Help with code (error)
Just want to start off saying that this isn’t my code and I am new to Arduino. I have the error message; ‘gps_port’ was not declared in this scope. Can someone help? I’ve made that bit red in colour to help you find it and for that reason, I didn’t upload it as code, but as a long piece of text. Any help would be much appreciated.
static NMEAGPS gps; // This parses the GPS characters
const int temperaturePin = 5;
int i = 0;
int altitudeft;
int altitudecm;
byte gps_set_sucess = 0 ;
float voltage, degreesC, degreesF;
void sendUBX(uint8_t MSG, uint8_t len) {
for(int i=0; i<len; i++) {
gps_port.write(MSG
_ Serial.print(MSG*, HEX);_
_
}_
gps_port.println();
_
}_
boolean getUBX_ACK(uint8_t MSG) {
uint8_t b;
* uint8_t ackByteID = 0;
uint8_t ackPacket[10];
_
unsigned long startTime = millis();*_
_ Serial.print(" * Reading ACK response: ");_
* // Construct the expected ACK packet *
* ackPacket[0] = 0xB5; // header*
* ackPacket[1] = 0x62; // header*
* ackPacket[2] = 0x05; // class*
* ackPacket[3] = 0x01; // id*
* ackPacket[4] = 0x02; // length*
* ackPacket[5] = 0x00;*
* ackPacket[6] = MSG[2]; // ACK class*
* ackPacket[7] = MSG[3]; // ACK id*
* ackPacket[8] = 0; // CK_A*
* ackPacket[9] = 0; // CK_B*
* // Calculate the checksums*
* for (uint8_t i=2; i<8; i++) {
_ ackPacket[8] = ackPacket[8] + ackPacket;
ackPacket[9] = ackPacket[9] + ackPacket[8];
}*_
* while (1) {*
* // Test for success*
* if (ackByteID > 9) {*
* // All packets in order!*
* Serial.println(" (SUCCESS!)");*
* return true;*
* // Timeout if no valid response in 3 seconds*
* if (millis() - startTime > 3000) {*
* Serial.println(" (FAILED!)");*
* return false;*
* // Make sure data is available to read*
* if (gps_port.available()) {
b = gps_port.read();*
* // Check that bytes arrive in sequence as per expected ACK packet*
* if (b == ackPacket[ackByteID]) {*
* ackByteID++;*
* Serial.print(b, HEX);*
* else {*
* ackByteID = 0; // Reset and look again, invalid order*
static void printL( Print & outs, int32_t degE7 );
* // Extract and print negative sign*
* if (degE7 < 0) {*
* degE7 = -degE7;*
* outs.print( ‘-’ );*
* // Whole degrees*
* int32_t deg = degE7 / 10000000L;
_ outs.print( deg );
outs.print( ‘.’ );
// Get fractional degrees*
degE7 -= deg10000000L;
// Print leading zeroes, if needed*
* int32_t factor = 1000000L;*
* while ((degE7 < factor) && (factor > 1L)){
outs.print( ‘0’ );
factor /= 10L;
}*_
* // Print fractional degrees*
* outs.print( degE7 );*
static void doSomeWork();
static void doSomeWork( const gps_fix & fix )
* // This is the best place to do your time-consuming work, right after*
* // the RMC sentence was received. If you do anything in “loop()”,*
* // you could cause GPS characters to be lost, and you will not*
* // get a good lat/lon.*
* // For this example, we just print the lat/lon. If you print too much,*
* // this routine will not get back to “loop()” in time to process*
* //the next set of GPS data.*
// test vs other option
* //float voltage, degreesC, degreesF;*
* //voltage = getVoltage(temperaturePin);*
_ //degreesC = (voltage - 0.5) * 100.0;
//degreesF = degreesC * (9.0/5.0) + 32.0;
* //Serial.println(degreesF);
if (i == 1) { // keeps a reading every 30 seconds. Change this to the time wanted between readings
//concern tha this takes time therefore could throw off repetition*
* // consistency*
// float voltage, degreesC, degreesF;
* voltage = getVoltage(temperaturePin);
if (degreesF > 300) {
}else {
// Serial.print("Degrees C "); //uncomment if you want celsius*
* // Serial.println(degreesC); //uncomment if you want celsius*
* Serial.print("Degrees F "); //comment if you do not want fahrenheit*
* Serial.println(degreesF); //comment if you do not want fahrenheit*
* }_
digitalWrite(LED_BUILTIN, HIGH);
_ if (fix.valid.time) {
// Set these values to the offset of your timezone from GMT*
* static const int32_t zone_hours = -7L; // PST*
* static const int32_t zone_minutes = 0L; // usually zero*
* static const NeoGPS::clock_t zone_offset =
zone_hours * NeoGPS::SECONDS_PER_HOUR +
zone_minutes * NeoGPS::SECONDS_PER_MINUTE;
NeoGPS::time_t localTime( fix.dateTime + zone_offset );*
* Serial << localTime;
if (fix.valid.location) {*_
* if ( fix.dateTime.seconds < 10 )*
* Serial.print( ‘0’ );*
* Serial.print( fix.dateTime.seconds );*
* Serial.print( ‘,’ );*
* // Serial.print( fix.latitude(), 6 ); // floating-point display*
* // Serial.print( fix.latitudeL() ); // integer display*
* printL( Serial, fix.latitudeL() ); // prints int like a float*
