This is the test code, seems to work just fine.
// Program used to test the driving simulator functions on
// the USB Joystick object on the Arduino Leonardo or
// Arduino Micro.
// Matthew Heironimus
// 2016-05-29 Original version.
#include "Joystick.h"
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_MULTI_AXIS, 4, 0,
false, false, false, false, false, false,
false, false, true, true, true);
// Set to true to test "Auto Send" mode or false to test "Manual Send" mode.
//const bool testAutoSendMode = true;
const bool testAutoSendMode = false;
const unsigned long gcCycleDelta = 1000;
const unsigned long gcButtonDelta = 500;
const unsigned long gcAnalogDelta = 25;
unsigned long gNextTime = 0;
unsigned int gCurrentStep = 0;
void testSingleButtonPush(unsigned int button)
if (button > 0)
Joystick.releaseButton(button - 1);
if (button < 4)
Joystick.pressButton(button);
void testMultiButtonPush(unsigned int currentStep)
for (int button = 0; button < 4; button++)
if ((currentStep == 0) || (currentStep == 2))
if ((button % 2) == 0)
} else if (currentStep != 2)
Joystick.releaseButton(button);
} // if ((currentStep == 0) || (currentStep == 2))
if ((currentStep == 1) || (currentStep == 2))
if ((button % 2) != 0)
} // if ((currentStep == 1) || (currentStep == 2))
if (currentStep == 3)
} // if (currentStep == 3)
} // for (int button = 0; button < 32; button++)
void testAcceleratorBrake(int value)
Joystick.setAccelerator(value);
Joystick.setBrake(260 - value);
void testSteering(int value)
if (value < 300) {
Joystick.setSteering(value);
Joystick.setSteering(600 - value);
Joystick.setAcceleratorRange(0, 260);
Joystick.setBrakeRange(0, 260);
Joystick.setSteeringRange(0, 300);
if (testAutoSendMode)
Joystick.begin();
Joystick.begin(false);
pinMode(A0, INPUT_PULLUP);
pinMode(13, OUTPUT);
// System Disabled
if (digitalRead(A0) != 0)
// Turn indicator light off.
digitalWrite(13, 0);
return;
// Turn indicator light on.
digitalWrite(13, 1);
if (millis() >= gNextTime)
if (gCurrentStep < 4)
gNextTime = millis() + gcButtonDelta;
testSingleButtonPush(gCurrentStep);
else if (gCurrentStep < 9)
testMultiButtonPush(gCurrentStep - 5);
else if (gCurrentStep < (9 + 260))
gNextTime = millis() + gcAnalogDelta;
testAcceleratorBrake(gCurrentStep - 9);
else if (gCurrentStep < (9 + 260 + 600))
testSteering(gCurrentStep - (9 + 260));
if (testAutoSendMode == false)
Joystick.sendState();
gCurrentStep++;
if (gCurrentStep >= (9 + 260 + 600))
gNextTime = millis() + gcCycleDelta;
gCurrentStep = 0;
