_num;//set variable btn2_num
volatile int button1;//set variable button1
volatile int button2;//set variable button2
String fans_char;//string type variable fans_char
volatile int fans_val;//set variable fans_char
volatile int flag;//set variable flag
volatile int flag2;//set variable flag2
volatile int flag3;//set variable flag3
volatile int gas;//set variable gas
volatile int infrar;//set variable infrar
String led2;//string type variable led2
volatile int light;//set variable light
String pass;//string type variable pass
String passwd;//string type variable passwd
String servo1;//string type variable servo1
volatile int servo1_angle;//set variable light
String servo2;//string type variable servo2
volatile int servo2_angle;//set variable servo2_angle
volatile int soil;//set variable soil
volatile int val;//set variable val
volatile int value_led2;//set variable value_led2
volatile int water;//set variable water
int length;
int tonepin = 3; //set the signal end of passive buzzer to digital 3
//define name of every sound frequency
#define D0 -1
#define D1 262
#define D2 293
#define D3 329
#define D4 349
#define D5 392
#define D6 440
#define D7 494
#define M1 523
#define M2 586
#define M3 658
#define M4 697
#define M5 783
#define M6 879
#define M7 987
#define H1 1045
#define H2 1171
#define H3 1316
#define H4 1393
#define H5 1563
#define H6 1755
#define H7 1971
#define WHOLE 1
#define HALF 0.5
#define QUARTER 0.25
#define EIGHTH 0.25
#define SIXTEENTH 0.625
//set sound play frequency
int tune[] =
M3, M3, M4, M5,
M5, M4, M3, M2,
M1, M1, M2, M3,
M3, M2, M2,
M3, M3, M4, M5,
M5, M4, M3, M2,
M1, M1, M2, M3,
M2, M1, M1,
M2, M2, M3, M1,
M2, M3, M4, M3, M1,
M2, M3, M4, M3, M2,
M1, M2, D5, D0,
M3, M3, M4, M5,
M5, M4, M3, M4, M2,
M1, M1, M2, M3,
M2, M1, M1
//set music beat
float durt[] =
1, 1, 1, 1,
1, 1, 1, 1,
1, 1, 1, 1,
1 + 0.5, 0.5, 1 + 1,
1, 1, 1, 1,
1, 1, 1, 1,
1, 1, 1, 1,
1, 1, 1, 1,
1, 0.5, 0.5, 1, 1,
1, 0.5, 0.5, 1, 1,
1, 1, 1, 1,
1, 1, 1, 1,
1, 1, 1, 0.5, 0.5,
1, 1, 1, 1,
Serial.begin(9600);//set baud rate to 9600
mylcd.init();
mylcd.backlight();//initialize LCD
//LCD shows "passcord:" at first row and column
mylcd.setCursor(1 - 1, 1 - 1);
mylcd.print("passcord:");
servo_9.attach(9);//make servo connect to digital 9
servo_10.attach(10);//make servo connect to digital 10
servo_9.write(0);//set servo connected digital 9 to 0°
servo_10.write(0);//set servo connected digital 10 to 0°
delay(300);
pinMode(7, OUTPUT);//set digital 7 to output
pinMode(6, OUTPUT);//set digital 6 to output
digitalWrite(7, HIGH); //set digital 7 to high level
digitalWrite(6, HIGH); //set digital 6 to high level
pinMode(4, INPUT);//set digital 4 to input
pinMode(8, INPUT);//set digital 8 to input
pinMode(2, INPUT);//set digital 2 to input
pinMode(3, OUTPUT);//set digital 3 to output
pinMode(A0, INPUT);//set A0 to input
pinMode(A1, INPUT);//set A1 to input
pinMode(13, OUTPUT);//set digital 13 to input
pinMode(A3, INPUT);//set A3 to input
pinMode(A2, INPUT);//set A2 to input
pinMode(12, OUTPUT);//set digital 12 to output
pinMode(5, OUTPUT);//set digital 5 to output
length = sizeof(tune) / sizeof(tune[0]); //set the value of length
auto_sensor();
if (Serial.available() > 0) //serial reads the characters
val = Serial.read();//set val to character read by serial Serial.println(val);//output val character in new lines
pwm_control();
switch (val) {
case 'a'://if val is character 'a'ļ¼program will circulate
digitalWrite(13, HIGH); //set digital 13 to high levelļ¼LED lights up
break;//exit loop
case 'b'://if val is character 'b'ļ¼program will circulate
digitalWrite(13, LOW); //Set digital 13 to low level, LED is off
break;//exit loop
case 'c'://if val is character 'c'ļ¼program will circulate
digitalWrite(12, HIGH); //set digital 12 to high levelļ¼NO of relay is connected to COM
break;//exit loop
case 'd'://if val is character 'd'ļ¼program will circulate
digitalWrite(12, LOW); //set digital 12 to low levelļ¼NO of relay is disconnected to COM
break;//exit loop
case 'e'://if val is character 'e'ļ¼program will circulate
music1();//play birthday song
break;//exit loop
case 'f'://if val is character 'f'ļ¼program will circulate
music2();//play ode to joy song
