Help with Class variable
Apologies - I'm a bit "in and out" over the next couple of days, so might not be able to reply straight away.
I have a variable in my code called _incrementIndex that isn't behaving as I'd like.
I have a class called:
class motorControl {
It has a constructor where I declare the variable in the hope that it becomes a variable I can reference later (I'm not sure quite why this works, but seems to work for some other variables - don't beat me up on this please - I've a feeling it's this part may need some work)
Public:
motorControl() {
int _incrementIndex = 1;
There are two relevant methods within the class that I'm calling. One set the value of _incrementIndex and one to retrieve it.
    int get_incrementIndex() {
      //int _incrementIndex = incrementIndex;
      Serial.println("Im in get_incrementIndex, and am about to print _incrementIndex");
      Serial.println(_incrementIndex);
      Serial.println("^^did i do it??^^");
      return _incrementIndex;
    void set_increment(int increment) {
      Serial.println("set_increment");
      int _incrementIndex = increment;
      Serial.println(_incrementIndex); //only works when I declare the variable in private
and I'm declaring some of the variables private
	 private:
    int _incrementIndex;
This is a contradiction I appreciate, but if I don't have this, then my function void set_increment(int increment) complains about undeclared variables. Which is another place where this could all be failing.
I create my objects
timeControl RATimer;
timeControl DecTimer;
timeControl IRTimer;
And i have a function that translates my infra red code. When I press button 1 on my remote, I'm expecting the increment variable int _incrementIndex to be changed to 1, and stored in the class so I reference it later.
void translateIR(unsigned long IRraw) // takes action based on IR code received
  //Serial.print("translateIR");
  switch (IRraw)
    case 404736: //Serial.println("");
      //set increments to 1
      Serial.println("Setting increment for both motors");
      decMotor.set_increment(1);
      raMotor.set_increment(1);
      Serial.println("Getting increment indexfor both motors");
      Serial.println(decMotor.get_incrementIndex());//returns 0. Why?
      raMotor.get_incrementIndex();
In my Serial monitor, the messages here are printed:
0
^^did i do it??^^
I'm expecting to see 1 rather than 0.
What have I missed? What do i need to change so that 1 appears instead of 0 when the code return _incrementIndex; executed when I press 1 on my remote control?
Full code here.
//======Includes=======================
#include "Arduino.h"
#include <AFMotor.h>
//IR controls
//#include "PinDefinitionsAndMore.h"
#include <IRremote.hpp>
//======Define stuff===================
#define RAMotor 1
#define DECMotor 2
#define FORWARD 1
#define BACKWARD 2
#define IR_RECEIVE_PIN A0
//=======Classes======================
//=======Create Classes================
class timeControl {
  public:
    unsigned long MPC;
    long countNumber;
    unsigned long currentTime;
    unsigned long storedTime;
    unsigned long TimeToWait;
    double storedNumber;
    timeControl() {
      storedTime = savedTime(micros());
      storedNumber = 6; //
      TimeToWait = 1;
      currentTime = 1;
      countNumber = 2;
      _startTime = 1;
      MPC = microsPerCount();
    unsigned long getTime(uint8_t currentTime = 1) { //0 = currentTime = 0, 1 = stored time, 2 = wait time, 3 = count, 4 = RPM
      if (currentTime == 0) {
        return micros(); //return the time now
      else if (currentTime == 1) {
        storedTime = _storedTime;
        return storedTime; //return the time (for last time activated)
      else if (currentTime == 2) {
        return TimeToWait; //return the time to wait before attempting to activate again
      else if (currentTime == 3) {
        return countNumber; //return the time to wait before attempting to activate again
      else if (currentTime == 4) {
    unsigned long savedTime(unsigned long whatTime) {
      _storedTime = whatTime;  //2) Store some arbitrary time that I pass to it so I can reference it later. normally used to save the last step time
      unsigned long storedTime = _storedTime;
      return _storedTime;
    double savedNumber(unsigned long whatNumber) {
      _storedNumber = whatNumber;  //2) Store some arbitrary time that I pass to it so I can reference it later. normally used to save the last step time
      unsigned long storedNumber = _storedNumber;
      return _storedNumber;
    void waitTime(unsigned long whatTime) {
      TimeToWait = whatTime;  //2) Store some arbitrary time that I pass to it so I can reference it later. normally used to store the calculated step gap
    void startTimer() {
      _startTime = millis();
    unsigned long get_startTime() {
      return _startTime;
    double Counter (uint8_t controlCounter = 1) { //if countrolCounter = 0, then reset to 0, controlCounter = 1 then increment the counter by 1. If controlCounter = 2 then return current count
      if (controlCounter == 0) {
        _countNumber = 0;
      else if (controlCounter == 1) {
        _countNumber ++;
      else if (controlCounter == 2) {
        countNumber = _countNumber;
        return countNumber;
    unsigned long microsPerCount() {
      _endTime = micros();
      //_startTime = startTime;
      //_counts = counts;
      MPC = (_endTime  - _startTime) / _counts; //3) A function that subtracts one time against another and returns the answer.
