Hello everyone,
In an effort to avoid troubling anyone, i have scoured the net/you tube in search of code for my project but to no avail. I have also spent hours looking on the forum (probably passed the answer) and have not been able to find code.
I need code to control a 3 digit(separate) sev-seg display read off an infrared encoder. This i want to use with an adjustable magnetic reed switch mounted on a lead shaft that's attached to a motor. So as the switch moves backwards or forwards...so the display goes up or down.
Please help
Kind regards
Joe
- No idea what that means. What does control mean in this context? What infrared encoder? Is it a remote from a TV? Have you analised the code pattern it sends?
How, you have just mentioned two totally different things without describing how they interact.
Physically or the numbers? What is the relationship?
- Are you just looking for code or do you want to learn how to write it?
Please read this:-
How to use this forum it will help you formulate a sensible question.
