Help with code related to rotary encoder and 4x7segment display
I'm working on a project to turn the rotary encoder to increase a number (i have the basics of this figured out) and then push it to move to the next digit over and increase/decrease the number for that digit.
So i know the code for increasing the number related to the rotary encoder is wrong, but i don't know what to change it to. And then how to make all the digits the same brightness and actually display the correct numbers...
Here's the code i have so far... Any help would be appreciated! (I know the hardware setup is a little weird, i set it up as i went...)
/* Purpose: Defines hardware setup */
define sega 2
define segb 3
define segc 4
define segd 5
define sege 6
define segf 7
define segg 9
define encoderpina 10
define encoderpinb 11
define encoderpinswitch 12
define digit4 0
define digit3 1
define digit2 13
define digit1 8
/* Purpose: Declares each number output function */ void output_0(); void output_1(); void output_2(); void output_3(); void output_4(); void output_5(); void output_6(); void output_7(); void output_8(); void output_9();
/* Purpose: Declares variables for the loop function */ int number=0; int number4=0; int number3=0; int number2=0; int number1=0; int encoderpinaLast4=LOW; int encoderpinaLast3=LOW; int encoderpinaLast2=LOW; int encoderpinaLast1=LOW; int digit=4; int switchLast=LOW;
/* Purpose: Declares each pin as input or output */ void setup() { pinMode(sega, OUTPUT); pinMode(segb, OUTPUT); pinMode(segc, OUTPUT); pinMode(segd, OUTPUT); pinMode(sege, OUTPUT); pinMode(segf, OUTPUT); pinMode(segg, OUTPUT); pinMode(encoderpina, INPUT_PULLUP); pinMode(encoderpinb, INPUT_PULLUP); pinMode(encoderpinswitch, INPUT); pinMode(digit1, OUTPUT); pinMode(digit2, OUTPUT); pinMode(digit3, OUTPUT); pinMode(digit4, OUTPUT);
/* Purpose: Increments number when turned clockwise, decrements number when turned counter-clockwise */ void loop() { int n4=digitalRead(encoderpina); int n3=digitalRead(encoderpina); int n2=digitalRead(encoderpina); int n1=digitalRead(encoderpina);
if(digitalRead(encoderpinswitch==HIGH)){ digit--; if(digit==0) digit=4; }
if(digit==4){ if ((encoderpinaLast4 == LOW) && (n4 == HIGH)) { if (digitalRead(encoderpinb) == LOW) { number4++; if(number4==10) number4=0; } else { number4--; if(number4==-1) number4=9; } } encoderpinaLast4=n4; } if(digit==3){ if ((encoderpinaLast3 == LOW) && (n3 == HIGH)) { if (digitalRead(encoderpinb) == LOW) { number3++; if(number3==10) number3=0; } else { number3--; if(number3==-1) number3=9; } } encoderpinaLast3=n3; } if(digit==2){ if ((encoderpinaLast2 == LOW) && (n2 == HIGH)) { if (digitalRead(encoderpinb) == LOW) { number2++; if(number2==10) number2=0; } else { number2--; if(number2==-1) number2=9; } } encoderpinaLast2=n2; }
if(digit==1){ if ((encoderpinaLast1 == LOW) && (n1 == HIGH)) { if (digitalRead(encoderpinb) == LOW) { number1++; if(number1==10) number1=0; } else { number1--; if(number1==-1) number1=9; } } encoderpinaLast1=n1; }
digitalWrite(digit4, HIGH); digitalWrite(digit3, LOW); digitalWrite(digit2, LOW); digitalWrite(digit1, LOW); if(number4==0) output_0(); if(number4==1) output_1(); if(number4==2) output_2(); if(number4==3) output_3(); if(number4==4) output_4(); if(number4==5) output_5(); if(number4==6) output_6(); if(number4==7) output_7(); if(number4==8) output_8(); if(number4==9) output_9();
digitalWrite(digit4, LOW); digitalWrite(digit3, HIGH); digitalWrite(digit2, LOW); digitalWrite(digit1, LOW); if(number3==0) output_0(); if(number3==1) output_1(); if(number3==2) output_2(); if(number3==3) output_3(); if(number3==4) output_4(); if(number3==5) output_5(); if(number3==6) output_6(); if(number3==7) output_7(); if(number3==8) output_8(); if(number3==9) output_9();
digitalWrite(digit4, LOW); digitalWrite(digit3, LOW); digitalWrite(digit2, HIGH); digitalWrite(digit1, LOW); if(number2==0) output_0(); if(number2==1) output_1(); if(number2==2) output_2(); if(number2==3) output_3(); if(number2==4) output_4(); if(number2==5) output_5(); if(number2==6) output_6(); if(number2==7) output_7(); if(number2==8) output_8(); if(number2==9) output_9();
digitalWrite(digit4, LOW); digitalWrite(digit3, LOW); digitalWrite(digit2, LOW); digitalWrite(digit1, HIGH); if(number1==0) output_0(); if(number1==1) output_1(); if(number1==2) output_2(); if(number1==3) output_3(); if(number1==4) output_4(); if(number1==5) output_5(); if(number1==6) output_6(); if(number1==7) output_7(); if(number1==8) output_8(); if(number1==9) output_9(); }
See the solution in this post to get your display to work. Afterwards, we'll work on the encoder. http://forum.arduino.cc/index.php?topic=300444.0
Added:
What happens if the encoder skips? perhaps you would want to check if counter is greater than 9 and/or less than 0.
if ((encoderpinaLast1 == LOW) && (n1 == HIGH)) { if (digitalRead(encoderpinb) == LOW) { number1++; if(number1*==10) number1=0; } else { number1--; if(number1==*-1) number1=9; } }