      return MPC;
    unsigned long timeDifference(long startTime, long endTime) {
      _endTime = endTime;
      return _endTime  - _startTime; //3) A function that subtracts one time against another and returns the answer.
  private:
    unsigned long _storedTime;
    double _storedNumber;
    long _startTime;
    long _endTime;
    long _counts;
    long _countNumber;
  public:
    //constructor for motorControl class
    //I think this is a constructor and should execute when the object is created AND IT DOES!! YAY!
    motorControl (uint8_t motorType) {
      _type = motorType;
    //Set methods so that they are available all the time
    motorControl() {
      double _maxRPM = get_maxRPM();
      double _minRPM = get_minRPM();
      double _steps = get_Steps(1);
      double _currentRPH = 0;
      double _solarRPM = get_solarRPM();
      double _lunarRPM = get_lunarRPM();
      double _stepGap = calculate_stepGapRPM(_currentRPH, _steps);
      //double _increment = get_increment(_incrementSpeed);
      double _increment = 1;
      double _motorDirection = get_motorDirection();
      int _gap = 0;
      unsigned long _startTimeGTD = 0;
      unsigned long _endTimeGTD = 0;
      unsigned long _counterGTD = 0;
    void begin() {
      if (_type == RAMotor) {
        Serial.println("I'm an RA Motor!");
        _currentRPH = 60;//this does nothing - setup overrides this value
        _motorDirection = FORWARD;
      else if (_type == DECMotor) {
        Serial.println("I'm a DEC Motor!");
        _currentRPH = 0;
      else {
        Serial.println("I'm an unknown Motor!");
    //Functions for motorControl class
    //calculate the step gap for a given number of steps and desired output RPM
    unsigned long calculate_stepGapTimeDiff(unsigned long startTimeGTD, unsigned long endTimeGTD, unsigned long counterGTD) {
      //startTime is millis (to limit overflow rollover issues - millis repeats every 47 days, micros repeats every 17 minutes)
      unsigned long _startTimeGTD = startTimeGTD;
      unsigned long _endTimeGTD = endTimeGTD;
      unsigned long _counterGTD = counterGTD;
      _stepGap = ((_endTimeGTD - _startTimeGTD) / _counterGTD);
      return _stepGap;
    unsigned long calculate_stepGapRPM( double output_RPM, double steps) {
      _steps = steps;
      //Serial.println("I'm in calculate_stepGapRPM");
      //Serial.println(_steps);
      //Serial.println(output_RPM);
      //step_delay = 60L * 1000L * 1000L / number_of_steps / roles_Per_Minute;
      _stepGap = (60UL * 60UL * 1000UL * 1000UL ) / (_steps * output_RPM); //(steps * revs per hour (6 revs per hour for RA) / 3.6million MS per hour
      //_stepGap = (1 / (_steps * output_RPM) / (60L * 60L * 1000L));
      _currentRPH = output_RPM;
      //Serial.println(_stepGap);
      return _stepGap;
    //store the number of steps for one rotation of the stepper motor
    //    void steps(double get_steps) {
    //      _steps = get_steps;
    double get_maxRPM() {
      double _maxRPM = _currentRPH * (1.05);
      return _maxRPM;
    double get_minRPM() {
      double _minRPM = _currentRPH * (0.95);
      return _minRPM;
    double get_currentRPH() {
      return _currentRPH;
    void set_currentRPH(double setRPM) {
      _currentRPH = setRPM;
    double get_solarRPM() {
      double _solarRPM = 6;
      return _solarRPM;
    double get_lunarRPM() {
      double _lunarRPM = _currentRPH * (27.0 / 28.0);
      return _lunarRPM;
      Serial.println(_incrementIndex);//only works when I declare the variable in private
    double get_incrementRPH(uint8_t incrementSpeed) {
      uint8_t _incrementSpeed = incrementSpeed;
      if (_incrementSpeed = 1) {
        Serial.println("_minRPM:");
        Serial.println(_minRPM);
        double _increment = (_maxRPM - _minRPM) / 100.0;
        return _increment;
      }  else if  (_incrementSpeed = 2) {
        double _increment = (_maxRPM - _minRPM) / 10.0;
        return _increment;
      }  else if (_incrementSpeed = 3) {
        _maxRPM = 15;
        return _increment;
    double get_Steps(int precision) { //1 if 2048 (high precision) 2 if 1024 (low precision)
      double _steps;
      if (precision = 1) {
        return _steps = 2048;
      else if (precision = 2) {
        return _steps = 1024;
      else {
    double get_stepGap(double gap) {
      gap;
      if (gap = 0) {
        return _stepGap;
      else {
        _stepGap = gap;
    uint8_t get_motorDirection() {
      return _motorDirection;
  private:
    double _steps;
    double _stepGap;
    uint8_t _type;
    double _currentRPH;
    //double _currentRPM;
