Help with code error - Error compiling for board Arduino Uno
Hello all,
I am trying to build a 'simple' word clock but I'm already stuck at the copy/paste of the code from the adafruit tutorial. I copied over all the libraries as per the instructions on the tutorial and I also included an additional library "#include <U8glib.h>" as per a youtube video with a supposed solutions but it didn't work.
The error appears when I try to compile or upload the code to an Arduino Uno.
I am a beginner, I've done other projects but I've never encountered this type of errors. I've attached screenshots of the Arduino Library and the "Adafruit_GFX_Library" as per the error description.
Please could someone kindly help!!
Thank you so much!
Henry
Word Clock tutorial
Error message
In file included from C:\Users\Henry\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.cpp:20:0:
C:\Users\Henry\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_MonoOLED.h:30:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
#include <Adafruit_I2CDevice.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
Code I'm using
#include <U8glib.h>
WORD CLOCK - 8x8 NeoPixel Desktop Edition
by Andy Doro
A word clock using NeoPixel RGB LEDs for a color shift effect.
Hardware:
  • Trinket Pro 5V (should work with other Arduino-compatibles with minor modifications)
  • DS1307 RTC breakout
  • NeoPixel NeoMatrix 8x8
Software:
This code requires the following libraries:
Wiring:
  • Solder DS1307 breakout to Trinket Pro, A2 to GND, A3 to PWR, A4 to SDA, A5 to SCL
    If you leave off / clip the unused SQW pin on the RTC breakout, the breakout can sit right on top of the Trinket Pro
    for a compact design! It'll be difficult to reach the Trinket Pro reset button, but you can activate the bootloader by
    plugging in the USB.
  • Solder NeoMatrix 5V to Trinket 5V, GND to GND, DIN to Trinket Pro pin 8.
grid pattern
A T W E N T Y D
Q U A R T E R Y
F I V E H A L F
D P A S T O R O
F I V E I G H T
S I X T H R E E
T W E L E V E N
F O U R N I N E
Acknowledgements:
  • Thanks Dano for faceplate / 3D models & project inspiration!
// include the library code:
#include <Wire.h>
#include <RTClib.h>
#include <DST_RTC.h>
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
// define how to write each of the words
// 64-bit "mask" for each pixel in the matrix- is it on or off?
uint64_t mask;
// define masks for each word. we add them with "bitwise or" to generate a mask for the entire "phrase".
#define MFIVE mask |= 0xF00000000000 // these are in hexadecimal
#define MTEN mask |= 0x5800000000000000
#define AQUARTER mask |= 0x80FE000000000000
#define TWENTY mask |= 0x7E00000000000000
#define HALF mask |= 0xF0000000000
#define PAST mask |= 0x7800000000
#define TO mask |= 0xC00000000
#define ONE mask |= 0x43
#define TWO mask |= 0xC040
#define THREE mask |= 0x1F0000
#define FOUR mask |= 0xF0
#define FIVE mask |= 0xF0000000
#define SIX mask |= 0xE00000
#define SEVEN mask |= 0x800F00
#define EIGHT mask |= 0x1F000000
#define NINE mask |= 0xF
#define TEN mask |= 0x1010100
#define ELEVEN mask |= 0x3F00
#define TWELVE mask |= 0xF600
#define ANDYDORO mask |= 0x8901008700000000
// define pins
#define NEOPIN 8 // connect to DIN on NeoMatrix 8x8
#define RTCGND A2 // use this as DS1307 breakout ground
#define RTCPWR A3 // use this as DS1307 breakout power
// brightness based on time of day- could try warmer colors at night?
#define DAYBRIGHTNESS 40
#define NIGHTBRIGHTNESS 20
// cutoff times for day / night brightness. feel free to modify.
#define MORNINGCUTOFF 7 // when does daybrightness begin? 7am
#define NIGHTCUTOFF 22 // when does nightbrightness begin? 10pm
// define delays
#define FLASHDELAY 250 // delay for startup "flashWords" sequence
#define SHIFTDELAY 100 // controls color shifting speed
RTC_DS1307 RTC; // Establish clock object
DST_RTC dst_rtc; // DST object
DateTime theTime; // Holds current clock time
int j; // an integer for the color shifting effect
// Do you live in a country or territory that observes Daylight Saving Time?
// Daylight saving time by country - Wikipedia
// Use 1 if you observe DST, 0 if you don't. This is programmed for DST in the US / Canada. If your territory's DST operates differently,
// you'll need to modify the code in the calcTheTime() function to make this work properly.
//#define OBSERVE_DST 1
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//Adafruit_NeoPixel matrix = Adafruit_NeoPixel(64, NEOPIN, NEO_GRB + NEO_KHZ800);
// configure for 8x8 neopixel matrix
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(8, 8, NEOPIN,
NEO_MATRIX_TOP + NEO_MATRIX_LEFT +
NEO_MATRIX_ROWS + NEO_MATRIX_PROGRESSIVE,
//Serial for debugging
//Serial.begin(9600);
// set pinmodes
pinMode(NEOPIN, OUTPUT);
// set analog pins to power DS1307 breakout!
pinMode(RTCGND, OUTPUT); // analog 2
pinMode(RTCPWR, OUTPUT); // analog 3
// set them going!
digitalWrite(RTCGND, LOW); // GND for RTC
digitalWrite(RTCPWR, HIGH); // PWR for RTC
// start clock
Wire.begin(); // Begin I2C
RTC.begin(); // begin clock
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(DATE, TIME));
// DST? If we're in it, let's subtract an hour from the RTC time to keep our DST calculation correct. This gives us
// Standard Time which our DST check will add an hour back to if we're in DST.
DateTime standardTime = RTC.now();
if (dst_rtc.checkDST(standardTime) == true) { // check whether we're in DST right now. If we are, subtract an hour.
standardTime = standardTime.unixtime() - 3600;
RTC.adjust(standardTime);
matrix.begin();
matrix.setBrightness(DAYBRIGHTNESS);
matrix.fillScreen(0); // Initialize all pixels to 'off'
matrix.show();
// startup sequence... do colorwipe?
// delay(500);
// rainbowCycle(20);
flashWords(); // briefly flash each word in sequence
// get the time
theTime = dst_rtc.calculateTime(RTC.now()); // takes into account DST
// add 2.5 minutes to get better estimates
theTime = theTime.unixtime() + 150;
adjustBrightness();
displayTime();
//mode_moon(); // uncomment to show moon mode instead!
Libraries screenshot.pdf (67.8 KB)
did you install all the libraries? looks like you're missing an I2C library
