Help with code required
Hi guys,
I’m a beginner in Arduino programming. I have messed around with a couple of sketches but not that many. Anyways, here’s what’s going on
I want to basically control my Arduino with a PS3 controller/Wireless keyboard using a USB Host Sheild. I should say though that my USB Shield is different as it says “Arduino meets Android” on the board. Anyways, I tried adding a USB Shield library and loaded an example that came with the library. The problem is that the USB shield detects and displays all the buttons being pressed but on the serial monitor I see weird characters like: “ÒùªNö?óÿúøüøúþü?%% ¢Q¢T ñ? x1?1??1?0??1??1?1??1?0??1?0?11??1?” So I was wondering how do I convert that “language” into English and normal numbers.
I hope I made sense in this post as I generally have trouble explaining.
Thankyou
Oh and here is the code:
 Example sketch for the PS3 USB library - developed by Kristian Lauszus
 For more information visit my blog: http://blog.tkjelectronics.dk/ or
 send me an e-mail:  kristianl@tkjelectronics.com
#include <PS3USB.h>
USB Usb;
/* You can create the instance of the class in two ways */
PS3USB PS3(&Usb); // This will just create the instance
//PS3USB PS3(&Usb,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
boolean printAngle;
uint8_t state = 0;
  if (Usb.Init() == -1) {
    Serial.print(F("OSC did not start"));
    while(1); //halt
  Serial.print(F("PS3 USB Library Started"));
  Usb.Task();
  if(PS3.PS3Connected || PS3.PS3NavigationConnected) {
    if(PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
      Serial.print(F("LeftHatX: "));
      Serial.print(PS3.getAnalogHat(LeftHatX));
      Serial.print(F("LeftHatY: "));
      Serial.print(PS3.getAnalogHat(LeftHatY));
      Serial.print(F("RightHatX: "));
      Serial.print(PS3.getAnalogHat(RightHatX));
      Serial.print(F("RightHatY: "));
      Serial.print(PS3.getAnalogHat(RightHatY));
    // Analog button values can be read from almost all buttons
    if(PS3.getAnalogButton(L2_ANALOG) > 0 || PS3.getAnalogButton(R2_ANALOG) > 0) {
      Serial.print(F("L2: "));
      Serial.print(PS3.getAnalogButton(L2_ANALOG));
      Serial.print(F("R2: "));
      Serial.print(PS3.getAnalogButton(R2_ANALOG));
    if(PS3.getButtonClick(PS))
      Serial.print(F("PSButtonPressed"));
    if(PS3.getButtonClick(TRIANGLE))
      Serial.print(F("Traingle"));
    if(PS3.getButtonClick(CIRCLE))
      Serial.print(F("Circle"));
    if(PS3.getButtonClick(CROSS))
      Serial.print(F("Cross"));
    if(PS3.getButtonClick(SQUARE))
      Serial.print(F("Square"));
    if(PS3.getButtonClick(UP)) {
      Serial.print(F("Up"));
      PS3.setAllOff();
      PS3.setLedOn(LED4);
    if(PS3.getButtonClick(RIGHT)) {
      Serial.print(F("Right"));
      PS3.setAllOff();
      PS3.setLedOn(LED1);
    if(PS3.getButtonClick(DOWN)) {
      Serial.print(F("Down"));
      PS3.setAllOff();
      PS3.setLedOn(LED2);
    if(PS3.getButtonClick(LEFT)) {
      Serial.print(F("Left"));
      PS3.setAllOff();
      PS3.setLedOn(LED3);
    if(PS3.getButtonClick(L1))
      Serial.print(F("L1"));
    if(PS3.getButtonClick(L3))
      Serial.print(F("L3"));
    if(PS3.getButtonClick(R1))
      Serial.print(F("R1"));
    if(PS3.getButtonClick(R3))
      Serial.print(F("R3"));
    if(PS3.getButtonClick(SELECT)) {
      Serial.print(F("Select - "));
      Serial.print(PS3.getStatusString());
    if(PS3.getButtonClick(START)) {
      Serial.print(F("Start"));
      printAngle = !printAngle;
  if(printAngle) {
    Serial.print(F("Pitch: "));
    Serial.print(PS3.getAngle(Pitch));
    Serial.print(F("Roll: "));
    Serial.print(PS3.getAngle(Roll));
  else if(PS3.PS3MoveConnected) { // One can only set the color of the bulb, set the rumble, set and get the bluetooth address and calibrate the magnetometer via USB
    switch(state) {
    case 0:
      PS3.moveSetRumble(0);
      PS3.moveSetBulb(Off);
      state = 1;
    case 1:
      PS3.moveSetRumble(75);
      PS3.moveSetBulb(Red);
      state = 2;
    case 2:
      PS3.moveSetRumble(125);
      PS3.moveSetBulb(Green);
      state = 3;
    case 3:
      PS3.moveSetRumble(150);
      PS3.moveSetBulb(Blue);
      state = 4;
    case 4:
      PS3.moveSetRumble(175);
      PS3.moveSetBulb(Yellow);
      state = 5;
    case 5:
      PS3.moveSetRumble(200);
      PS3.moveSetBulb(Lightblue);
      state = 6;
    case 6:
      PS3.moveSetRumble(225);
      PS3.moveSetBulb(Purble);
      state = 7;
    case 7:
      PS3.moveSetRumble(250);
      PS3.moveSetBulb(White);
      state = 0;
Did you set the serial monitor speed to 115200 baud?
Ohhh, I have done just that and its now working perfectly. Thankyou! :D