break;//exit loop
case 'g'://if val is character 'g'ļ¼program will circulate
noTone(3);//set digital 3 to stop playing music
break;//exit loop
case 'h'://if val is character 'h'ļ¼program will circulate
Serial.println(light);//output the value of variable light in new lines
delay(100);
break;//exit loop
case 'i'://if val is character 'i'ļ¼program will circulate
Serial.println(gas);//output the value of variable gas in new lines
delay(100);
break;//exit loop
case 'j'://if val is character 'j'ļ¼program will circulate
Serial.println(soil);//output the value of variable soil in new lines
delay(100);
break;//exit loop
case 'k'://if val is character 'k'ļ¼program will circulate
Serial.println(water);//output the value of variable water in new lines
delay(100);
break;//exit loop
case 'l'://if val is character 'l'ļ¼program will circulate
servo_9.write(180);//set servo connected to digital 9 to 180°
break;//exit loop
case 'm'://if val is character 'm'ļ¼program will circulate
servo_9.write(0);;//set servo connected to digital 9 to 0°
break;//exit loop
case 'n'://if val is character 'n'ļ¼program will circulate
servo_10.write(180);//set servo connected to digital 10 to 180°
break;//exit loop
case 'o'://if val is character 'o'ļ¼program will circulate
servo_10.write(0);//set servo connected to digital 10 to 0°
break;//exit loop
case 'p'://if val is character 'p'ļ¼program will circulate
digitalWrite(5, HIGH); //set digital 5 to high level, LED is on
break;//exit loop
case 'q'://if val is character 'q'ļ¼program will circulate
digitalWrite(5, LOW); // set digital 5 to low level, LED is off
break;//exit loop
case 'r'://if val is character 'r'ļ¼program will circulate
digitalWrite(7, LOW);
digitalWrite(6, HIGH); //fan rotates anticlockwise at the fastest speed
break;//exit loop
case 's'://if val is character 's'ļ¼program will circulate
digitalWrite(6, LOW); //fan stops rotating
break;//exit loop
////////////////////////set birthday song//////////////////////////////////
void birthday()
tone(3, 294); //digital 3 outputs 294HZ sound
delay(250);//delay in 250ms
tone(3, 440);
delay(250);
tone(3, 392);
delay(250);
tone(3, 532);
delay(250);
tone(3, 494);
tone(3, 392);
delay(250);
tone(3, 440);
delay(250);
tone(3, 392);
delay(250);
tone(3, 587);
delay(250);
tone(3, 532);
tone(3, 392);
delay(250);
tone(3, 784);
delay(250);
tone(3, 659);
delay(250);
tone(3, 532);
delay(250);
tone(3, 494);
delay(250);
tone(3, 440);
delay(250);
tone(3, 698);
delay(375);
tone(3, 659);
delay(250);
tone(3, 532);
delay(250);
tone(3, 587);
delay(250);
tone(3, 532);
//detect gas
void auto_sensor() {
gas = analogRead(A0);//assign the analog value of A0 to gas
if (gas > 700) {
//if variable gas>700
flag = 1;//set variable flag to 1
while (flag == 1)
//if flag is 1, program will circulate
Serial.println("danger");//output "danger" in new lines
tone(3, 440);
delay(125);
delay(100);
noTone(3);
delay(100);
tone(3, 440);
delay(125);
delay(100);
noTone(3);
delay(300);
gas = analogRead(A0);//gas analog the value of A0 to gas
if (gas < 100) //if variable gas is less than 100
flag = 0;//set variable flag to 0
break;//exit loop exist to loop
} else
//otherwise
noTone(3);// digital 3 stops playing music
light = analogRead(A1);////Assign the analog value of A1 to light
if (light < 300)//if variable light is less than 300
infrar = digitalRead(2);//assign the value of digital 2 to infrar
Serial.println(infrar);//output the value of variable infrar in new lines
if (infrar == 1)
// if variable infra is 1
digitalWrite(13, HIGH); //set digital 13 to high level, LED is on
} else//Otherwise
digitalWrite(13, LOW); //set digital 13 to low level, LED is off
water = analogRead(A3);//assign the analog value of A3 to variable water
if (water > 800)
// if variable water is larger than 800
flag2 = 1;//if variable flag 2 to 1
while (flag2 == 1)
// if flag2 is 1, program will circulate
Serial.println("rain");//output "rain" in new lines
servo_10.write(180);// set the servo connected to digital 10 to 180°
delay(300);//delay in 300ms
delay(100);
water = analogRead(A3);;//assign the analog value of A3 to variable water
if (water < 30)// if variable water is less than 30
flag2 = 0;// set flag2 to 0
break;//exit loop
