Hi can anyone help me with this code. It uses an esp 32 dev V1, The task is search for a specified Bluetooth Mac address, When it is in range it turns on the led on pin 2. if it gets out of range it turns off. I want to make a crude keyless entry system with multiple smartwatches as keys (security is not important) but i can only get it to work with 1 Mac address at a time (the one specified as knownAdresses) can someone help me use this code with multiple Mac addresses as a key.
Code:
#include "BLEDevice.h"
unsigned int frequency = 1000;
unsigned int onDuration = 50;
unsigned int offDuration = 100;
unsigned int pauseDuration = 500;
unsigned int cycles = 10;
int LED = 2; // on-board LED at pin 2
int BUTTON = 0;
static BLEAddress *pServerAddress;
BLEScan* pBLEScan;
BLEClient* pClient;
bool deviceFound = false;
bool LEDoff = false;
bool BotonOff = false;
String knownAddresses[] = {"54:b7:e5:6c:79:d0"}; // change the MAC
unsigned long entry;
static void notifyCallback(
BLERemoteCharacteristic* pBLERemoteCharacteristic,
uint8_t* pData,
size_t length,
bool isNotify) {
Serial.print("Notify callback for characteristic ");
Serial.print(pBLERemoteCharacteristic->getUUID().toString().c_str());
Serial.print(" of data length ");
Serial.println(length);
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
void onResult(BLEAdvertisedDevice Device){
// show the MAC of other BLE devices
//Serial.print("BLE Advertised Device found: ");
//Serial.println(Device.toString().c_str());
pServerAddress = new BLEAddress(Device.getAddress());
bool known = false;
bool Master = false;
for (int i = 0; i < (sizeof(knownAddresses) / sizeof(knownAddresses[0])); i++) {
if (strcmp(pServerAddress->toString().c_str(), knownAddresses[i].c_str()) == 0)
known = true;
if (known) {
Serial.print("Our device found!");
Serial.print("Device distance:");
Serial.println(Device.getRSSI());
// adjust the value. -85 is medium distance
// -60 is closer than -85
if (Device.getRSSI() > -100) {
deviceFound = true;
else {
Device.getScan()->stop();
delay(100);
pinMode(LED,OUTPUT);
digitalWrite(LED,LOW);
BLEDevice::init("");
pClient = BLEDevice::createClient();
pBLEScan = BLEDevice::getScan();
pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
pBLEScan->setActiveScan(true);
Serial.println("Done");
void Bluetooth() {
Serial.println("BLE Scan restarted.....");
BLEScanResults scanResults = pBLEScan->start(5);
if (deviceFound) {
Serial.println("LED is ON now");
LEDoff = true;
digitalWrite(LED,HIGH);
BUTTON = 0;
else{
Bluetooth();
