Hello lovely forum. I have started a project to make a MIDI keyboard controller, keypad library didn’t offer more than 12 notes so I had to start on my own code. I am using a Arduino (original) MKRzero. My matrix scan code seems to have a problem, when I press a key the column above the actual column also registers. So it seems to jump somewhere in the code, this is the first time I have a array only for debouncing so there is probably some problems there. I have tried this without the actual keyboard and just jumping with wires and it gives the same problem with column above the actual column. I suspect the problem is somewhere in the mathematical operations of the matrix and maybe the fact that the mkrzero is really fast?Thank you in advance for help
Code: https://gist.github.com/brorgustav/ac2089083cbd08884b0ef51554893606
or:
#include "MIDIUSB.h"
#define debug SERIAL_PORT_MONITOR
#define ledPin A2
#define Keys 32
#define debugStart
//comment out to disable delay and printing during setup,
//the purpose is to show the pins for matrix through l2c
const int rows[] = {5, 4, 3, 2, 1, 0, 21, 20};
const int cols[] = {6, 8, 10, 12, 7, 9, 11, 13};
const int rowCount = 8;
const int colCount = 8;
//Loop count and delay variables
//Loopcount
unsigned long startTime;
unsigned long loopCount = 0;
unsigned long looptimer = 0;
//Delay
int printTime = 30;
int printDelay = 600;
unsigned long time_now = 0;
//Debounce variables
int debounceSampleMax = 40; // number of millis/samples to consider before declaring a debounced input
int debounceRead[colCount][rowCount]; // the current value read from the input pin
int debounceState[colCount][rowCount]; // the debounced input value
int debounceSampleCount[colCount][rowCount]; // how many times we have seen new value
long debounceTime[colCount][rowCount]; // the last time the output pin was sampled
//Normal rows: {8,9,10,11,12,13,14,15};
//Inverted rows:{15,14,13,12,11,10,9,8};
const int keynote[colCount][rowCount] = {
{1,9,17,25,33,41,49,57},
{2,10,18,26,34,42,50,58},
{3,11,19,27,35,43,51,59},
{4,12,20,28,36,44,52,60},
{5,13,21,29,37,45,53,61},
{6,14,22,30,38,46,54,62},
{7,15,23,31,39,47,55,63},
{8,16,24,32,40,48,56,64}
int firstKey=36;
int num_keys = Keys;
int channel=0;
int keys[colCount][rowCount];
int keys_prev[colCount][rowCount];
int noteIndex[48];
int noteCount;
debug.begin(115200);
// use default address 0
// pinMode(0, INPUT);
// pinMode(0, HIGH); // turn on a 100K pullup internally
#ifdef debugStart
delay(2500);
debug.println("*****************START*******************");
#endif
for (int x = 0; x < rowCount; x++) {
#ifdef debugStart
debug.print(x + 1); debug.print("/"); debug.print(rowCount);
debug.print(": "); debug.print("Pin #"); debug.print(rows[x]); debug.println(" as input");
debug.println("************************************");
delay(250);
#endif
pinMode(rows[x], INPUT);
delay(100);
for (int x = 0; x < colCount; x++) {
#ifdef debugStart
debug.print(x + 1);
debug.print("/");
debug.print(colCount);
debug.print(": ");
debug.print("Pin #"); debug.print(cols[x]); debug.println(" as input-pullup");
delay(250);
#endif
delay(100);
pinMode(cols[x], INPUT_PULLUP);
void scanMatrix()
for (int rowIndex=0; rowIndex < rowCount; rowIndex++) {
for (int colIndex=0; colIndex < colCount; colIndex++) {
int rx=keys[colIndex][rowIndex];
debounceMatrix(colIndex, rowIndex, rx);
void readMatrix() {
for (int colIndex = 0; colIndex < colCount; colIndex++) {
// col: set to output to low
int curCol = cols[colIndex];
pinMode(curCol, OUTPUT);
digitalWrite(curCol, LOW);
// row: interate through the rows
for (int rowIndex = 0; rowIndex < rowCount; rowIndex++) {
int rowCol = rows[rowIndex];
pinMode(rowCol, INPUT_PULLUP);
keys[colIndex][rowIndex] = digitalRead(rowCol);
//int rx=digitalRead(rowCol);
pinMode(rowCol, INPUT);
// debounceMatrix(colIndex, rowIndex, rx);
// disable the column
pinMode(curCol, INPUT);
void debounceMatrix(int colIndex, int rowIndex , int rx)
// if (rowCol != keys_prev[colIndex][rowIndex]) //If the rowCol (state) is different from last time scanned
// If we have gone on to the next millisecond
if(millis() != debounceTime[colIndex][rowIndex])
keys[colIndex][rowIndex] = rx;
if(rx == keys_prev[colIndex][rowIndex] && debounceSampleCount[colIndex][rowIndex] > 0)
debounceSampleCount[colIndex][rowIndex]--;
//debounceSampleCount[colIndex][rowIndex]=debounceSampleCount[colIndex][rowIndex]-1;
if(rx != keys_prev[colIndex][rowIndex])
debounceSampleCount[colIndex][rowIndex]++;
//debounceSampleCount[colIndex][rowIndex]=debounceSampleCount[colIndex][rowIndex]+1;
// If the Input has shown the same value for long enough let's switch it
if(debounceSampleCount[colIndex][rowIndex] >= debounceSampleMax)
debounceSampleCount[colIndex][rowIndex] = 0;
keys_prev[colIndex][rowIndex] = rx;
showMatrix(colIndex, rowIndex, rx);
// debug.print("KEY STATE IS DIFFERENT: "); debug.print("current="); debug.print(rx); debug.print("//"); //ebug.print("last known="); debug.println(keys_prev[colIndex][rowIndex]);
debounceTime[colIndex][rowIndex] = millis();
} // keys_prev[colIndex][rowIndex] = rowCol; //save the new state
void showMatrix(int colIndex, int rowIndex, int rx)
debug.print("column[");
debug.print(colIndex);
debug.print("] row[");
debug.print(rowIndex);
debug.print("]");
debug.print(" = ");
debug.println(rx);
void noteOn(int channel, int pitch, int velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
MidiUSB.flush();
debug.print("MIDI | NOTE ON: ");
debug.print(pitch);
debug.print(" / ");
debug.println(pitch, HEX);
void noteOff(int channel, int pitch, int velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
MidiUSB.flush();
debug.print("MIDI | NOTE OFF: ");
debug.print(pitch);
debug.print(" / ");
readMatrix();
scanMatrix();