    double _maxRPM;
    double _minRPM;
    double _solarRPM;
    double _lunarRPM;
    int gap;
    uint8_t _incrementSpeed;
    double _increment;
    uint8_t _motorDirection;
    unsigned long startTimeGTD;
    unsigned long endTimeGTD;
    unsigned long counterGTD;
//=======Objects=======================
motorControl raMotor(RAMotor) ;
motorControl decMotor(DECMotor) ;
AF_Stepper motor_dec_stepper(1024, 1);
AF_Stepper motor_ra_stepper(1024, 2);
//=======Functions=====================
//--------translateIR Function----------
bool counterHasStarted;
// describing Remote IR codes
//unsigned long IRraw = IrReceiver.decodedIRData.decodedRawData;
  switch (IRraw)
    //Elgoo Controller
    //    case 0xFFA25D: Serial.println("POWER");       break;
    //    case 0xFFE21D: Serial.println("FUNC/STOP");   break;
    //    case 0xFF629D: Serial.println("VOL+");        break;
    //    case 0xFF22DD: Serial.println("FAST BACK");   break;
    //    case 0xFF02FD: Serial.println("PAUSE");       break;
    //    case 0xFFC23D: Serial.println("FAST FORWARD"); break;
    //    case 0xFFE01F: Serial.println("DOWN");        break;
    //    case 0xFFA857: Serial.println("VOL-");        break;
    //    case 0xFF906F: Serial.println("UP");          break;
    //    case 0xFF9867: Serial.println("EQ");          break;
    //    case 0xFFB04F: Serial.println("ST/REPT");     break;
    //    case 0xFF6897: Serial.println("0");           break;
    //    case 0xFF30CF: Serial.println("1");     break;
    //    case 0xFF18E7: Serial.println("2");     break;
    //    case 0xFF7A85: Serial.println("3");     break;
    //    case 0xFF10EF: Serial.println("4");     break;
    //    case 0xFF38C7: Serial.println("5");     break;
    //    case 0xFF5AA5: Serial.println("6");     break;
    //    case 0xFF42BD: Serial.println("7");     break;
    //    case 0xFF4AB5: Serial.println("8");     break;
    //    case 0xFF52AD: Serial.println("9");     break;
    //Sony Blu-Ray controller
    case 404758: Serial.println("Eject");        break;
    case 165: Serial.println("Input Select");    break;
    case 149: Serial.println("TV Power");    break;
    case 929045: Serial.println("Main Power");        break;
      Serial.println(decMotor.get_incrementRPH(decMotor.get_incrementIndex()));
      Serial.println(raMotor.get_incrementRPH(raMotor.get_incrementIndex()));
    case 404737: Serial.println("2");
      Serial.println("button 2 pressed");
      //set increments to 2
    case 404738: Serial.println("3");
      Serial.println("button 3 pressed");
      //set increments to 3
    case 929027: Serial.println("4");          break;
    case 929028: Serial.println("5");          break;
    case 929029: Serial.println("6");          break;
    case 929030: Serial.println("7");          break;
    case 929031: Serial.println("8");          break;
    case 929032: Serial.println("9");          break;
    case 929033: Serial.println("0");          break;
    case 929127: Serial.println("Red");          break;
    case 929128: Serial.println("Green");          break;
    case 929129: Serial.println("Yellow");         break;
    case 929126: Serial.println("Blue");           break;
    case 929068: Serial.println("Top Menu");       break;
    case 929065: Serial.println("Pop Up/Menu");    break;
    case 929091: Serial.println("Return");         break;
    case 929087: Serial.println("Options");        break;
    case 929090:
      Serial.println("Home");
      Serial.println("RATimer.countNumber");
      Serial.println(RATimer.countNumber);
      if (counterHasStarted == true) { //if the counter has been run before, then
        Serial.println("I'm going to start the RA timer");
        raMotor.get_stepGap(RATimer.microsPerCount());//calculate the micros Per Count (step gap), and store it
        RATimer.startTimer();//reset the timer
        RATimer.Counter(0); //reset the counter
        counterHasStarted = true;
        RATimer.Counter(0);
        //raMotor.get_stepGap(raMotor.calculate_stepGapRPM(raMotor.get_solarRPM(), raMotor.get_Steps(1)) ) ;
      Serial.println("New Step Gap");
      Serial.println(raMotor.get_stepGap(0));
      Serial.println("");
    case 929081: Serial.println("Up");
      // get current speed
      decMotor.get_currentRPH();
      // get increment
      Serial.println(raMotor.get_incrementRPH ( raMotor.get_incrementIndex())); //1 = slow, 2 = medium, 3 = fast
      // add both and recalculate speed
    case 929082: Serial.println("Down");           break;
    case 929083: Serial.println("Left");           break;