} else//Otherwise
if (val != 'u' && val != 'n')
//if val is not equivalent 'u' either 'n'
delay(10);
soil = analogRead(A2);//assign the analog value of A2 to variable soil
if (soil > 50)
// if variable soil is greater than 50
flag3 = 1;//set flag3 to 1
while (flag3 == 1)
//If set flag3 to 1, program will circulate
Serial.println("hydropenia ");//output "hydropenia " in new lines
tone(3, 440);
delay(125);
delay(100);
noTone(3);
delay(100);
tone(3, 440);
delay(125);
delay(100);
noTone(3);//digital 3 stops playing sound
delay(300);
soil = analogRead(A2);//Assign the analog value of A2 to variable soil
if (soil < 10)//If variable soil<10
flag3 = 0;//set flag3 to 0
break;//exit loop
} else//Otherwise
door();//run subroutine
void door() {
button1 = digitalRead(4);// assign the value of digital 4 to button1
button2 = digitalRead(8);//assign the value of digital 8 to button2
if (button1 == 0)//if variablebutton1 is 0
delay(10);//delay in 10ms
while (button1 == 0) //if variablebutton1 is 0ļ¼program will circulate
btn1_num = btn1_num + 1;//variable btn1_num plus 1
delay(100);// delay in 100ms
if (btn1_num >= 1 && btn1_num < 5) //1ā¤if variablebtn1_num<5
Serial.print(".");
Serial.print("");
passwd = String(passwd) + String(".");//set passwd
pass = String(pass) + String(".");//set pass
//LCD shows pass at the first row and column
mylcd.setCursor(1 - 1, 2 - 1);
mylcd.print(pass);
if (btn1_num >= 5)
//if variablebtn1_num ā„5
Serial.print("-");
passwd = String(passwd) + String("-");//Set passwd
pass = String(pass) + String("-");//set pass
mylcd.print(pass);
if (button2 == 0) //if variablebutton2 is 0
delay(10);
if (button2 == 0)//if variablebutton2 is 0
if (passwd == ".--.-.")//if passwd is ".--.-."
mylcd.clear();//clear LCD screen
//LCD shows "open!" at first character on second row
mylcd.print("open!");
servo_9.write(100);//set servo connected to digital 9 to 100°
delay(300);
delay(5000);
passwd = "";
pass = "";
//LCD shows "password:"at first character on first row
mylcd.print("password:");
} else //Otherwise
//LCD shows "error!"at first character on first row
mylcd.print("error!");
passwd = "";
pass = "";
delay(2000);
//LCD shows "again" at first character on first row
mylcd.print("again");
if (infrar == 0 && (val != 'l' && val != 't'))
//if variable infrar is 0 and val is not 'l' either 't'
servo_9.write(0);//set servo connected to digital 9 to 0°
delay(50);
delay(10);
while (button2 == 0) //if variablebutton2 is 0ļ¼program will circulate
btn2_num = btn2_num + 1;//variable btn2_num plus 1
delay(100);
if (btn2_num >= 15)//if variablebtn2_num ā„15
tone(3, 532);
delay(125);
//LCD shows "password:" at the first character on first row
//LCD shows "wait" at the first character on first row
mylcd.print("wait");
} else//Otherwise
noTone(3);//digital 3 stops playing music
btn1_num = 0;//set btn1_num to 0
btn2_num = 0;//set btn2_num to 0
// Birthday song
void music1() {
birthday();
//Ode to joy
void music2() {
Ode_to_Joy();
void Ode_to_Joy()//play Ode to joy song
for (int x = 0; x < length; x++)
tone(tonepin, tune[x]);
delay(300 * durt[x]);
//PWM control
void pwm_control() {
switch (val)
case 't'://if val is 't'ļ¼program will circulate
servo1 = Serial.readStringUntil('#');
servo1_angle = String(servo1).toInt();
servo_9.write(servo1_angle);//set the angle of servo connected to digital 9 to servo1_angle
delay(300);
break;//exit loop
case 'u'://if val is 'u'ļ¼program will circulate
servo2 = Serial.readStringUntil('#');
servo2_angle = String(servo2).toInt();
servo_10.write(servo2_angle);//set the angle of servo connected to digital 10 to servo2_angle
delay(300);
break;//exit loop
case 'v'://if val is 'v'ļ¼program will circulate
led2 = Serial.readStringUntil('#');
value_led2 = String(led2).toInt();
analogWrite(5, value_led2); //PWM value of digital 5 is value_led2
break;//exit loop
case 'w'://if val is 'w'ļ¼program will circulate
fans_char = Serial.readStringUntil('#');
fans_val = String(fans_char).toInt();
analogWrite(6, fans_val); //set PWM value of digital 6 to fans_valļ¼the larger the value, the faster the fan
break;//exit loop
If anyone can help me modify the code to the previous mentioned requirements i would be super grateful