* // Serial.print( fix.longitude(), 6 ); // floating-point display*
* // Serial.print( fix.longitudeL() ); // integer display*
* printL( Serial, fix.longitudeL() ); // prints int like a float*
* if (fix.valid.satellites)*
* Serial.print( fix.satellites );*
* Serial.print( " , " );*
* Serial.print( fix.speed(), 6 );*
* Serial.print( F(" kn = ") );*
* Serial.print( fix.speed_mph(), 6 );
_ Serial.print( F(" mph") );
Serial.print( " " );
Serial.print(fix.heading());
Serial.print( F(" heading") );
Serial.print( " " );_
// Serial.print( gps.fix().altitude_cm());
altitudecm = gps.fix().altitude_cm();
_ altitudeft = altitudecm * 0.0328084;
Serial.print(altitudeft);*_
* } else {*
* // No valid location data yet!*
* Serial.print( ‘?’ );*
* Serial.println();*
* digitalWrite(LED_BUILTIN, LOW);
i = 0;
_}else{
i = i + 1;*_
* }// doSomeWork*
float getVoltage(int pin)
return (analogRead(pin) * 0.004882814);
static void GPSloop();
* while (gps.available( gps_port ))
_ doSomeWork( gps.read() );
} // GPSloop*_
* Serial.begin(9600);*
* pinMode(LED_BUILTIN, OUTPUT);
_ // Start the UART for the GPS device*
gps_port.begin(9600);
Serial.println("Setting uBlox flight mode: ");
uint8_t setNav[] = {
* 0xB5, 0x62, 0x06, 0x24, 0x24, 0x00, 0xFF, 0xFF, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x10, 0x27, 0x00, 0x00,
0x05, 0x00, 0xFA, 0x00, 0xFA, 0x00, 0x64, 0x00, 0x2C, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16, 0xDC };_
while(!gps_set_sucess)
_ {_
sendUBX(setNav, sizeof(setNav)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setNav);
_ }_
gps_set_sucess=0;*
* while (!Serial);*
* Serial.print( F(“NMEAloc.INO: started\n”) );*
* Serial.print( F("fix object size = ") );*
* Serial.println( sizeof(gps.fix()) );*
* Serial.print( F("NMEAGPS object size = ") );*
* Serial.println( sizeof(gps) );*
* Serial.println( F(“Looking for GPS device on " USING_GPS_PORT) );
_ Serial.print(“High Altitude Weather Balloon Data Logger”);
Serial.println(” by Aaron Price");
Serial.println(" Time Latitude Longitude SAT Wind Speed Wind Speed Altitude");
Serial.println(" (deg) (deg) knotts mph ft");
Serial.println("----------------------------------------------------------------------------------------------------------------");_
#ifdef NMEAGPS_NO_MERGING*
* Serial.println( F(“Only displaying data from xxRMC sentences.\n Other sentences may be parsed, but their data will not be displayed.”) );*
* #endif*
* Serial.flush();*
* GPSloop();*
* // If the GPS has been sending data, then the “fix” structure may have*
* // valid data. Remember, you must check the valid flags before you*
* // use any of the data inside “fix”. See “doSomeWork” for an example*
* // of checking whether any lat/lon data has been received yet.*
I have the error message; 'gps_port' was not declared in this scope.
What scope did you define it in?
Where is this declared? gps_port.
In order to use gps_port.write(MSG); you have to have a gps_port object.
I see no declaration for it.
PaulS:
I'm not sure, as I mentioned I am new to Arduino and haven't been able to figure out what went wrong as this isn't my code, I got it off someone online for a project I'm doing.
Where would I have to define it as an object?
You seem to be missing a serial port to read the GPS with. With an Arduino with only one hardware serial port (Uno, Mini, etc.) you would #include a software serial library and create an instance of a software serial object named gps_port. Look at the examples that come with the software serial library to see how to do it.
With an Arduino with multip!e harware serial ports you could use a #define to reference the hardware port with gps_port.
Savraj:
First, if this is not all the code, please post it all. IT does not seem to be all there. Next, did you make any modifications?
I will also mention that code is a mess and hard for us to read. Please use the code tags when you post all the code. Also have the ice indent it, CTL T I believe.
groundFungus:
With an Arduino with multip!e hardware serial ports you could use a #define to reference the hardware port with gps_port.
Ive looked at the software serial library examples and still am lost in how I am meant to do this, please could you give me an idea of how to do this?
Thank you to everyone who tried to help me with this, I really appreciate it. It turns out gps_port was updated to gpsPort in an update of something. Bit of a weird one. I had to go to the person who wrote the code to figure this one out, but thank you everyone nonetheless!