    case 929084: Serial.println("Right");          break;
    case 929085: Serial.println("Select/OK");      break;
    case 929050: Serial.println(">");              break;
    case 929049: Serial.println("\"");             break;
    case 929051: Serial.println("<< ");            break;
    case 929052: Serial.println(">>");             break;
    case 929111: Serial.println("|<< or Pentax Shutter Release");    break;
    case 929110: Serial.println(">>| or Pentax Shutter Release");    break;
    case 929048: Serial.println("Stop");           break;
    case 929123: Serial.println("Subtitles");      break;
    case 929124: Serial.println("Audio");          break;
    case 146: Serial.println("Vol + ");            break;
    case 147: Serial.println("Vol - ");            break;
    case 148: Serial.println("Mute");              break;
    case 929118: Serial.println("Favourite");      break;
    case 929089: Serial.println("Display");        break;
    default: Serial.println(IRraw); break;
  }// End Case
  //Serial.print(step_delay);
} //END translateIR
//=======Global Variables=======================
int doit = 1;
double last_IR_Time;
//=======SET UP=======================
  counterHasStarted = false;
  raMotor.begin();
  decMotor.begin();
  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK);
  //waitTime
  Serial.println("Initialise Timers");
  RATimer.savedTime(RATimer.getTime(1));//save the time NOW
  DecTimer.savedTime(DecTimer.getTime(1));
  IRTimer.savedTime(IRTimer.getTime(1));
  Serial.println(RATimer.getTime(0));
  Serial.println(RATimer.getTime(1));
  Serial.println(RATimer.getTime(2));
  Serial.println("wait time (setup)");
  RATimer.waitTime(raMotor.calculate_stepGapRPM(2000 , 2048)); //6 RPH
  DecTimer.waitTime(decMotor.calculate_stepGapRPM(60, 2048)); //change to 0 when live - //add line to release motor if 0.
  //DecTimer.waitTime(decMotor.);
  IRTimer.waitTime(500);
  Serial.println("END Initialise Timers");
//=======MAIN LOOP=======================
  // raMotor.steps(2048);
  //serial
  //Wait for IR Time to pass
  //need to initialise these variables then write the code in
  if   (micros() >= IRTimer.getTime(1) + IRTimer.getTime(2)) {
      //check the wait time here!! is it working?
    if (IrReceiver.decode()) {
      translateIR(IrReceiver.decodedIRData.decodedRawData);
      IrReceiver.resume(); // Enable receiving of the next value
  if (micros() >= (RATimer.getTime(1) + RATimer.getTime(2)))
    //Serial.println("time difference-desired difference");
    //Serial.println(RATimer.getTime(2));
    //Serial.println("time difference-actual error gap");
    //Serial.println(RATimer.timeDifference(RATimer.getTime(1), micros())- RATimer.getTime(2));
    //Serial.println("GAP");
    motor_ra_stepper.step(1, BACKWARD, DOUBLE); // need to change direction to variable
    RATimer.savedTime(micros());//save the time of the last step
    RATimer.Counter(1);//increment the counter
  }  if (micros() >= (DecTimer.getTime(1) + DecTimer.getTime(2)))
    //    Serial.println("time difference-desired difference");
    //    Serial.println(DecTimer.getTime(2));
    //Serial.println(DecTimer.timeDifference(DecTimer.getTime(1), micros())- DecTimer.getTime(2));
    motor_dec_stepper.step(1, FORWARD, DOUBLE); // need to change direction to variable
    DecTimer.savedTime(micros());//save the time of the last step
    DecTimer.Counter(1);//increment the counter
When you do this you are creating local variables with the same names as your member variables. When the constructor ends, those local variables disappers.
    motorControl()
      int _gap = 0;
What you probably WANTED to do is set the values of your member varibles.
    motorControl()
      _currentRPH = 0;
      //_increment = get_increment(_incrementSpeed);
      _increment = 1;
      _gap = 0;
      _startTimeGTD = 0;
      _endTimeGTD = 0;
      _counterGTD = 0;
You will need to add member variable named '_gap'.
This is common beginner mistake: using the assignment operator (=) when trying to compare for equality (==):
Thanks for this @johnwasser . Seems to make sense. I’ll give it a try tomorrow evening and let you know how I get on. Sorry for the slow reply and thanks for taking the time :+1:
Yes - I think you are right. I've modified the code, and I've made _incrementIndex public, and removed it elsewhere. I can now access and update that anytime so that's much better than before.
Yes - well spotted. I updated all the bits where I missed that. I'm sure that wasn't helping either.
Thanks for taking the time to look through my code. Much appreciated.
